Toshiba ® Satellite® P305-S8902 17" Satellite
#381
3.4
based on 17 reviews
Ratings Distribution
5 star
6
4 star
4
3 star
0
2 star
4
1 star
3
Category Average
4.3
$749.99 at Amazon
Find it at Amazon
Find it at Ebay
$749.99
from 1 store
More Images
Pros
  • Comfortable keyboard (2)
  • Fast (2)
  • Powerful (2)
  • Quality display (2)
  • Quiet (1)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Business use (2)
  • Graphics (2)
  • Music (2)
  • Video (2)
  • Web browsing (2)
  • Word processing (2)
Provided by MAGo Enterprise
Toshiba Satellite P305-S8904. Intel Core 2 Duo Processor T6400 2.0GHz 2MB L2 Cache 800MhHz FSB Mobile Intel GM45 Express Chipset Integrated Wi-Fi compliant wireless LAN Intel Wi-Fi Link 5100AGN (802.11a/g/n). 4GB PC6400 DDR2 SDRAM. Genuine Windows Vista Home Premium (SP1 64-bit version). 17.0 diagonal widescreen TruBrite TFT LCD display at 1440x900 native resolution (WXGA+). Native support for 720p content.
Specification Description
Model P305-S8904, PSPC8U-01400Q
UPC 883974185931
Auto Sensing Yes
Battery Type Product
Benefits 2.0GHz Intel Core 2 processor T6400, 2MB L2, 800MHz FSB provides the muscleConfigured with 4GB PC6400 DDR2 SDRAM, expandable to 8GB s
Body Material Metal
Cache Installed Size 2048 KB
Cache Memory Type L2 cache
Capacity 400
Capacity UOM mAh
Card Reader Type 5-in-1 Bridge Media Adapter
Chemistry Lithium Ion
Chipset Type Mobile Intel® GM45
Color Support 64-bit
Connections RGB (monitor) output portS/P DIF output port (shared with headphone port)1/8" nicrophone input port1/8" headphone o
Country Of Origin China
Data Bus Speed 800 MHz
Data Link Protocol 10/100Base-T Ethernet; 802.11a/g/n WLAN
Description Header It's like a portable desktop.
Display Catalog Number 55031022
Display Form Factor Built-in
Display Size 17 inches
Enclosure Color Black
End Product Indicator Yes
Expansion Slots Total (Free) ExpressCard slot supporting ExpressCard/34 and ExpressCard/54 (1)
Features Integrated Wi-Fi® compliant Intel® Wi-Fi Link 5100AGN wireless-LAN*, 10/100 Ethernet for Web surfingIntel® Graphics Media
Graphics Controller Type Intel® Graphics Media Accelerator 4500MHD
Hard Drive 320GB 5400rpm SATA hard drive
Humidity Range Operating 20-80%
Included in the Box Toshiba Satellite P305-S890475W (19V 3.95A) 100-240V/50-60Hz AC adapterLi-ion battery pack
Input Device 104 key US with 10-key; TouchPad pointing device
Installed Qty 1
Installed Size 4GB installed, 8GB maximum
Manufacturer Labor Warranty 12
Manufacturer Part Number PSPC8U-01400Q
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Altitude Operating 10000 ft
Max Operating Temperature 95 Fahrenheit
Max Resolution 1440x900
Max Resolution (external) 1440x900
Max Supported Qty 1
Memory Specification Compliance PC6400 DDR2 SDRAM
Memory Speed 800 MHz
Min Operating Temperature 41 Fahrenheit
Mobile Technology Intel® Centrino®
Model P305-S8904
Networking 10/100 Ethernet; Wi-Fi® compliant WLAN
Networking Compliant Standards Ethernet; Wi-Fi
Operating Temperature UOM ° F
Optical Storage Type DVD SuperMulti (+/- dbl lyr) drive with Labelflash
OS Provided Genuine Windows Vista® Home Premium (SP1,64-bit version)
Power Device AC adapter; Li-ion battery pack
Processor Speed 2.0GHz
Processor Type Intel Core 2
Product Depth 11.4
Product Dimensions UOM inches
Product Disclaimer *Wireless access point required and not included. Wireless Internet use requires separately purchased Internet service contract. Availability of publi
Product Height 1.5
Product Type Laptops
Product Weight 7.4
Product Weight UOM pounds
Product Width 15.8
RAM Form Factor 2 slots
RAM Technology PC6400 DDR2 SDRAM
Read Speed Up to 24x CD; 8x DVD
Rechargeable Yes
Rewrite Speed Up to 24x CD; 8x DVD
Shock Tolerance 10G operating; 60G non-operating
Size Specialty
Software Included TOSHIBA ConfigFree®, Microsoft® Office Trial Home and Student 2007 Edition (60-day trial), TOSHIBA DVD Player, TOSHIBA Games Console, designed
Speaker(s) Built-in harman/kardon® stereo speakers
Supported Flash Memory Cards Secure Digital, Secure Digital High Capacity, Memory Stick, Memory Stick PRO, MultiMedia Card, xD Picture Card
Supported Languages English
Type 17.0" diagonal widescreen TruBrite® TFT LCD display at 1440x900 native resolution (WXGA+), native support for 720p content
Vibration Tolerance 0.5G operating; 1.0G non-operating
Video Memory 128MB-1759MB dynamically allocated shared memory
Wireless NIC Intel® Wi-Fi Link 5100AGN
Write Speed Up to 24x CD; 8x DVD
Toshiba ® Satellite® P305-S8902 17" Satellite Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 6, 2009
Toshiba ® Satellite® P305-S8902 17" Satellite Reviews
Most helpful positive review
[20 of 20 customers found this review helpful]
Most helpful negative review
[5 of 5 customers found this review helpful]
5.0
Toshiba does it right!
