Provided by Beach Audio
This item can not be returned to Beach Audio. Deffective items to be covered by manufacturer's warranty
37in. Diagonal TheaterWide 16:9 Integrated HD LCD TV SRS WOW SRS WOW technology takes the performance of the television's existing speakers to a whole new level, offering the consumer superior sound quality with no additional peakers required, SRS WOW consists of three separate sound expanding systems, which work together to extract"buried" highs and lows. The three systems are, SRS 3D, TruBass, and FOCUS. SRS 3D creates a three dimensional sound field from just two speakers, thus giving the listener the feeling of hearing a multi speaker surround sound system. TruBass produces a powerful, yet low, frequency sound by utilizing a process called psychoacoustics. From only two small speakers, TruBass will give the effect of an expensive sub bass woofer that will leave the listener amazed by the quality of the sound. FOCUS was added to direct the energy from the speakers of the television set in a vertical direction up towards the listeners ears. The addition of FOCUS means that there is virtually no loss of sound from the speakers position on the bottom panel near the floor, which achieves a clear, undistorted range of audio. Benefit: A more enveloping sound with enhanced bass and better dialog reproduction. TV Guide On Screen Interactive Program Guide This on-screen guide, featured on all 2004 Toshiba integrated HDTVs, combines programming from each of the television's internal tuners into one, east-to-read on screen program guide. TV Guide On Screen makes it easy for the consumer to locate desired programs and is a crucial feature for digital cable. Simple, one-touch recording of programs, including HDTV, is also possible when connected to Toshibas new Symbio A/V Hard Drive Recorder. Benefit: This Interactive Program Guide provides an easy to read listing of the television programs available to view or record. The full 2004 version incorporated in this model provides: an 8-day program listing, flexibility of recording directly to DVD or the HDD, the ability to perform keyword searches for locating favorite programs and includes the G-Link IR Blaster for controlling cable boxes. When recording television programs, the name of the show, along with the channel and date, are automatically captured. Four-Item Illuminated Universal Remote with DVD Control For easy operation in a dark living room or home theater environment, Toshiba's ergonomically designed Universal Remote comes with Fully Illuminated Buttons. As an additional convenience, these remotes are pre-programmed to operate all functions of the TV and key functions of most Cable Boxes, VCRs and DVD players. All TV functions can be easily operated using the remote control to access Toshiba's advanced on-screen display. This full-featured system can be operated in English, French or Spanish. By using the four cursor buttons on the remote control, your favorite features or settings are only a click away.Benefit: Allows viewers to read menu selections in three different languages (English, French, and Spanish) to ensure user-friendly programming. HDMI (High-Definition Multimedia Interface) High Definition Multimedia Interface is the next generation of DVI. It includes the DVI digital video signal, and multi-channel digital audio signals on a single cable. Most Toshiba 2004 Integrated HD and HD Monitor models include HDMI. Benefit: HDMI (High-Definition Multimedia Interface) is the first industry-supported, uncompressed, all-digital audio/video connection. HDMI provides the best interface between a DVD player and compatible products, such as a digital television (DTV). When matched with a compatible TV, this single interconnecting cable combines: Multi-channel audio, uncompressed digital video, intercommunication between devices and simple control Protocols. This single cable connection ensures that all signals remain in their pure digital form and secure by use of High Definition Copy Protection (HDCP) regardless of signal output resolution.
FEATURES
ATSC & QAM Digital TelevisionTuners720p (1366 x 768) True HD Display with Built-in Speakers and Tuner600:1 Contrast RatioToshiba PixelPure AT" (Adaptive Technology) Digital Video ProcessingHDMI" Digital A/V InputSRS WOW"TV Guide On Screen" Interactive Program GuideDigital Cable Ready with CableCARD" Slot4-Item Illuminated Universal Remote ControlTri-Lingual Color Icon On-Screen DisplayOff/Sleep TimerHigh Definition MultiMedia Interface includes the DVI digital video signal and multi-channel digital audio signals on a single cable thus eliminating the need of a multiple cable hookup.PixelPure AT" (Adaptive Technology) includes Motion Adaptive De-Interlacing, Adaptive MPEG Processing, Adaptive Contrast Enhancement, and Adaptive Color Enhancement, all critical elements to deliver the consistently high quality picture expected from a Toshiba Television.
| Specifications |
| ATSC/QAM Tuners | Yes |
| Dolby Digital Audio Output (Optical) | Yes |
| CableCARD" Slot (DCR - Digital Cable Ready) | Yes |
| TV Guide On Screen | Yes |
| Series | TheaterWide HD LCD TV |
| Toshiba PixelPure AT | Yes |
| Screen Size | 37" Diagonal Wide |
| Panel Resolution | 1366 x 768 |
| Brightness | 500cd/m2 |
| SRSWOW" (3D, Tru-Bass, Focus) | Yes |
| Universal Remote Control | 4-Item Illuminated |
| ColorStream HD Component Video Inputs (Y, Pb, Pr) | 1 |
| Unit Dimensions (W x H x D in inches) | 36.09" x 26.04" x 4.29" |
| HDMI | Yes |
| PC Monitor Input (15 Pin D-Sub) | Yes |
| G-Link | Yes |
| New Cabinetry | Yes |
| Optional Wall Bracket | FWB3250 |
| UPC | 22265240441 |
