Toshiba 22LV505 - Open Box 22-Inch LCD HDTV/DVD Combo
#392
4.2
based on 32 reviews
from $329.99 - $399.00
Ratings Distribution
5 star
14
4 star
13
3 star
2
2 star
3
1 star
0
Category Average
4.4
Low Price:
$329.99 at Newegg
 Trusted:
$399.00 at Rainbow Appliance
Find it at Amazon
More Images
Pros
  • Fast setup (13)
  • Great picture quality (13)
  • High resolution (12)
  • Good connection options (11)
  • Attractive design (10)
  • Simple controls (9)
  • Wide viewing angle (6)
  • Durable (1)
  • Good value (1)
  • High quality (1)
See less See more
Cons
  • Poor sound quality (3)
  • Slow to change channels (2)
  • Could be a bit louder (1)
  • Low resolution (1)
  • Not a true 16x9 ratio (1)
  • Poor image quality (1)
  • Slow changing channels (1)
Best Uses
  • Bedroom (10)
  • Home (3)
  • Computer room (1)
  • Den study (1)
  • Kitchen (1)
  • Kitchen counter top (1)
  • Movies (1)
  • Office (1)
  • Wall mounting (1)
Provided by OneCall
22-inch Diagonal widescreen, TFT LCD display, perfect for viewing standard,
high definition and analog television signals and DVD movies.
Built-In Slot Loading DVD player with an ultra-slim profile is a convenient all-in-one, space saving design.
Built-In ATSC/NTSC/QAM digital tuning allows for tuning of standard cable channels as well as off-air digital broadcasts, in addition to digital “cable-in-the-clear" broadcasts.
Official DivX(R) Certified product. Plays all versions of DivX video (including
DivX(R) 6) with standard playback of DivX(R) media files.
Using the PC Input, the 22LV505 can be used in conjunction with a computer,
and the A/V Input, HDMITM, and Component Input can be used for gaming and receiving HD broadcasts.
Space Saving Design with a height under 18-inches allows the 22LV505 to fit into tight spaces, such as underneath your kitchen cabinets.
Specification Description
Model 22LV505
UPC 022265001516
Audio Controls Bass, trable, balance
Benefits 22" (diagonal) LCD display delivers great high-definition-quality images (1440x900)Built-in DVD player accepts DVD-Video, DVD-R/RW, D
Brightness 350 cd/m2
Capacity UOM mAh
Closed Caption Capability Yes
Color Depth 16.7 milion colors
Color Temperature Control Yes
Compliant Standards UL Listed, FCC/DHHS Certified
Controls / Adjustments Mode, contrast, brightness, color, tint, sharpness
Country Of Origin Thailand
Description Header Everything you need in one package.
Display Catalog Number 55031206
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 22 inches
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box Toshiba® 22" LCD HDTV/DVD ComboRemote control"AAA" batteries (2)User's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number 22LV505
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 22LV505
Operating Temperature UOM ° F
Output Power / Total 6 watts
Parental controls Yes
Product Depth 8.15
Product Dimensions UOM inches
Product Height 17.3
Product Type TV/DVD/VCR combos
Product Weight 13.4
Product Weight UOM pounds
Product Width 21.12
Reception System NTSC/ATSC/QAM
Screen Size Range 21-30"
Secondary Audio Program (SAP) Yes
Sound Output Mode Stereo
Speaker(s) Built-in , 3W + 3W
Speakers Included 2 Speakers
Supported Languages English
Surround Sound Effects Dolby® Digital and DTS® compatible output
TV Diagonal Size 22 inches
TV Image Contrast Ratio 800:1
TV Resolution 1440x900
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 160 Degrees
Viewing Angle (Vertical) 160 Degrees
Voltage Required 120V AC +/- 10%, 60Hz +/- 0.5%
Widescreen Modes 480i, 480p, 720p
Toshiba 22LV505 - Open Box 22-Inch LCD HDTV/DVD Combo Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 27, 2009
Toshiba 22LV505 - Open Box 22-Inch LCD HDTV/DVD Combo Reviews
Most helpful positive review
Most helpful negative review
4.0
Great TV for the price
"I purchased for the bedroom after looking at several brands at local box stores. [...]This set has a much clearer picture @ 1000 to 1.With a set of regular rabbit ears I had from an old set I was able to get a total of 26 channels without hooking up to cable. This would work great for anyone without cable. I didn't give 5 stars because of the 4 second delay changing channels and the sound quality isn't that grea..." Read Full Review »
Jan 02, 2009 by Regular Dave
See more positive Toshiba 22LV505 - Open Box 22-Inch LCD HDTV/DVD Combo reviews
2.0
Looks great on paper BUT...
"I bought this combo for the kitchen. I’ve done my research and found out that there is a limited selection of 22” combos. It’s limited to Sharp, Toshiba, Sansui and few “off” brands (“Dynex” etc.) Based on specs Toshiba sounds like an excellent choice. Toshiba picture looked a bit dark in the showroom but I’ve attributed it to the settings. "Off" brands image looked better than Toshiba but the draw back is ver..." Read Full Review »
Feb 02, 2009 by Savvy User
See more negative Toshiba 22LV505 - Open Box 22-Inch LCD HDTV/DVD Combo reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
4.0
    Pros
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Simple Controls
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
"I purchased for the bedroom after looking at several brands at local box stores. [...]This set has a much clearer picture @ 1000 to 1.With a set of regular rabbit ears I had from an old set I was able to get a total of 26 channels without hooking up to cable. This would work great for anyone without …"  Read Full Review »
I haven't removed protective cover yet.
  • Using Product
Was this LCD TV review on the Toshiba 22LV505 - Open Box 22-Inch LCD HDTV/DVD Combo helpful to you?
Jan 2 2009
Regular Dave
San Antonio, TX
I am:
  • Casual User
Reviewed at:
2.0
    Pros
  • Fast Setup
    Cons
  • Dull Image
  • Poor Resolution
  • Poor Sound
    Best Uses
  • Bedroom
Based on specs Toshiba sounds like an excellent choice. Toshiba picture looked a bit dark in the showr …"  Read Full Review »
Feb 2 2009
Savvy User
NYC
I am:
  • Power User
Reviewed at:
[4 of 4 customers found this review helpful]
Great features - I love it
5.0
"I tried both Sharp and Toshiba (22 LCD/DVD combo)- Here is a comparison .
Postives of Toshiba
1)Sharp Check source/input --> It says DVD,Input1,Input2,,,,,,DVD--> this is confusing...(Toshiba says PC, HDMI etc which is clear)
2) Sharp DVD drive doesn't read everything for eg I …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Nov 4 2008
Jacobs1222
Sacramento
Reviewed at:
[1 of 1 customers found this review helpful]
THIS IS A WINNER!
5.0
"I had a 19" old clunker T.V. in my bedroom for years and it was time for me to update so I got this 22" Toshiba. I could hardly believe the difference. The clarity was much, much better and one thing that many people (including me) don't think about, is the Remote Control. This one was beyond awe …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 29 2009
Liz The Whiz
Elgin, IL
I am:
  • Power User
Reviewed at:
22" Combo TV Toshiba
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
"The picture is great - esp the digital ones. We have it in the kitchen and can turn it so it's visible from many spots. It would be nice to have a swivel base, vs turning the whole TV. The channels seem a little slow changing. Love the "combo" feature able to use a DVD disc w/o another machine to …"  Read Full Review »
Jan 28 2009
z from tennessee
chattanooga, tn
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
