Toshiba REGZA 40-Inch 1080p LCD HDTV (Model #40XV645U)
#141
4.5
based on 30 reviews
Ratings Distribution
5 star
20
4 star
8
3 star
0
2 star
1
1 star
1
Category Average
4.4
$765.00 - $869.99
from 16 stores
More Images
Pros
  • Attractive design (11)
  • High resolution (11)
  • Fast setup (10)
  • Great picture quality (9)
  • Good connection options (7)
  • Wide viewing angle (6)
  • Simple controls (2)
  • Good value (1)
See less See more
Cons
  • Poor sound quality (3)
  • Difficult to set up (2)
Best Uses
  • Home (10)
  • Bedroom (4)
  • Movies (3)
  • Wall mounting (3)
  • Home theater (2)
Provided by OneCall
ClearFrame™ 120Hz
Doubles the video frames from 60 per second to 120 per second to reduce any motion blur that could be caused by fast action video. By using advanced motion vector frame interpolation, it improves picture clarity without affecting picture brightness or adding flicker. For those that prefer a more film-like picture, there is also a 5:5 Pull-Down option available.
Resolution+™
Some video content is in high definition (HD), but some is still in standard Definition (SD). However, REGZA® virtually levels the content playing fi eld with Resolution+™. Resolution+™ is super resolution technology that upconverts and enhances 480i, 480p, and even 720p content to create a sharper, more detailed picture. With REGZA® and Resolution+™ all of your standard DVDs, SD TV channels, camcorder videos, and even SD video games will feel like HD.
AutoView™
A TV picture must be bright enough for high contrast viewing during the day, but not so bright that it causes eye strain at night. To achieve this, REGZA® offers AutoView™. This system combines an ambient room light sensor and advanced algorithms that monitor the incoming video signal. AutoView™ can automatically control the TV picture settings to produce the ideal picture in any room lighting condition.
Bottom Deep Lagoon™ Design
Inspired by nature and reminiscent of sand disappearing below the surface of calm shores, the Deep Lagoon™ design adds a unique feeling of character and depth to fl at panel TV.
Specification Description
Model 40XV645U, TOS-40XV645U, TOS40XV645
UPC 022265002513
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
color null
Component Video (2) Rear Input
Contrast Ratio 50000:1
Contrast Ratio (Dynamic) 50,000:1
DB15 (PC Video) (1) Rear Input
Depth (Inches) 10.4
Dynamic Contrast Ratio 50000:1
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Height (Inches) 26.1
Optical (1) Rear Output
PC Audio (1) Rear Input
Ports 1 x Composite Video In Rear
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
S-Video (1) Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 40"
Screen Size (inches) 40
Screen Size (Inches/Diagonal) 40
size null
sku 157560
skuprice 999.9900
Speakers Built-in
Stand Included
style TOS40XV645
taxable Y
Technology HDTV
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port (1) Side Input
USB Port Service Only
Wall Mountable VESA Compliant
Wall Mountable Yes
Weight (Pounds) 38.6
Width (Inches) 38.4
Toshiba REGZA 40-Inch 1080p LCD HDTV (Model #40XV645U) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Toshiba REGZA 40-Inch 1080p LCD HDTV (Model #40XV645U) Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
After careful ...
"After careful consideration and comparrison of 40" 120hz LCD TV's, I decided I liked the Toshiba Regza 40XV645U and a comparable Samsung model; the Toshiba was lower priced (not an important factor) and more aesthetically pleasing to my preference,- also having a well designed long and wide sturdy base (rather than most that have a piller/post neck with questionable stability, that are better suited for wall mou..." Read Full Review »
Jul 22, 2009 by Nakima
See more positive Toshiba REGZA 40-Inch 1080p LCD HDTV (Model #40XV645U) reviews
1.0
Defective Toshiba TV Set...
"Purchased after much research. Picture was great- stunned to discover that the TV was part of a "small" percentage of defective sets- that had a maddening flickering black and white horizontal bar across the top of the screen. Found out about it only after searching the Toshiba site and reading the fine print comparing our serial number to that of the bad batch... Terrible customer service for the first attempt ..." Read Full Review »
Aug 30, 2009 by Debbiesoul
See more negative Toshiba REGZA 40-Inch 1080p LCD HDTV (Model #40XV645U) reviews
Displaying 1 - 5 of 30 Reviews
Show
Sort by
After careful ...
5.0
"After careful consideration and comparrison of 40" 120hz LCD TV's, I decided I liked the Toshiba Regza 40XV645U and a comparable Samsung model; the Toshiba was lower priced (not an important factor) and more aesthetically pleasing to my preference,- also having a well designed long and wide sturdy b …"  Read Full Review »
Was this LCD TV review on the Toshiba REGZA 40-Inch 1080p LCD HDTV (Model #40XV645U) helpful to you?
Jul 22 2009
Nakima
Minnesota
Reviewed at:
Price: $799.99
the price was good [...]
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"I luv my tv. The picture quality is excellent and the sound is good and loud. The only thing I'm not pleased with is that are no controls on the tv to operate the tv. you have to use the remote to control the unit. what if you loose the remote? That wasn't a good ideal toshiba. Other than that flaw, …"  Read Full Review »
Oct 26 2009
Bonita
ex Tobacoville, NC
I am:
  • Casual User
Reviewed at:
Price: $789.97
Love it....
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Reduced Glare
    Cons
  • Poor Sound
    Best Uses
  • Home
  • Wall Mounting
"Couldn't ask for better so far...speakers pointing down don't provide the best sound, but a minor quibble on a fine machine! "
Nov 16 2009
Neophyte
Central Mountains, Colorado
I am:
  • Casual User
Reviewed at:
Price: $789.97
great features and price
5.0
    Pros
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Reduced Glare
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Home
  • Movies
"The Toshiba 40xv645u HD TV is great TV . This is my first HD TV,but it is way above entry level. I love the Resolution+feature,it makes standard tv resolution look almost HD. Blu ray movies look incredible.The only minor negative thing is the speakers,but I think most people will use a home theate …"  Read Full Review »
Sep 15 2009
mike in chicopee
Chicopee MA
I am:
  • Casual User
Reviewed at:
Price: $789.99
Solid LCD TV. Good price.
4.0
    Pros
  • Attractive Design
  • Good Resolution
  • Reduced Glare
    Cons
  • Difficult To Set Up
    Best Uses
  • None
"This is a very good LCD tv at a very good price.
Don't let other cheaper 40" LCD fool you b/c this LCD TV is 120MHZ. The picture quality is solid and the sound is ok.
When setting up using HDMI connection, if not getting a sound, make sure to go into menu and go into AV connection and change HDMI …"  Read Full Review »
Aug 21 2009
ps3
east coast
I am:
  • Casual User
Reviewed at:
Price: $828.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
