Toshiba 37AV502U 37-inch LCD TV
4.3
based on 69 reviews
Ratings Distribution
5 star
42
4 star
16
3 star
6
2 star
3
1 star
2
Category Average
4.4
More Images
Pros
  • Attractive design (5)
  • Fast setup (5)
  • Good connection options (5)
  • Great picture quality (5)
  • High resolution (5)
  • Wide viewing angle (5)
  • Simple controls (4)
See less See more
Best Uses
  • Home (4)
  • Bedroom (1)
  • Home theater (1)
  • Movies (1)
  • Wall mounting (1)
Provided by WolfCamera.com
The 37AV502U combines quality, style, and value. It features DynaLight for a deeper picture, Native Mode and Gaming Mode for a better gaming experience, 2 HDMI digital inputs for improved connectivity, and ENERGY STAR compliance. All of this comes in a new thinner high-gloss black cabinet that will blend into any room.
DynaLight Backlight Control utilizes advanced image processing to monitor the brightness of each video frame, and adjust the backlight intensity accordingly. This precision creates seamless transitions with deep blacks for increased detail and depth analysis. CineSpeed LCD panels have the 8ms or faster response speed necessary for cleaner high-action home theater images. A wide viewing angle ensures that you?ll have the best seat in the house. Gaming Mode enhances the gaming experience by reducing the amount of time it takes for the signal to travel from the game controller to the TV.
  • 720p HD CineSpeed Display
  • DynaLight Dynamic Backlight Control for Deep Black Levels
  • Native Mode Eliminates Unnecessary Over-Scanning and Restores Picture Size
  • Gaming Mode for Fast Game Controller Response
  • ATSC / QAM Digital Tuner for Over-the-Air and Cable-in-the-Clear Digital Tuning
  • 2 HDMI Digital Inputs
  • PC Input (15 Pin, D-sub)
  • New High-Gloss Black Cabinet
  • Specification Description
    Model 37AV502U, TOS37AV502
    UPC 022265001714
    Analog Audio (1) Rear Output
    Analog Audio (1) Side Input
    Analog Audio (3) Rear Input
    Analog Audio / Video Rear Input
    Analog Audio / Video Side Input
    Aspect Ratio 16:9
    color null
    Component Video (2) Rear Input
    DB15 (PC Video) Rear Input
    Depth (Inches) 10.9
    Energy Star Compliant Yes
    HDMI (2) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Capable HD Tuner is included
    HDTV Native Resolution 720p
    Height (Inches) 25.6
    Optical Rear Output
    PC Audio Rear Input
    Refresh Frequency 60 Hz
    Remote Control Included
    S-Video Rear Input
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size (inches) 37
    Screen Size (Inches/Diagonal) 37
    size null
    sku 155534
    skuprice 699.9900
    Speakers Built-in
    Stand Included
    style TOS37AV502
    taxable Y
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    Wall Mountable VESA Compliant
    Weight (Pounds) 39.7
    Width (Inches) 36.3
    Toshiba 37AV502U 37-inch LCD TV Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 37AV502U 37-inch LCD TV
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Aug 6, 2009
    Toshiba 37AV502U 37-inch LCD TV Reviews
    Most helpful positive review
    [1 of 1 customers found this review helpful]
    Most helpful negative review
    4.0
    great value
    "The first set had a small flaw in one pixel. The ABT guys spotted it before I did. They brought a new one the next day. The color, sound, and overall quality are great. I would recommend this set for a smaller living space. You should use the HDMI cable for the hook up to really maximize the digital effect. The TV design has a nice clean look to it and even thought bigger than my tube TV, it fits into the de..." Read Full Review »
    Feb 03, 2009 by Claire
    See more positive Toshiba 37AV502U 37-inch LCD TV reviews
    2.0
    Nice but I returned it
    "I have been going through the process of upgrading to an HDTV now for two years. I've looked at reviews, put money aside, and scratched my head, wondering when prices would come down enough for me to splurge. On a whim, I bought this Toshiba which was on sale for $629, based on the reviews and the fact that I really wanted a new TV. I read about the buzzing thing but ignored it, thinking making it was the stand ..." Read Full Review »
    Jan 11, 2009 by radiotony
    See more negative Toshiba 37AV502U 37-inch LCD TV reviews
    Displaying 1 - 5 of 69 Reviews
    Show
    Sort by
    great value
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    The color, sound, and overall quality are great. I would recommend this set for a smaller living space. You should use the HDMI cable for the hook up to really maximize the digi …"  Read Full Review »
    Was this LCD TV review on the Toshiba 37AV502U 37-inch LCD TV helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Feb 3 2009
    Claire
    Chicago
    I am:
    • Casual User
    Reviewed at:
    Very Happy So Far
    4.0
    "I bought the tv yesterday and am very happy so far for the $699 it cost.
    PICTURE:
    -Decent HD picture. Not the best, but good enough so that you'll be satisfied. I noticed the resolution was lower than most all other 37 inchers though.
    -To me 37 inches is too big for non HD channels on an LCD tv. I …"  Read Full Review »
    Jan 30 2009
    Waltham, MA
    Reviewed at:
    Very Happy So Far
    4.0
    PICTURE:
    Jan 30 2009
    Waltham, MA
    Reviewed at:
    good deal
    4.0
    "When my Sony 36 inch hdtv tube screen stopped the other day I started looking for a cheap replacement. This tv is will be used in bright living room for mostly broadcast tv and some hbo/on demand. I have a large sreen in a different room for movies/sports, etc. I looked at the 42 inch plasma panason …"  Read Full Review »
    Jul 16 2009
    wood1001
    pittsburgh
    Reviewed at:
    Solid Choice
    4.0
    "This TV was purchased for use in a master bedroom and is the ideal size for our application. It was on display right beneath a larger Toshiba 1080p LCD sharing a blu-ray player for input. HDMI going to the 1080P and component going to this 720P TV. I saw virtually no difference in picture quality an …"  Read Full Review »
    Apr 19 2009
    South Carolina
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