"If you are looking for a widescreen laptop, this Satellite has everything you want and doesn't give you things you don't want for the money. I had an HP and I won't ever go back. I love the fact that you get the (64 bit) version of Vista, that is the only way to get the true benefits of 4gb of ram with Vista. The eSATA/USB port is the only way to go if you are planing on using an external storage device, it is m..." Read Full Review »
Mar 06, 2009 by T. Tenney
See more positive Toshiba ® Satellite® P305-S8902 17" Satellite reviews
2.0
touchpad
"I wish Toshiba had this computer, and I had my money back; I spent much more on it than today's advertised price. I recently tried to use the CD drive, which would not work. However, the main complaint I have, is the extremely sensitive touch pad, which is constantly kicking me out somewhere into cyberspace. And, this guy is also a "self-scrolling" unit. There are times when I'm not touching it and it will st..." Read Full Review »
Jun 14, 2009 by Shiloh
See more negative Toshiba ® Satellite® P305-S8902 17" Satellite reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
5.0
"If you are looking for a widescreen laptop, this Satellite has everything you want and doesn't give you things you don't want for the money. I had an HP and I won't ever go back. I love the fact that you get the (64 bit) version of Vista, that is the only way to get the true benefits of 4gb of ram w …"  Read Full Review »
Was this Laptop review on the Toshiba ® Satellite® P305-S8902 17" Satellite helpful to you?
 Report Abuse  (20)  (0)  0 comments
Mar 6 2009
T. Tenney
Utah
Reviewed at:
Price: $749.99
touchpad
2.0
However, the main complaint I have, is the extremely sensitive touch pad, which is constantly kicking me out somewhere into …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Jun 14 2009
Shiloh
Amazon
Reviewed at:
Price: $749.99
[2 of 2 customers found this review helpful]
Great Deal for the Money!
5.0
    Pros
  • Comfortable Keyboard
  • Fast
  • Powerful
  • Quality Display
  • Quiet
    Cons
  • None
    Best Uses
  • Business Use
  • Graphics
  • Music
  • Video
  • Web Browsing
  • More »
"Love this lap top for sure! Owned a different brand lap top prior to this one, and I won't go back! Great product. Has lots of great stuff for the price. Would recommend to anyone. "
 Report Abuse  (2)  (0)  0 comments
May 11 2009
Mrs G-2
Arizona
I am:
  • Tech Savvy
Reviewed at:
Touchpad and DVD Problems
2.0
"There are so many things to like about the Toshiba P305-S8910: sleek attractive appearance, 17- inch Tru-Brite screen, and overall, pretty good performance for a modestly priced laptop. I was able to become accustomed to the heavier than expected weight of the laptop. However, just as other reviewer …"  Read Full Review »
Jun 18 2009
conscientious consumer
Northeast USA
Reviewed at:
Price: $749.99
4.0
    Pros
  • Fast
  • Powerful
  • Quality Display
    Cons
  • Heavy
    Best Uses
  • Business Use
  • Graphics
  • Music
  • Video
  • Web Browsing
  • More »
"I use this computer for college works and it fits all the expectations, it's fast, it has good HD capacity, it's a bit heavy but i dont really care about it, vista its the only problem "
Jun 30 2009
Erick Vasquez
Guatemala
I am:
  • Avid Gamer
  • Multimedia Professional
  • Student
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
