Toshiba 42" Regza Cinema Series Flat Panel LCD HDTV - 42XV545U
4.4
based on 8 reviews
from
Ratings Distribution
5 star
4
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Good connection options (7)
  • High resolution (7)
  • Fast setup (6)
  • Great picture quality (6)
  • Simple controls (6)
  • Attractive design (5)
  • Wide viewing angle (5)
See less See more
Cons
  • Bad interface (1)
  • Poor connection options (1)
  • Remote could be better (1)
Best Uses
  • Home (6)
  • Home theater (4)
  • Movies (4)
  • Bedroom (2)
  • Wall mounting (2)
  • Sports (1)
Provided by CameraWorld.com
Only our best get to be called Cinema Series , and the 42XV545U certainly makes the grade. This premium LCD TV series features our longest list of picture quality technology enhancements yet, including SRT, AutoView, ClearFrame, ColorBurst, PixelPure 4G, DynaLight, and more. If you are looking for an amazing picture , you owe it to yourself to view our 42XV545U.
SRT1 Super Resolution Technology upconverts and enhances 480i/p and 720p input signals for a more detailed picture. Now all your DVDs and TV channels will be displayed in near High Defi nition picture quality. AutoView uses an external light sensor to automatically adjust various picture quality settings based on the amount of ambient room lighting and the type of video content you are watching for an improved viewing experience. AutoView monitors and adjusts brightness, sharpness, contrast, color, and SRT settings to improve picture quality.
ClearFrame 120Hz Anti-Blur Technology -- This advanced system virtually eliminates motion blur without decreasing image brightness, or adding flicker. Images are now crisp and clear regardless of image motion. ClearFrame doubles the displayed frame rate to 120 frames per second or 120Hz. ClearFrame utilizes superior Motion Vector Frame Interpolation (MVFI) technology. Utilizing the power of the PixelPure processor, MVFI creates new frames, inserting them between the original frames. PixelPure 4G takes advantage of both the 14-bit internal digital video processor and the 10-bit display panel to reach 16,384 levels of gradation, producing a smooth and natural picture.
  • 1080p Full HD CineSpeed Display
  • SRT1 Super Resolution Technology Upconverts and Enhances 480i/p and 720p Input Signals
  • AutoView Automatically Adjusts Picture Settings Based on Ambient Room Light
  • ClearFrame 120Hz Frame Rate with 5:5 Pull-Down Option
  • ColorBurst Wide Color Gamut CCFL for Rich Colors
  • PixelPure 4G 14-Bit Internal Digital Video Processing and 10-Bit Panel for our Most Natural Picture
  • DynaLight Dynamic Backlight Control for Deep Black Levels
  • ATSC / QAM Digital Tuner for Over-the-Air and Cable-in-the-Clear Digital Tuning
  • 4 HDMI Digital Inputs (1 Side)
  • New Double Skin Thin-Line Bezel with a High-Gloss Black Cabinet
  • Specification Description
    Model 42XV545U
    UPC 022265001745
    Analog Audio (1) Rear Output
    Analog Audio (1) Side Input
    Analog Audio (3) Rear Input
    Analog Audio / Video Rear Input
    Analog Audio / Video Side Input
    Aspect Ratio 16:9
    Color Glossy Black Cabinet
    Component Video (2) Rear Input
    DB15 (PC Video) Rear Input
    Depth (Inches) 12.1
    HDMI (1) Side Input
    HDMI (3) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Capable HD Tuner is included
    HDTV Native Resolution 1080p
    Height (Inches) 27.3
    Optical Rear Output
    PC Audio Rear Input
    Ports 1 x S-Video In Rear
    Refresh Frequency 120 Hz
    Remote Control Included
    Resolution 1920 x 1080
    S-Video Rear Input
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size 42"
    Screen Size (inches) 42
    Screen Size (Inches/Diagonal) 42
    Speakers Built-in
    Stand Included
    Technology HDTV
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    Wall Mountable Yes
    Weight (Pounds) 54
    Width (Inches) 39.8
    Toshiba 42" Regza Cinema Series Flat Panel LCD HDTV - 42XV545U Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 42" Regza Cinema Series Flat Panel LCD HDTV - 42XV545U
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Apr 1, 2009
    Toshiba 42" Regza Cinema Series Flat Panel LCD HDTV - 42XV545U Reviews
    Displaying 1 - 5 of 8 Reviews
    Show
    Sort by
    [2 of 2 customers found this review helpful]
    Excellent LCD
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Bedroom
    • Home
    • Home Theater
    • Movies
    • Wall Mounting
    "If you want a TV that is as good or better than the Samsung's, try this new Toshiba. Excellent picture. Great sound. My only complaint would be the PC interface does not support 1920 x 1080. But, I bought this for a TV and not a computer monitor. If you just want an awesome picture and sound, y …"  Read Full Review »
    Was this LCD TV review on the Toshiba 42" Regza Cinema Series Flat Panel LCD HDTV - 42XV545U helpful to you?
     Report Abuse  (2)  (0)  0 comments
    Dec 29 2008
    G. HDTV
    Kentucky
    I am:
    • Power User
    Reviewed at:
    Very Nice
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • Bad Interface
      Best Uses
    • Home
    • Home Theater
    • Movies
    • Wall Mounting
    "Great TV. Perfect side for the basement Home Theater. Just got a Blu-ray player. Looks incredible. All at 1/10th of the proce of our first plasma just 4.5 years ago.
    The "bad interface" comment is simply due to the fact that the physical contriols are on the side of the TV and really hard to …"  Read Full Review »
    Mar 9 2009
    JAK
    East Amherst, NY
    I am:
    • Enthusiast
    Reviewed at:
    Very pleased with product [...]
    4.0
      Pros
    • Bright Image
    • Fast Setup
    • Good Resolution
    • Reduced Glare
      Cons
      Best Uses
    • Home
    • Movies
    • Sports
    "First time purchasing a product of this size and cost online so, I was very concerned! [...]The Toshiba arrived intact and ready to go! I cannot say enough about the TV, the remote can be tricky but I knew that from researching Toshiba. I definately would recommend the Toshiba 42xv545u and I wouldn' …"  Read Full Review »
    Mar 2 2009
    BB
    Boston area
    I am:
    • Power User
    Reviewed at:
    Awesome picture with great angle viewing
    5.0
      Pros
    • Bright Image
    • Fast Setup
    • Good Resolution
    • Reduced Glare
    • More »
      Cons
    • None
      Best Uses
    • Home
    "This was a recommended 42" LCD from Consumer Reports and it is all that they said it was. The resolution, contrast, color (with adjustment) and viewing angle are great. "
    Dec 30 2008
    Duck
    Schererville, IN
    I am:
    • Casual User
    Reviewed at:
    Excellent deal!
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    "We compared features and price on several LCDs (there are a limited number of 42 inch screens) and found this Toshiba model to be best deal. "
    Feb 10 2009
    Aim high
    East Bay, CA
    I am:
    • Casual User
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
