Toshiba 26" LCD TheaterWide HDTV
4.2
based on 6 reviews
Ratings Distribution
5 star
2
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.4
Pros
  • Attractive design (6)
  • Great picture quality (6)
  • Wide viewing angle (6)
  • Simple controls (4)
  • Fast setup (3)
  • Hdmi inputs (1)
See less See more
Cons
  • Difficult to set up (1)
  • Needs satcable receiver (1)
  • Or tuner (1)
Best Uses
  • Home (6)
  • Movies (2)
  • Office (1)
  • Video (1)
Provided by Beach Audio
The sleekly styled 26-inch Toshiba 26HLC56 HD-ready monitor features the company's latest LCD panel technology--Cinespeed--and an expanded viewing angle of 176 degrees. With no internal tuner (either standard NTSC or digital ATSC), the 26HLC56 requires an optional tuner or cable/satellite set-top box to receive standard- and high-definition television programming. It's easy to connect to brilliant imagery with the component and HDMI connections--the latter offering pure digital audio/video performance with no degradation of signal from just one convenient cable. This set also offers Toshiba's exclusive HD Dynamic Contrast function, which provides a sharper, deeper image with rich colors and a more life-like image.
It offers compatibility with all HDTV formats (480i, 480p, 720p, and 1080i) and it has a 1366 x 768-pixel resolution. It also features a 16:9 aspect ratio, 500 cd/m2 (candela per square meter) brightness rating, and an exceptional 900:1 contrast ratio. (The higher the contrast ratio, the greater a TV's ability to display subtle color details and not get washed out by ambient room light.) The Cinespeed panel provides a very fast 8ms (millisecond) response time, which is great for watching fast-moving sports and action movies. Toshiba's PixelPure AT (Adaptive Technology) includes Motion Adaptive De-Interlacing, Adaptive MPEG Processing, Adaptive Contrast Enhancement, and Adaptive Color Enhancement--all critical elements to deliver a consistently high quality picture.
Convenience features include color temperature control, auto aspect ratio detection, closed captioning on mute, sleep timer, tri-lingual on-screen display, video input labeling, channel labeling, channel/video lock, and V-Chip parental controls.
The 4 MB, 10-bit digital 3D Y/C comb filter (with vertical contour correction) separates brightness and color signals better in 3D domain to eliminate cross-color, cross-luminance and dot-crawl distortion. It performs field-by-field comparisons of the television image to accurately separate the color from the black-and-white information and remove both horizontally and vertically hanging dots, as well as dot crawl, resulting in a razor sharp image. The HD Dynamic Contrast feature increases Contrast and Color Saturation to create deep, rich images, analyzing both the dark and bright areas of the picture, and separately optimizing the dynamic range in each area of the picture.
The Cinema Mode feature performs 3:2 pulldown detection and reversal, too--a handy feature for watching progressive-scan movie programs in their native 24-frame format. To adapt 24 frames-per-second movies to 30 fps video, frames in the original movie must be duplicated; 3:2 pulldown digitally corrects this duplication by removing the redundant information to display a frame-accurate picture. This set also offers several TheaterWide modes that expand letterboxed images--which is particularly useful when watching narrow letterboxed Panavision or CinemaScope films.
Product Features
" Tunerless 26-inch LCD high-definition monitor; measures 27.2 x 22.8 x 12.1 inches (WxHxD) with included stand
" Requires optional receiver or cable/satellite set-top box to receive all TV programming--no built-in NTSC tuner
" Fast 8ms (millisecond) response time, 1366 x 768-panel resolution, 500 cd/m2 brightness, 900:1 contrast ratio
" Inputs: 1 composite, 1 S-Video, 1 component, 1 HDMI, 1 PC VGA, 1 RF
" Two stereo speakers, 10 watts apiece (20 watts total); SRS WOW virtual surround sound
Toshiba 26" LCD TheaterWide HDTV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 26" LCD TheaterWide HDTV
See all eBay results
  at eBay.com
Product Reviews
Last update: Apr 10, 2007
Toshiba 26" LCD TheaterWide HDTV Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
I like it so much, I have three of them!
5.0
    Pros
  • Attractive Design
  • Great Picture
  • Reduced Glare
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I started with a 42" HD in our den, then tried this one in our kitchen where we had a glare problem. This set worked so well and was such a good buy that I went all-out HD and replaced remaining sets in master bedroom and my office with this model. Since I use satellite, I was able to take advantage …"  Read Full Review »
Was this LCD TV review on the Toshiba 26" LCD TheaterWide HDTV helpful to you?
Feb 2 2007
Ron, hooked on HD
Tucson,AZ
Reviewed at:
It is a MONITOR, Not aTV
3.0
    Pros
  • Attractive Design
  • Great Picture
  • Reduced Glare
    Cons
  • None
    Best Uses
  • Home
"Misleading advertizing led me to purchase a Monitor and not a television set as the website stated it was. Once we figure that out it works fine for what we want. Picture and color are good. "
Apr 8 2007
J the Bat
Yucaipa, CA
I am:
  • Technically Challenged
who needs a built in tuner!
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Reduced Glare
    Cons
  • None
    Best Uses
  • Home
"excellent picture, even without a high def signal coming into it..a hi def broadcast is exceptional! "
Feb 21 2007
Dano
Ellicott City, MD
Reviewed at:
Very good product - would buy it again.
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • HDMI Inputs
  • Reduced Glare
  • More »
    Cons
  • Needs SatCable receiver
  • Or Tuner
    Best Uses
  • Home
  • Movies
  • Office
  • Video
"Great picture and competitive price. "
Mar 7 2007
Jim
Brandywine, MD
Reviewed at:
Great Quality Product!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Reduced Glare
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"Easy set-up and great picture quality. [...] "
Apr 10 2007
Linda Runs for the Health of It
Chicago, IL
I am:
  • Professional
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
