Close Login Module
Join
Toshiba DR570 DVD Recorder with Built-In Digital Tuner
#6
4.3
based on 14 reviews
Ratings Distribution
5 star
7
4 star
7
3 star
0
2 star
0
1 star
1
Category Average
3.8
$149.00 - $179.99
from 13 stores
More Images
Pros
  • Attractive design (7)
  • Fast recording (7)
  • Fast setup (6)
  • Simple controls (6)
  • Many inputs (1)
  • Uses all formats of media (1)
See less See more
Cons
  • Discs load slowly (3)
  • Manual has no index (1)
  • Remote has no vol control (1)
Best Uses
  • Archiving tv shows (5)
  • Home (5)
  • Movies (4)
  • Record erase re-record (1)
  • Sports (1)
Where to Buy
$149.00
BizRate Rating Outstanding 9.6
$156.99
No Tax Outside NY
BizRate Rating Outstanding 9.1
$158.98
Show all 13 stores
Product Reviews
Last update: Oct 27, 2009
Toshiba DR570 DVD Recorder with Built-In Digital Tuner Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
5.0
A very nice machine
"After lots of research the new DR570 seemed pretty sweet. [...] Pretty inexpensive, and easy to set up and use. And it uses all formats (+ and -) of DVD-Rs and DVD-RWs. The remote could use a volume control but thats no big deal. And when learning the machine, the manual could use an index to make finding topics easier. Overall you can't go wrong with the DR570...." Read Full Review »
Jun 13, 2009 by The RaZoR
See more positive Toshiba DR570 DVD Recorder with Built-In Digital Tuner reviews
1.0
In fairness to CompUSA, I ...
"In fairness to CompUSA, I did not buy it from them but am looking for a replacement for this model I bought elsewhere. The tuner could only pull in 3 off the air HD channels even though my TV pulls in 30 HD channels. Supplier admitted tuner is weak! Useless...." Read Full Review »
Oct 24, 2009 by rod
See more negative Toshiba DR570 DVD Recorder with Built-In Digital Tuner reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
A very nice machine
5.0
    Pros
  • Attractive Design
  • Fast Recording
  • Fast Setup
  • Simple Controls
    Cons
  • Manual has no Index
  • Remote has no Vol Control
    Best Uses
  • Archiving TV Shows
  • Home
  • Movies
  • Sports
"After lots of research the new DR570 seemed pretty sweet. [...] Pretty inexpensive, and easy to set up and use. And it uses all formats (+ and -) of DVD-Rs and DVD-RWs. The remote could use a volume control but thats no big deal. And when learning the machine, the manual could use an index to make …"  Read Full Review »
Was this DVD Recorder review on the Toshiba helpful to you?
 Report Abuse  (6)  (0)  0 comments
Jun 13 2009
The RaZoR
Jersey
I am:
  • Enthusiast
Reviewed at:
Price: $159.00
Great product. This unit ...
5.0
"Great product. This unit eliminates the need for a digial tuner box. It delivers a flawless picture and records easy. I use long play and still get a good picture on recordings upm to 4 hours. I bought memorex dvd-rw and they work great on this machine. You must finalize to play on other machines bu …"  Read Full Review »
Oct 26 2009
bob
Undisclosed
Reviewed at:
Price: $159.99
Nice alternative to Tivo
4.0
    Pros
  • Attractive Design
  • Many Inputs
    Cons
  • Discs Load Slowly
    Best Uses
  • Movies
"This DVD recorder hit it's mark. The upscaling is very nice with standard DVD's. It really does a great job of bringing new life to your standard DVD's. Just make sure you are using a HDMI cable to take advantage of this feature. Recording shows is a snap. The menu is easy to navigate. If you know h …"  Read Full Review »
Aug 24 2009
casanezo
Sumner, WA
I am:
  • Casual User
Reviewed at:
Price: $159.00
[0 of 1 customers found this review helpful]
Great Product
5.0
    Pros
  • Attractive Design
  • Fast Recording
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"It works good to record if your cable TV cord is connected to your television without a box if you connect another coaxial cable from it to the TV. I don't have a cable box for that TV but only have one for the TV in the living room. But I sometimes need to record something that is on at the same …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Sep 24 2009
dg
San Diego
I am:
  • Casual User
Reviewed at:
Price: $159.00
[1 of 1 customers found this review helpful]
So far, so good
4.0
    Pros
  • Attractive Design
  • Fast Recording
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"The DVR is easy to use and keep using. It's as good as an old-fashioned VCR was, and that's the function I want. "
 Report Abuse  (1)  (0)  0 comments
Oct 27 2009
Tech savvy
New Jersey
I am:
  • Casual User
Reviewed at:
Price: $159.00
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$149.00
$156.99
No Tax Outside NY
$158.98
$159.00
BizRate Rating Outstanding 9.4
$159.60
5% off orders at Abt.com
$159.99
$1.99 Shipping On Orders Over $100 at TigerDirect
$159.99
$1.99 Shipping on Orders Over $75
$162.99
$163.75
Overstock.com Club O Deals!
BizRate Rating Outstanding 9.3
$169.97
BizRate Rating Outstanding 9.0
$171.66
$179.99
$179.99
Out Of Stock
$169.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
