Toshiba SD-P101S 10.2-inch Portable DVD Player
4.6
based on 21 reviews
from
Ratings Distribution
5 star
16
4 star
3
3 star
1
2 star
1
1 star
0
Category Average
3.9
More Images
Pros
  • Great picture quality (17)
  • Portable (17)
  • Nice sound (15)
  • Good battery life (13)
  • Simple / intuitive controls (13)
  • Durable (11)
  • Lightweight (11)
  • Excellent screen size (1)
  • High resolution picture (1)
See less See more
Cons
  • Disk drive makes noise (1)
  • Finding a case to fit (1)
  • Poor sound quality (1)
  • Speakers are not too loud (1)
Best Uses
  • Home (13)
  • Travel (11)
  • In the car (8)
  • Office (7)
Provided by Beach Audio
Take your favorite movies on the road. This elegantly designed portable DVD player boasts a 10.2" wide swivel-screen with brilliant 800x480 resolution. A 4-in-1 Card Slot and DivX 6 support provide extra viewing options, and the powerful Battery has a life of up to 5 hours. When you're in the mood for a movie, this versatile player can play back many different types of prerecorded DVDs, including DVD-R/-RW discs. If you want to give your eyes a rest and listen to some tunes instead, the SD-P101S DVD player handles lots of the most popular Audio formats around, including CDs, MP3 - CD, CD-R/RW discs and WMA files.
  • Box Contents: Toshiba SD-P101S Portable DVD Player, Lithium Battery Pack, AC Adapter (100-240v), Car Cord Adapter, AV Cable, Remote Control, Owner's Manual
  • 10.2" diagonal Wide LCD Panel
  • 800 x 480 Resolution
  • Multi-format playback - DVD-Video/DVD-R/DVD-RW/DVD VR/CD/CD-R/CD-RW Discs
  • 14bit Video DAC with 108MHz Processing
  • Swivel and Flip Screen
  • 24bit Audio DAC with 192kHz Processing
  • Dolby Digital/DTS (Coaxial) Output
  • Plays MP3 and WMA formats
  • JPEG Viewer
  • 4-in-1 Card Reader (JPEG): SD, MMC, MS, xD
  • Features: Video Adjustments (Brightness, Contrast, Color, Tint) and Zoom Mode
  • Connections: A/V Mini Jack Input, A/V Mini Jack Output, 2 x Headphone jacks
  • Approximate Unit Dimensions: 11.02" (W) x 1.26" (H) x 7.48" (D)
  • Specification Description
    Model DVTO101, SD-P101S, SDP101S
    UPC 022265001479
    Analog Audio / Video (Mini) Yes
    Card Slot Memory Stick
    Card Slot Secure Digital
    Card Slot xD-Picture Card
    Compatible Formats CD
    Compatible Formats CD-R
    Compatible Formats CD-RW
    Compatible Formats DVD
    Compatible Formats DVD-R
    Compatible Formats DVD-RW
    Compatible Formats DVD-VR
    Compatible Formats DiVX
    Compatible Formats MP3
    Compatible Formats WMA
    Depth (Inches) 7.48
    Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
    DiVX Play Compatible Yes
    DVD Dual Layer Play Compatible Yes
    Headphone Jack Yes
    Height (Inches) 1.26
    LCD Display Size (Inches) 10.2
    Memory Card Slot Yes
    Power Supply Battery / 110 Volts AC / 12V DC Car
    Screen Size 10.2"
    Screen Size (Inches/Diagonal) 10
    Speakers Built-in
    Width (Inches) 11.02
    Toshiba SD-P101S 10.2-inch Portable DVD Player Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: SD-P101S 10.2-inch Portable DVD Player
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: May 10, 2009
    Toshiba SD-P101S 10.2-inch Portable DVD Player Reviews
    Most helpful positive review
    Most helpful negative review
    [1 of 1 customers found this review helpful]
    5.0
    Out-of-the-box FABULOUS!!
