Close Login Module
Join
Toshiba DVR600 Dvd Recorder & Vcr With 1080p
2.7
based on 10 reviews
Ratings Distribution
5 star
1
4 star
3
3 star
2
2 star
0
1 star
4
Category Average
3.6
Pros
  • Easy to use (3)
  • Durable (2)
  • Easy setup (2)
  • Attractive design (1)
  • Consistent performance (1)
  • Fast recording (1)
  • Fast setup (1)
  • High quality picture (1)
  • It does what it says (1)
  • Many features (1)
See less See more
Cons
  • Difficult to use (2)
  • Inconsistent (2)
  • Did not recognize disc. o (1)
  • Does not work with any tv (1)
  • Never worked out of box (1)
  • No tuner (1)
  • Poor vcr play (1)
  • Will not record from ntsc (1)
Best Uses
  • Home (5)
  • Archiving tv shows (1)
  • Can not use (1)
  • Dvds only (1)
  • Movies (1)
  • Office (1)
  • Paper weight (1)
  • Preserve home movies (1)
  • Professional (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DVR600 Dvd Recorder & Vcr With 1080p
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 4, 2008
Toshiba DVR600 Dvd Recorder & Vcr With 1080p Reviews
Most helpful positive review
Most helpful negative review
5.0
This dvd recorder is fun to use.
"I bought this unit to preserve old vhs taped memories onto dvd. The First one turned out great and I can't wait to transfer all of my home movies to dvd. I'm still learning all of the functions, so if a slow motion reverse is available I haven't found it yet. That would help with the editing. I am having a lot of fun learning all of the functions this unit has (and there are plenty). My next task is to learn how..." Read Full Review »
Jun 04, 2008 by Roadranger
See more positive Toshiba DVR600 Dvd Recorder & Vcr With 1080p reviews
1.0
Useless piece of expensive equipment
"I've had this product for three weeks and have not yet been able to hook it up or use it. I bought it to replace an old VCR since it has both VCR and DVD Recording. However, this product does not have a tuner, meaning there is no way to connect it to the cable. The cable has to be connected to an external tuner, then the tuner connected to this unit. I called Toshiba, they do not make or sell a tuner that wi..." Read Full Review »
May 30, 2007 by Ken, retired CTO
See more negative Toshiba DVR600 Dvd Recorder & Vcr With 1080p reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Fast Recording
  • Fast Setup
  • Many features
  • Simple Controls
    Cons
  • None
    Best Uses
  • Archiving TV Shows
  • Home
  • Movies
  • Office
  • More »
"I bought this unit to preserve old vhs taped memories onto dvd. The First one turned out great and I can't wait to transfer all of my home movies to dvd. I'm still learning all of the functions, so if a slow motion reverse is available I haven't found it yet. That would help with the editing. I am h …"  Read Full Review »
Was this DVD Player review on the Toshiba helpful to you?
Jun 4 2008
Roadranger
Bloomington, IN
I am:
  • Perfectionist
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
1.0
    Pros
  • None
    Cons
  • Does not work with any TV
    Best Uses
  • None
"I've had this product for three weeks and have not yet been able to hook it up or use it. I bought it to replace an old VCR since it has both VCR and DVD Recording. However, this product does not have a tuner, meaning there is no way to connect it to the cable. The cable has to be connected to an …"  Read Full Review »
May 30 2007
Ken, retired CTO
Smyrna, TN
Problems with VCR playback
1.0
    Pros
  • Easy To Set Up
    Cons
  • Poor VCR play
    Best Uses
  • DVDs only
"I bought this player for my children and it has not worked well in playing VCR tapes. It seems to be very fussy about tapes.Some will play fine while others will not,no matter how tracking is adjusted. These same tapes will play fine in our other VCRs (Panasonics). The DVD section plays well but I p …"  Read Full Review »
Dec 27 2007
moe44
Santa Fe, NM
I am:
  • Practical
Works well, remote response slow
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"I have been using this unit to transfer VHS tapes to DVD's and so far it has worked flawlessly. The Remote is a bit slow, but for what I need it for it's fine. "
Aug 21 2007
Bob A Booey
New York
I am:
  • Tech Savvy
Reviewed at:
Did not work out of box.
1.0
    Pros
  • None
    Cons
  • Did not recognize disc. O
  • Difficult To Use
    Best Uses
  • can not use
"New unit would play tapes but dvd portion did not work. Sent to factory service center. [...] "
Jan 30 2008
ouch
san jose
I am:
  • Professional
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
BizRate Rating Outstanding 9.6
$169.95
No Tax Outside NY
$176.99
BizRate Rating Outstanding 9.4
$187.00
5% off orders at Abt.com
$199.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
