Toshiba 42RV535U 42-inch Regza 1080p HD LCD TV
#287
4.7
based on 33 reviews
Ratings Distribution
5 star
24
4 star
8
3 star
1
2 star
0
1 star
0
Category Average
4.4
$1,009.00 at Rainbow Appliance
Find it at Amazon
Find it at Ebay
$1,009.00
from 1 store
More Images
Pros
  • Fast setup (13)
  • Good connection options (12)
  • High resolution (11)
  • Attractive design (10)
  • Bright image (9)
  • Simple controls (9)
  • Reduced glare (6)
  • Clear instructions (1)
  • Ps3 ready (1)
See less See more
Cons
  • Poor sound quality (2)
  • No dislikes with this tv (1)
Best Uses
  • Home (12)
  • Movies (8)
  • Home theater (5)
  • Wall mounting (4)
  • Bedroom (3)
  • Video (1)
Provided by photoalley.com
The REGZA 42RV535U combines 1080p Full HD resolution with new SRT1Super Resolution Technology to ensure that everything you watch feels like HD. This series also features the PixelPure 4G 14-bit internal digital video processor for superior power, and the new AutoView feature that simplify its operation by controlling picture settings for you. All of this technology is housed in our new Double Skin cabinetry that will complement virtually any room in your home. When settling for less than excellent quality is not an option, the 42RV535U delivers.
SRT1 Super Resolution Technology upconverts and enhances 480i/p and 720p input signals for a more detailed picture. Now all your DVDs and TV channels will be displayed in near High Defi nition picture quality. AutoView uses an external light sensor to automatically adjust various picture quality settings based on the amount of ambient room lighting and the type of video content you are watching for an improved viewing experience. AutoView monitors and adjusts brightness, sharpness, contrast, color, and SRT1 settings to improve picture quality.
DynaLight Backlight Control utilizes advanced image processing to monitor the brightness of each video frame, and adjust the backlight intensity accordingly. This precision creates seamless transitions with deep blacks for increased detail and depth analysis. PixelPure 4G takes advantage of the 14-bit internal digital video processor to reach 4,096 levels of gradation, producing a smooth and natural picture. Gaming Mode enhances the gaming experience by reducing the amount of time it takes for the signal to travel from the game controller to the TV.
  • 1080p Full HD CineSpeed Display
  • SRT1 Super Resolution Technology Upconverts and Enhances 480i/p and 720p Input Signals
  • AutoView Automatically Adjusts Picture Settings Based on Ambient Room Light
  • PixelPure 4G 14-Bit Internal Digital Video Processing and 10-Bit Panel for a More Natural Picture
  • DynaLight Dynamic Backlight Control for Deep Black Levels
  • ATSC / QAM Digital Tuner for Over-the-Air and Cable-in-the-Clear Digital Tuning
  • 4 HDMI Digital Inputs (1 Side)
  • New Double Skin Thin-Line Bezel with a High-Gloss Black Cabinet
  • Specification Description
    Model 42RV535U
    UPC 022265001738
    Analog Audio (1) Rear Output
    Analog Audio (1) Side Input
    Analog Audio (3) Rear Input
    Analog Audio / Video Rear Input
    Analog Audio / Video Side Input
    Aspect Ratio 16:9
    Color Glossy Black Cabinet
    Component Video (2) Rear Input
    Contrast Ratio 20000:1
    DB15 (PC Video) Rear Input
    Depth (Inches) 12.1
    HDMI (1) Side Input
    HDMI (3) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Capable HD Tuner is included
    HDTV Native Resolution 1080p
    Height (Inches) 27.3
    Optical Rear Output
    PC Audio Rear Input
    Ports 1 x S-Video In Rear
    Refresh Frequency 60 Hz
    Remote Control Included
    Resolution 1920 x 1080
    S-Video Rear Input
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size 42"
    Screen Size (inches) 42
    Screen Size (Inches/Diagonal) 42
    Speakers Built-in
    Technology HDTV
    Weight (Pounds) 55.1
    Width (Inches) 39.8
    Toshiba 42RV535U 42-inch Regza 1080p HD LCD TV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Mar 17, 2009
    Toshiba 42RV535U 42-inch Regza 1080p HD LCD TV Reviews
    Most helpful positive review
    [2 of 2 customers found this review helpful]
    Most helpful negative review
    4.0
    Everything I needed...
    "This turned out exactly as I wanted it to. Great picture, great options on the LCD, no artifacts in picture, and amazing price to boot. I'm glad I got this set...." Read Full Review »
    Jan 06, 2009 by Mike the bargain hunter
    See more positive Toshiba 42RV535U 42-inch Regza 1080p HD LCD TV reviews
    3.0
    Great fo rthe Price
    "Great for the price I paid few things missing like PIP and Great sound..." Read Full Review »
    Mar 03, 2009 by Legend
    See more negative Toshiba 42RV535U 42-inch Regza 1080p HD LCD TV reviews
    Displaying 1 - 5 of 33 Reviews
    Show
    Sort by
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Wall Mounting
    "This turned out exactly as I wanted it to. Great picture, great options on the LCD, no artifacts in picture, and amazing price to boot. I'm glad I got this set. "
    Was this LCD TV review on the Toshiba 42RV535U 42-inch Regza 1080p HD LCD TV helpful to you?
     Report Abuse  (2)  (0)  0 comments
    Jan 6 2009
    San Antonio, TX
    I am:
    • Casual User
    Reviewed at:
    Just what I needed
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Good Resolution
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "I use this TV for movie and television watching and video games. The picture quality is superb (even moreso with Blue-Ray!) although standard definition programs are grainy at times. Has four HDMI inputs, which is great, and they're easily accessible. Remote control is good, although I haven't been …"  Read Full Review »
    Feb 27 2009
    DonnyB
    Chicago, IL
    I am:
    • Enthusiast
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Great Buy
    4.0
      Pros
    • Bright Image
    • Fast Setup
    • Good Resolution
    • Reduced Glare
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Video
    "This is a great buy for a feature packed television from a reputable manufacturer. The only drawback is the piano black finish. Just make sure you have a microfiber cloth on hand to wipe the casing of the tv. Using something other than that may leave surface scratches. Overall a very fine set, e …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Nov 26 2008
    JWW
    Southern California
    I am:
    • Casual User
    Reviewed at:
    Best 42" 1080p In price range
    5.0
    "The Toshiba 42RV530U 42" LCD is my second HD TV. It replaced a four year old Panasonic 37" Plasma that had just gotten too old and was only 720p. Making the upgrade to this beautiful TV was amazing! The picture is clear, sharp, and mostly accurately colored. 4 HDMI inputs is very useful since I have …"  Read Full Review »
    Nov 8 2008
    GreatAchilles
    Undisclosed
    Reviewed at:
    [3 of 3 customers found this review helpful]
    one heck of a tv for the price
    5.0
    "my gramdma recently bought this television and i'm only in high school and i had it set up and running in less than five minuets. it worked very well with her new surround sound system, her dvd player and satellite reciever. this tv is simple and has a wide range of settings to fit your exact style. "
     Report Abuse  (3)  (0)  0 comments
    Sep 29 2008
    TheGenius
    Haubstadt, IN
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
