Toshiba 26" Black LCD Flat Panel HDTV/DVD Combo
#455
4.2
based on 21 reviews
from $383.99 - $549.99
Ratings Distribution
5 star
8
4 star
5
3 star
5
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (2)
  • Fast setup (2)
  • Great picture quality (2)
  • High resolution (2)
  • Simple controls (2)
  • Good connection options (1)
  • Wide viewing angle (1)
See less See more
Cons
  • No flashback button (1)
Best Uses
  • Kitchen (1)
  • Wall mounting (1)
Provided by HSN
Grab the popcorn! Movie night doesn't get much better than with the Toshiba 26" LCD/DVD Combo. Its 1366 x 768 resolution and Dolby digital-compatible sound bring video and audio into crisp clarity. Great for spaces that can't handle a widescreen, this 26" beauty sports big screen perks! Good-bye cable clutter; hello great entertainment! Toshiba 26" LCD/DVD Combo - 26LV610U Features: 26" widescreen, 720p LCD display - for viewing standard and high definition programming Built-In Slot-Loading DVD player - convenient space-saving design. Built-In ATSC, NTSC, QAM digital tuning - allows for tuning of standard cable channels, off-air digital broadcasts and digital cable-in-the-clear broadcasts Digital comb filter Official DivX Certified product - plays all versions of DivX video (including DivX 6) with standard playback of DivX media files. PC and Gaming ready - all the inputs you need for multi-use Super-slim profile - conveniently wall mountable Key Specifications: Screen Type: TFT 720p LCD Screen Size: 26" Aspect Ratio: HD Ready: Yes Resolution (in pixels): 1366 x 768 Additional Product Specifications: Brightness: 500 cd/m2 Refresh Rate: 8ms Contrast Ratio: 800:1 Progressive Scan: Yes HDTV Upgradeable: Yes TV Tuner: Integrated ATSC, NTSC, QAM View Modes: Cinema, 3 mode picture size adjustment, multi-angle camera select Viewing Angles: 160 Speakers: Bottom mount stereo Bass/Treble Balance Controls: Yes Simulated Surround Sound: Dolby digital-compatible Child Lockout/V-Chip: Yes Sleep Timer: Yes Multi-Brand Remote: Yes Headphone Jack: Yes Inputs: 2 HDMI Digital, ColorStream HD Component, S-Video, RCA-video and -audio, RF 1, PC (D-Sub with L/R audio) Outputs: Digital audio, Coaxial (DVD only) Languages: English, Spanish French Multi-Subtitle Select Tabletop TV Stand: Yes Cabinet Color: Black Wall Mountable: VESA 200 x 100 mm (brackets sold separately) Power Consumption: Energy Star Power Source: Plugs into any standard household outlet Measures approx. 26.81"W x 20.23"H x 8.93"Deep (with stand) Weighs approx. 19.4 lbs. (with stand) Model #: 26LV610U Made in Thailand DVD Features: Playable Disc Types: DVD/DVD-R/DVD-RW/CD/CD-R/CD-RW/VCD DivX Home Theater WMA Playback MP3 Playback Digital Picture Zoom Fast Scan Slow-Motion Multi-Camera Angle Select Accessories Included: Remote control User Guide
Specification Description
Model 26LV610U, TOS-26LV610U, TOS26LV610
UPC 022265002292
16:9 Mode Yes
Battery Type Remote
Benefits 26" (diagonal) LCD display delivers great high-definition-quality images (1366x768)Built-in slot loading DVD player for all-in-one sp
Brightness 300 cd/m2
Capacity UOM mAh
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.7 million
Compliant Standards 120V AC +/- 10%, 60Hz +/- 0.5%
Connections HDMI™ in (1)Component in (1)S-video in (1)RCA composite in (1)RCA analog audio (1)Antenna in
Controls / Adjustments Mode, contrast, brightness, color, tint, sharpness
Country Of Origin Thailand
Description Header An all-in-one entertainment solution.
