Toshiba 500GB Portable Hard Drive
#22
4.7
based on 41 reviews
Ratings Distribution
5 star
29
4 star
11
3 star
1
2 star
0
1 star
0
Category Average
4.1
Low Price:
$109.99 at CompUSA
 Trusted:
$109.99 at TigerDirect
Find it at Amazon
$109.99 - $149.99
from 5 stores
More Images
Pros
  • Quiet (7)
  • Attractive design (6)
  • Easy to use (6)
  • Large capacity / good size (6)
  • Easy setup (5)
  • Compact (3)
  • Portable (3)
  • Easy to install (1)
  • Fast (1)
  • Highly compatible (1)
See less See more
Cons
  • No on/off switch (2)
Best Uses
  • Back-up (6)
  • Additional storage (5)
  • Photo storage (5)
  • Video (5)
  • File transfer (3)
Provided by Meijer.com
Sleek and stylish, the Toshiba 500GB USB 2.0 Portable External Hard Drive captures the essence of today's fast paced digital lifestyle. It is the must-have accessory for a new mobile generation of consumers who take their digital work and entertainment wherever they go. And Toshiba lets them do just that.
With 500GB, take thousands of songs, pictures, movies, and work files on the road quickly, easily, and securely. A Toshiba external hard drive is a hassle-free, simple and easy solution to all your backup needs. Take the mystery out of backing up your most precious digital memories with Toshiba's reliable hard drive technology and easy-to-use backup software.
USB powered, it includes an internal shock sensor and ramp loading technology to help keep your drive safe and your data mobile. Ready to go out of the box, it is certified to work with Windows XP and Vista as well as Mac OS 10.3.9 or later.
Specification Description
Model 500GB, 72E6AC60, HDDR500E03X
UPC 883974113330
Accessory Indicator Yes
Benefits NTI Shadow backup automatically backs up your important files, photos and musicCompatible with both Macs and PCs, it's USB powered an
Cables Included USB cable
Capacity UOM mAh
Connections USB
Country Of Origin China
Description Header You can take it with you.
Display Catalog Number 55033495
Enclosure Color Black/Silver
Included in the Box Toshiba Portable External Drive (preloaded with NTI Shadow Backup Software)USB 2.0 CableQuck Install Guide
Manufacturer Labor Warranty 3
Manufacturer Part Number HDDR500E03X
Manufacturer Parts Warranty 3
MAP Price 0.0
Model 500GB
Operating Temperature UOM ° F
Product Depth 5
Product Dimensions UOM inches
Product Height 0.63
Product Type External
Product Weight 6
Product Weight UOM ounces
Product Width 3.5
Required to function Microsoft Windows® XP or Vista®; Mac® OS X 10.3.9 or laterAvailable USB 2.0 port
Supported Languages English
Toshiba 500GB Portable Hard Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 11, 2009
Toshiba 500GB Portable Hard Drive Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Excellent Drive
"I used it to shadow backup my entire C:\ drive then selected my precious Photos, MP3's & other Graphics files to safely store offsite easily and quickly. Runs VERY cool and surprisingly fast for a drive with no external power source. Don't forget to format as NTFS as it comes FAT32 - that 5Gb file will fail if you don't!..." Read Full Review »
Mar 03, 2009 by Rocketman
See more positive Toshiba 500GB Portable Hard Drive reviews
3.0
the 320 gig version has ...
"the 320 gig version has worked fine for me for several months, so i bought a 500 as grad gift. never use the back up software, tho, caveat emptor. HD seems faster to transfer than my old desktop HD. and they 've been humming away in all those laptops all this time, so... so wish we knew what the life expectancy of these things is and how long can they be stored with out running without seizing up?..." Read Full Review »
Jun 16, 2009 by plumtukrd
See more negative Toshiba 500GB Portable Hard Drive reviews
Displaying 1 - 5 of 41 Reviews
Show
Sort by
Excellent Drive
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • None
Don't forget to format as NTFS as it comes FAT32 - that 5Gb file …"  Read Full Review »
Was this External Computer Hard Drive review on the Toshiba 500GB Portable Hard Drive helpful to you?
 Report Abuse  (2)  (0)  0 comments
Mar 3 2009
Rocketman
Toronto, Ontario, Canada
I am:
  • Heavy Duty User
Reviewed at:
[8 of 10 customers found this review helpful]
largest external hard drive
5.0
"this is fantastic, toshiba is bringing the world to our homes now. i can now store so many songs,pictures,movies etc without complaining that my hard drive is full pls get it. "
 Report Abuse  (8)  (2)  0 comments
Jan 3 2009
Saint
Lagos,Nigeria
Reviewed at:
Great product and easy to use.
5.0
    Pros
  • Attractive Design
  • Easy To Setup
  • Easy to use
  • High Capacity
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Additional Storage
  • Backup
  • Photo Storage
  • Video
"This external Hard Drive is slim in size and lightweight.Plug N Play with simple backup functions.Perfect for Laptop case.I would recommend this for anyone that does not want to lose pics or important documents. "
Jul 29 2009
Sportytom
Brandon, Florida
I am:
  • Casual user
Reviewed at:
As good as my other toshiba drive
5.0
"I have another 2 Toshiba hard drives of 400 GB.... this one is the same size as those and also the same good quality. I got really impressed with toshiba hard drives since I bought my first 250 GB hard drive over a year ago.
Bought this a few days ago and its really good, its fast, easy to install, …"  Read Full Review »
Mar 7 2009
MACS
Florida
Reviewed at:
Stylist pocket HDD
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy to use
  • High Capacity
  • Quiet
    Cons
  • No Power Switch
    Best Uses
  • Backup
  • Video
"This stylist pocket HDD is easy to carry and too portable. Has a good glossy finish and looks better than my old buffalo HDD. I prefer toshiba products and hence i vote for this HDD. "
Aug 10 2009
Murali
Montebello, CA
I am:
  • Power user
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