    "I got this DVD player for my elderly mother (who is terrified of DVDs, but who REALLY wanted to watch movies in the kitchen in the early morning hours). She found it so easy to use and operate that she's a real convert to DVDs now, and can enjoy her movies without disturbing my dad. I found that it wouldn't play a couple of my purchased DVDs (I still don't understand why), but overall, it performs beautifull..." Read Full Review »
    Oct 07, 2008 by Terri
    See more positive Toshiba SD-P101S 10.2-inch Portable DVD Player reviews
    3.0
    Versatile player
    "Good Divx player as well as DVD player. Worked with DVD-R and CD media. Picture is very good but sound volume is low. Plan on using this with earphones. The batteries will not recharge while the unit is turned on. If the batteries are low they must be removed to use the unit on AC power. Controls are small and hard to read..." Read Full Review »
    Oct 01, 2008 by Ernie
    See more negative Toshiba SD-P101S 10.2-inch Portable DVD Player reviews
    Displaying 1 - 5 of 21 Reviews
    Show
    Sort by
    5.0
      Pros
    • Durable
    • Good Picture
    • Good Sound
    • Lightweight
    • Portable
      Cons
    • None
      Best Uses
    • At Home
    I found th …"  Read Full Review »
    Was this Portable DVD Player review on the Toshiba SD-P101S 10.2-inch Portable DVD Player helpful to you?
    Oct 7 2008
    Terri
    Florham Park, NJ
    I am:
    • Gearhead
    Reviewed at:
    best one i've seen
    5.0
      Pros
    • Easy Controls
    • Good Picture
    • Good Sound
    • Lightweight
    • Portable
      Cons
      Best Uses
    • At Home
    • In The Car
    "the Toshiba was the best 10.2" portable i have seen. Its thin and light weight. As far as durability i think all portables are a little fragile and need to be taken care of and not bounced around. Its the nature of the product. I def. wld buy this again.
    The battery life is not real long but …"  Read Full Review »
    Jan 19 2009
    Boxer owner
    Lancaster, Pa
    I am:
    • Practical
    Reviewed at:
    Outstanding Portable DVD player
    5.0
      Pros
    • Durable
    • Easy Controls
    • Good Picture
    • Good Sound
    • Lightweight
    • More »
      Cons
    • None
      Best Uses
    • At Home
    • Office
    • Travel
    "My wife uses the DVD player to review her YOGA training dvd's and is able to take and type notes on her computer. The Toshiba is easy to stop, pause and continue. It is easy to view and the 10.2 screen is great. I can't find anything that is not great! "
    Jan 7 2009
    Marilyn
    Kirkland Wa
    I am:
    • Frequent Traveler
    • Practical
    • Student
    Reviewed at:
    Great DVD Player
    4.0
      Pros
    • Durable
    • Easy Controls
    • Good Picture
    • Long Battery Life
    • Portable
      Cons
      Best Uses
    • In The Car
    • Travel
    "I bought this product for the car and travel for a wee one - just took it on a flight to Memphis and it was great! Easy to carry and great picture on the plane. Only con is the sound only goes up so much - but that is what ear phone are for :o) "
    Jan 8 2009
    DBadiali
    NJ
    I am:
    • Frequent Traveler
    • Mother of 21 month old
    • Practical
    Reviewed at:
    Versatile player
    3.0
      Pros
    • Good Picture
    • Long Battery Life
    • Portable
      Cons
    • Poor Sound
      Best Uses
    • Travel
    "Good Divx player as well as DVD player. Worked with DVD-R and CD media. Picture is very good but sound volume is low. Plan on using this with earphones. The batteries will not recharge while the unit is turned on. If the batteries are low they must be removed to use the unit on AC power. Controls a …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Oct 1 2008
    Ernie
    Atlanta
    I am:
    • Frequent Traveler
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
