Toshiba 40XV648U 40-inch REGZA 120Hz 1080p LCD HDTV
#521
4.0
based on 3 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.4
$839.00 - $899.97
from 4 stores
More Images
Pros
  • Attractive design (3)
  • Fast setup (3)
  • Good connection options (3)
  • Great picture quality (3)
  • High resolution (3)
  • Simple controls (3)
  • Wide viewing angle (2)
See less See more
Cons
  • Poor sound quality (1)
  • Speakercabinet vibration (1)
Best Uses
  • Home (3)
  • Bedroom (2)
  • Wall mounting (2)
  • Home theater (1)
  • Movies (1)
Provided by OneCall
New CrystalCoat™
You may watch TV at night in a dark room, but sometimes you may keep the lights on and have a bright room, or watch the game on Sunday afternoon with even brighter sunlight coming through the windows. Extra room light can lower the contrast on some TVs, but with CrystalCoat™, you don’t have to worry. CrystalCoat™ stops ambient room light refl ections from washing out the picture, creating 30%+ better contrast in bright rooms3. Now you can enjoy the deep high contrast REGZA® picture in all room light conditions.
New Dolby® Volume
If you have ever been bothered by loud TV commercials or inconsistent volume when changing channels, Dolby® Volume technology is the solution. Advanced algorithms monitor the audio during programs, when commercials start, and when changing channels. Louder programming is brought down, while lower programming is brought up. This ensures a consistent volume level with full dynamic range at all times.
ClearFrame™ 120Hz
Doubles the video frames from 60 per second to 120 per second to reduce any motion blur that could be caused by fast action video. By using advanced motion vector frame interpolation, it improves picture clarity without affecting picture brightness or adding fl icker. For those that prefer a more fi lm-like picture, there is also a 55 Pull-Down option available.
Resolution+™
Some video content is in high definition (HD), but some is still in standard definition (SD). However, REGZA® virtually levels the content playing field with Resolution+™. Resolution+™ is super resolution technology that upconverts and enhances 480i, 480p, and even 720p content to create a sharper, more detailed picture. With REGZA® and Resolution+™ all of your standard DVDs, SD TV channels, camcorder videos, and even SD video games will feel like HD.
Specification Description
Model 40XV648U
UPC 022265002865
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video (1) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Component Video (2) Rear Input
DB15 (PC Video) (1) Rear Input
Depth (Inches) 10.35
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Height (Inches) 26.10
Optical (1) Rear Output
PC Audio (1) Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
Screen Size (inches) 40
Speakers Built-in
Tuner ATSC
Tuner NTSC
Tuner QAM
Wall Mountable VESA Compliant
Weight (Pounds) 41.9
Width (Inches) 38.43
Toshiba 40XV648U 40-inch REGZA 120Hz 1080p LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
Toshiba 40XV648U 40-inch REGZA 120Hz 1080p LCD HDTV Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Great product so far!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Wall Mounting
"I got the 40" for bedroom use and it looks great. Both the anti-glare & auto contrast features seem to work pretty well. Picture is actually better than my 61" DLP because of the lack of pixelation on sports.
I'll give an update after a few months. "
Was this LCD TV review on the Toshiba 40XV648U 40-inch REGZA 120Hz 1080p LCD HDTV helpful to you?
Nov 10 2009
Golfin' Guy
Orlando, FL
I am:
  • Enthusiast
Reviewed at:
Price: $859.44
Speaker Problem
3.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Home
"I purchased 2 tv's both same model and both have right speaker has vibration at certain frequencies, usually lower tones or voices, which may cause the tv cabinet to vibrate. service tech came out and replaced the speakers in both tv's but it did not fix the problem. "
Oct 24 2009
Gerry
South Gate, Ca
I am:
  • Casual User
Reviewed at:
Price: $859.44
Very nice TV
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"I use the product at a business, it is a great TV with very good resolution and dark colors, especially for the price. I also have a Samsung 850 which has a bit better picture quality, but of course it is more expensive. "
Oct 26 2009
Paokakis
Dallas, TX
I am:
  • Power User
Reviewed at:
Price: $859.44
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
