Toshiba 55" Regza Cinema Series LED Flat Panel LCD HDTV (Model #55SV670U)
#516
3.8
based on 5 reviews
Ratings Distribution
5 star
1
4 star
3
3 star
0
2 star
1
1 star
0
Category Average
4.4
$2,048.18 - $2,999.98
from 14 stores
More Images
Pros
  • Bright image (2)
  • Fast setup (2)
  • Good connection options (2)
  • High resolution (2)
  • Simple controls (2)
  • Attractive design (1)
  • Blacks are black (1)
See less See more
Best Uses
  • Home theater (2)
  • Bedroom (1)
  • Home (1)
  • Movies (1)
  • Wall mounting (1)
Provided by OneCall
New FocaLight™ LED Backlighting
If you won’t settle for anything but the deepest, most stunning picture quality, FocaLight™ LED Backlight is what you’ve been waiting for. Lesser Edge LED Systems must sacrifi ce peak white brightness to attain better blacks. However, our new FocaLight™ system utilizes a Full LED Matrix with superior Local Dimming that enables it to create Deep Blacks and Bright Whites simultaneously. Thanks to FocaLight™, our New REGZA® LCD TV attains an all-new level of picture quality with an amazing 2,000,0001 Dynamic Contrast. Once you experience the New REGZA® with FocaLight™, it will be hard to watch anything else.
New Deep Lagoon™ Design with Infi nity Flush Front™
Inspired by nature and reminiscent of sand disappearing below the surface of calm shores, the Deep Lagoon™ design adds a unique feeling of character and style to fl at panel TV. Also inspired by water and taking LCD TV design to the next level, the new Infi nity Flush Frontt™ provides a seamless front face that is similar to the surface of an infi nity pool. The combination of Deep Lagoon™ and the Infi nity Flush Frontt™ creates a stunning, elegant design for a level of stylish appeal that you must see, and will not forget.
New ClearScan 240™
If you love watching Sports or Action Movies, ClearScan 240™ will put a smile on your face. Some fl at panel TVs just can’t keep up with the action. On the other hand, REGZA® LCD TV with ClearScan 240™ will make you feel like part of the action. ClearScan 240™ combines 120 frames per second with a new advanced Backlight Scanning System to create a 240 Hz Effect. New REGZA® LCD TV with ClearScan 240™ creates such a new level of picture clarity with motion video that you won’t know whether to stay glued to your seat, or to jump from it.
New Dolby®Volume
If you have ever been bothered by loud TV commercials or inconsistent volume when changing channels, you need our new Dolby® Volume technology. Advanced algorithms monitor the audio during programs, when commercials start, and when changing channels. Louder programming is brought down, while lower programming is brought up. This ensures a consistent volume level with full dynamic range at all times.
Specification Description
Model 55SV670U
UPC 022265002582
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Card Slot Secure Digital
Component Video (2) Rear Input
Computer Display Capable Yes
Computer Interface VGA
DB15 (PC Video) (1) Rear Input
Depth (Inches) 16.22
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (3) Rear Input
HDMI 4
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Height (Inches) 35.47
Memory Card Slot SD
Optical (1) Rear Output
PC Audio (1) Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1200
S-Video (1) Rear Input
Screen Format 16:10 Widescreen TV Imaging
Screen Resolution 1920x1080
Screen Size (inches) 55
Screen Size (Inches/Diagonal) 54
Speakers Built-in
Stand Included
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Connection Yes
USB Port (1) Side Input
Wall Mountable VESA Compliant
Wall Mountable Yes
Weight (Pounds) 98.1
Width (Inches) 53.62
Toshiba 55" Regza Cinema Series LED Flat Panel LCD HDTV (Model #55SV670U) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 1, 2009
Toshiba 55" Regza Cinema Series LED Flat Panel LCD HDTV (Model #55SV670U) Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[3 of 7 customers found this review helpful]
We waited three months ...
2.0
"We waited three months for this TV, and we could not have done more research. I'll let you read my wife's email to my son.
I thought I would update you on our long journey of purchasing a TV. Much to our surprise the new Toshiba was finally released this week, and were available at Best Buy. Of cou …"  Read Full Review »
Was this LCD TV review on the Toshiba 55" Regza Cinema Series LED Flat Panel LCD HDTV (Model #55SV670U) helpful to you?
 Report Abuse  (3)  (4)  0 comments
Aug 5 2009
ETJCali
Undisclosed
Reviewed at:
Price: $2,999.98
BEST TV OUT 4 THE $ !!!
4.0
    Pros
  • Attractive Design
  • Blacks are Black
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
"No what you are buying be for you buy it. If you have a problem with glare keep it away from lights! "
Oct 5 2009
Fu
Atlantic City , NJ
I am:
  • Enthusiast
Reviewed at:
Price: $2,248.98
Great value in this TV!
4.0
"Compared this TV to a Samsung LED UN6000. Samsung was only better in 2 things...the accuracy of the color green and performance in 24 fps. The Toshiba however has better contrast and deeper blacks. I paid $1000 less for the Toshiba. After the research and at that price difference.....I had to go wit …"  Read Full Review »
Oct 12 2009
Scrawny
San Antonio
Reviewed at:
Price: $2,999.98
Toshiba CINEMA REGZA / 55 " LED Wow!
5.0
"Check the features, the rich colors, automatic light sensor, PC input, more. If you look at what this LED offers, and see it in the store, you will be impressed. Toshiba has really produced a cutting edge TV for a great price. Check it against the others and dollar for dollar, it beats them all.
Lov …"  Read Full Review »
Aug 21 2009
khill1234
Ocean City, NJ
Reviewed at:
Price: $2,999.98
[1 of 1 customers found this review helpful]
REGZA 55SV670U 55" LCD TV by Toshiba
4.0
    Pros
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Bedroom
  • Home Theater
  • Wall Mounting
"No comment "
 Report Abuse  (1)  (0)  0 comments
Nov 1 2009
radx
Pa
I am:
  • Casual User
Reviewed at:
Price: $2,048.18
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
