Toshiba 47ZV650U 47-inch REGZA 1080p LCD HDTV
#168
4.5
based on 23 reviews
Ratings Distribution
5 star
19
4 star
0
3 star
1
2 star
2
1 star
1
Category Average
4.4
Low Price:
$1,108.99 at Newegg
 Trusted:
$1,199.95 at B&H Photo Video
Find it at Amazon
$1,108.99 - $1,499.99
from 16 stores
More Images
Pros
  • Attractive design (3)
  • Bright image (3)
  • Good connection options (3)
  • High resolution (3)
  • Fast setup (1)
  • Reduced glare (1)
  • Simple controls (1)
See less See more
Cons
  • Difficult to set up (1)
Best Uses
  • Home theater (3)
  • Movies (3)
  • Home (2)
  • Bedroom (1)
  • Wall mounting (1)
Provided by OneCall
New ClearScan 240™
If you love watching Sports or Action Movies, ClearScan 240™ will put a smile on your face. Some fl at panel TVs just can’t keep up with the action. On the other hand, REGZA® LCD TV with ClearScan 240™ will make you feel like part of the action. ClearScan 240™ combines 120 frames per second with a new advanced Backlight Scanning System to create a 240 Hz Effect. New REGZA® LCD TV with ClearScan 240™ creates such a new level of picture clarity with motion video that you won’t know whether to stay glued to your seat, or to jump from it.
New CrystalCoat™
You may watch TV at night in a dark room, but sometimes you may keep the lights on and have a bright room, or watch the game on Sunday afternoon with even brighter sunlight coming through the windows. Extra room light can lower the contrast on some TVs, but with CrystalCoat™, you don’t have to worry. CrystalCoat™ stops ambient room light refl ections from washing out the picture, creating up to 30% better contrast in bright rooms. Now you can enjoy the deep high contrast REGZA® picture in all room light conditions.
New Dolby® Volume
If you have ever been bothered by loud TV commercials or inconsistent volume when changing channels, Dolby® Volume technology is the solution. Advanced algorithms monitor the audio during programs, when commercials start, and when changing channels. Louder programming is brought down, while lower programming is brought up. This ensures a consistent volume level with full dynamic range at all times.
New USB Port and SD Card Slot
Thanks to our new USB Port, you can now watch your movies or videos, view your digital pictures, or even listen to your digital music, by just connecting a USB hard drive or fl ash drive to the USB Port on the TV. If your digital camera uses an SD memory card, you can even view your digital pictures by just taking the card from the camera and placing it in the TV’s SD Card Slot. Enjoying your multi-media content has never been easier, or more fun.
Specification Description
Model 47ZV650U, TOS 47ZV650U, TOS47ZV650
UPC 022265002551
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Card Slot Secure Digital
color null
Component Video (2) Rear Input
Contrast Ratio 100000:1
DB15 (PC Video) Rear Input
Depth (Inches) 12.95
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 31.18
Optical Rear Output
PC Audio Rear Input
Ports 2 x Component Video In
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1920 x 1080
S-Video (1) Rear Input
Screen Size 47"
Screen Size (inches) 47
size null
sku 155538
skuprice 1449.9900
Speakers Built-in
Stand Included
style TOS47ZV650
taxable Y
Technology HDTV
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Side Input
Wall Mountable Yes
Weight (Pounds) 57.2
Width (Inches) 46.30
Toshiba 47ZV650U 47-inch REGZA 1080p LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 13, 2009
Toshiba 47ZV650U 47-inch REGZA 1080p LCD HDTV Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Leapfrogs to new PQ Levels
"I'm posting this based upon in-store reviewing and having been a member of AVS forum 4.5 yrs - this is my Hobby. PQ --- Outstanding and this is a new level for Toshiba - If you were to mask the bezel nameplate you'd swear you were looking at a Samsung B650 or better. Excellent Black Levels = Haze removal LCD's are known for in the past and eye popping colors and they've rid the panel of a problem they had in pa..." Read Full Review »
Apr 25, 2009 by HDTVOCD
See more positive Toshiba 47ZV650U 47-inch REGZA 1080p LCD HDTV reviews
2.0
Great Vaue.....Great Pictue....But....
"What's Great: Pricing, at $1500-$1700 it's tough to find anything with this TV's features, Picture quality etc. Color accuracy is spot on for the most part. Build Quality is seemingle good albeit very "light" in weight. Nice remote control, plenty of connections including 4 HDMI & an SD card slot! Faste input switching is a nice touch on this as well. What's not so great: Mediocre at best Blacks when sitting de..." Read Full Review »
May 23, 2009 by BTBuck1
See more negative Toshiba 47ZV650U 47-inch REGZA 1080p LCD HDTV reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Connection Options
  • Good Resolution
    Cons
  • None
    Best Uses
  • Bedroom
  • Home Theater
  • Movies
PQ --- Outstanding and this is a new level for Toshiba - If you were to mask the bezel nameplate you'd swear you were looking at a Samsung B650 or better. Excellent Black Levels = Haze …"  Read Full Review »
Was this LCD TV review on the Toshiba 47ZV650U 47-inch REGZA 1080p LCD HDTV helpful to you?
 Report Abuse  (2)  (0)  0 comments
Apr 25 2009
HDTVOCD
Shelby Twp, MI
I am:
  • Power User
Reviewed at:
Price: $1,229.98
Awesome Picture, Great Value
5.0
"I initially bought the Toshiba Regza 46XV645U, but the speakers made a rattling sound when the volume was over 30, so I returned it. I was so impressed by the picture quality that I decided to stay with Toshiba and spent a little extra to get the 47ZV650U. I've had the TV for 2 weeks now, and I've b …"  Read Full Review »
Sep 22 2009
Frank78
Durham, NC
2.0
"What's Great:
Pricing, at $1500-$1700 it's tough to find anything with this TV's features, Picture quality etc. Color accuracy is spot on for the most part. Build Quality is seemingle good albeit very "light" in weight. Nice remote control, plenty of connections including 4 HDMI & an SD card slot! F …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
May 23 2009
BTBuck1
Vista
[1 of 1 customers found this review helpful]
Fantastic TV
5.0
"First Impressions:
Toshiba's first step into the 2009 market is the 47ZV650U. This 47" HDTV boasts some pretty impressive specs, but let's talk about the look. Toshiba and the ZV650 series take a step away from the bland LCD Bezel standards, and join the aesthetically bold bezels of Samsung and Sha …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 10 2009
Cellis
Chicago, IL
One Very Good TV
5.0
"Went to Best Buy for a particular Samsung, after a year researching HDTVs, but it was out of stock - thankfully. Saw this one, hooked by the "240", went home and looked into it; had a Toshiba 35" stereo CRT for years, nice set. Wound up at a big local competitor because of price - Nebraska Furniture …"  Read Full Review »
May 19 2009
hoot1911A1
Omaha, NE
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