Display Catalog Number 55033503
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 26 inches
Enclosure Color Black
End Product Indicator Yes
Expansion Slot(s) UL Listed, FCC/DHHS certified
Image Aspect Ratio 16:9
Included in the Box Toshiba® 26LV610U 26" LCD HDTV/DVD ComboRemote control"AAA" batteries (2)User's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number 26LV610U
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 26LV610U
Operating Temperature UOM ° F
Parental controls Yes
Pixel Response Time 5 ms
Product Depth 3.91
Product Dimensions UOM inches
Product Height 18.52
Product Type TV/DVD/VCR combos
Product Weight 19.4
Product Weight UOM pounds
Product Width 26.81
Reception System NTSC/ATSC/QAM
Screen Size Range 21-30"
Size AAA
Sound Output Mode Stereo
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Surround Sound Effects Dolby® Digital/DTS® Compatible
Technology IR
TV Diagonal Size 26 inches
TV Image Contrast Ratio 1000:1
TV Resolution 1366x768
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 170 Degrees
Viewing Angle (Vertical) 160 Degrees
Widescreen Modes 720p
Toshiba 26" Black LCD Flat Panel HDTV/DVD Combo Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 23, 2009
Toshiba 26" Black LCD Flat Panel HDTV/DVD Combo Reviews
Most helpful positive review
[13 of 13 customers found this review helpful]
Most helpful negative review
4.0
Excellent Picture Quality, Couple of Gripes
"Like all Toshiba TV's, the picture quality is top-notch. I compared this TV to a Samsung of similar size. Toshiba's color was a tad better than Samsung, but the Samsung was excellent also. Built in DVD player is a plus when space is limited for a separate player. We use this TV in our bedroom and the 26" size is perfect, almost bought Toshiba's similiar TV in 22" size, glad I picked went for the 26", bigger i..." Read Full Review »
May 17, 2009 by moviebuff52146
See more positive Toshiba 26" Black LCD Flat Panel HDTV/DVD Combo reviews
3.0
Looks nice
"I like the TV, the overall attractive 'black' design goes well with the black accents I have going on already. I'm just really bummed this TV doesn't have the flashback [to the previous channel] option. It has a pause when changing over to the next channel as well. For the price, it'll work for the kitchen though.[...]..." Read Full Review »
Aug 12, 2009 by gg
See more negative Toshiba 26" Black LCD Flat Panel HDTV/DVD Combo reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
4.0
"Like all Toshiba TV's, the picture quality is top-notch. I compared this TV to a Samsung of similar size. Toshiba's color was a tad better than Samsung, but the Samsung was excellent also. Built in DVD player is a plus when space is limited for a separate player. We use this TV in our bedroom and …"  Read Full Review »
Was this LCD TV review on the Toshiba 26" Black LCD Flat Panel HDTV/DVD Combo helpful to you?
 Report Abuse  (13)  (0)  0 comments
May 17 2009
moviebuff52146
East Coast USA
Reviewed at:
Price: $549.99
[9 of 10 customers found this review helpful]
Toshiba 26" LCD combo
4.0
"I purchased this TV to replace a much smaller TV for the bedroom.
The picture quality and sound are about what I was expecting.
I am hard of hearing and have no problem in hearing the sound.
It is easy to plug in extra speakers to boost the sound and that
is what I have also done. I am getting sou …"  Read Full Review »
 Report Abuse  (9)  (1)  0 comments
May 1 2009
Norman D. Marton
Amazon
Reviewed at:
Price: $549.99
[5 of 5 customers found this review helpful]
ALL BUT SOUND
4.0
"Review of Toshiba 26LV610U HDTV/CD PLAYER COMBO.
This purchase replaced a Toshiba 3 way combination TV/VCR/CD analog unit which had given excellent service for at least a decade.
The new combo unit described above is excellent in every respect except sound. The volume control operates an 0-50 on s …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
May 7 2009
C. Michael Jackson
Fort Myers, FL
Reviewed at:
Price: $549.99
Great Picture Quality, Few Improvments
5.0
"Picture quality is what is to be expected from a Toshiba TV. Many options available to fine tune the picture to your liking. Digital channels almost as good as the HD channels. Convenient built in DVD player, works as good as if you had a separate player. Only drawbacks, sound volume could be louder …"  Read Full Review »
May 16 2009
bc1966
New Jersey
Reviewed at:
Price: $399.99
The worst electronic ever....I mean ever!!!!!
1.0
"I bought this TV as a temporary while my tv was getting fixed through Geek Squad. I did buy this with no research. I have never done that before. I always research electronics and applicances for at least 3 weeks or more. I was leaving on trip just days for my tv quit working so I needed a TV for th …"  Read Full Review »
Nov 3 2009
EmileeG
Samson, AL
Reviewed at:
Price: $399.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
