Toshiba 23" 720p LCD TV With Built In DVD Player
5.0
based on 3 reviews
from
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.0
Pros
  • Attractive design (3)
  • Fast setup (3)
  • Great picture quality (3)
  • Simple controls (2)
  • Wide viewing angle (1)
See less See more
Best Uses
  • Home (3)
  • Office (1)
  • Video (1)
Provided by Creative Products
"MODEL- 23HLV87 VENDOR- TOSHIBA CONSUMER FEATURES- 23 in Diagonal LCD HD Monitor TV with Built-in DVD Player 23 in Diagonal widescreen, TFT LCD display, perfect for viewing standard, high definition and analog television signals and DVD movies. Built-In Slot Loading DVD player with an ultra-slim profile is a convenient all-in-one, space saving design. Built-In ATSC/NTSC/QAM digital tuning allows for tuning of standard cable channels as well as off-air digital broadcasts, in addition to digital in cable-in-the-clear in broadcasts. DivX Home Theater Certified allows playback of DivX, AVI and MPEG4 compressed files downloaded from the internet to a personal computer and stored on a CD-R/RW. JPEG Viewer enables a user to display digital photographs on the television set in the JPEG digital format.* VIDEO - ATSC/NTSC & QAM Digital Television Tuners ATSC is the 8VSB (8-level Vestigial Sideband Modulation) system. This is the digital TV broadcast system chosen by the ATSC (Advanced Television Systems Committee) for broadcast TV in the USA. QAM (Quadrature Amplitude Modulation) is the digital TV system chosen by the U.S. Cable TV companies for use over digital cable. Toshiba integrated digital TVs have both ATSC and QAM digital tuning capability so that you can receive terrestrial digital broadcasts as well as digital in cable-in-the-clear in broadcasts. - Built-in DVD Player For the ultimate in convenience, this has eliminated the clutter and confusion of a separate DVD player. Just simply slip a movie into the slot loaded player, and the TV does the rest; switching inputs, and starts playing. - Cinema Mode (3:2 Pulldown) Cinema Mode virtually eliminates the possibility of errors or artifacts that can be caused by the process of transferring film to video. The Cinema Mode circuitry identifies original film-based content from DVDs. The 3:2 pulldown process is a method to map the 24 frames per second that are captured during film production onto the 30 frames per second of a 525 line TV system. If film-based content is sensed by the circuitry, it reassembles the frame sequence to more accurately reproduce the original 24 frame film-based material. - Digital Comb Filter Chrominance and Luminance signals are converted to a digital medium prior to separation and 2H delay. This process provides enhanced color purity and reduced dot crawl. Vertical and diagonal correction performed in a digital medium provides highly accurate Chrominance and Luminance signal separation."
Specification Description
Model 23HLV87
UPC 022265000397
Aspect Ratio 16:9
Resolution 1366 x 768
Screen Size 21" to 29"
Screen Size 23"
Select LCD Units
TV Type TV/DVD Combo
Toshiba 23" 720p LCD TV With Built In DVD Player Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 23" 720p LCD TV With Built In DVD Player
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 21, 2008
Toshiba 23" 720p LCD TV With Built In DVD Player Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
This is a great TV.
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Reduced Glare
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I bought this TV for my den/guest room. It fits perfectly, and the picture is great with the component video hookup. It has a clean look and since the DVD is built in, it makes it easy.
I am very impressed by this 23" TV. It may be smaller is size, but it packs a powerful punch. "
Was this TV / DVD / VCR Combo review on the Toshiba 23" 720p LCD TV With Built In DVD Player helpful to you?
Jul 27 2007
Liz
Ozone Park, New York
I am:
  • Practical
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
Great TV!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I bought this TV for my guest room. The size is perfect and doesn't overwhelm my room. The picture is really great! Having the DVD built in to the TV is a plus. It really is a space saver. "
 Report Abuse  (1)  (0)  0 comments
Aug 4 2007
Liz
New York
I am:
  • Practical
Reviewed at:
Great TV
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
    Cons
  • None
    Best Uses
  • Home
  • Office
  • Video
"Excellent product. I use it as both a TV and Computer Monitor for online programming. The wall mounting was done professionally as well. "
Feb 21 2008
Mark
Chicago, IL
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
