based on 15 reviews
Ratings Distribution
| 5 star |
3 |
| 4 star |
9 |
| 3 star |
1 |
| 2 star |
1 |
| 1 star |
1 |
Category Average
$346.99 - $349.99
from 2 storesPros
Cons
Best Uses
Where to Buy
BizRate Rating
Outstanding 9.2
BizRate Rating
Good 8.5
Product Reviews
"I purchased this as a 2nd LCD and use it in my kitchen where it's wall mounted. The rear VESA mounting was easy as pie! The only issue I had was removing the stand - it's held on by 5 screws that kept stripping. After an hour of struggling and about 6 different screwdrivers, I finally got them all. Here's a TIP: use a high quality screwdriver, i.e., Craftsman. For some reason it "bit" better than cheaper on..." Read Full Review »
Feb 25, 2009 by arlingtonbadger
See more positive Toshiba 22in. 720p HD LCD TV (Model #22AV500U) reviews
"Set TV up in kitchen under cabinets. Despite great reviews, the TV does not deliver good picture quality using a standard signal (non HD). Picture is unclear and fuzzy, especially around the perimeter of on-screen objects. Also, it is difficult to watch programming for any length of time. Planning to return TV...." Read Full Review »
Apr 22, 2009 by Dissatisfied
See more negative Toshiba 22in. 720p HD LCD TV (Model #22AV500U) reviews
Displaying 1 - 5 of 15 Reviews
Toshiba 22in. 720p HD LCD TV (Model #22AV500U) Review
Pros
Cons
Best Uses
"I purchased this as a 2nd LCD and use it in my kitchen where it's wall mounted. The rear VESA mounting was easy as pie! The only issue I had was removing the stand - it's held on by 5 screws that kept stripping. After an hour of struggling and about 6 different screwdrivers, I finally got them al …" Read Full Review »
Pros
Cons
Best Uses
"We bought this for our small master bedroom. We do not have HD hookup yet, so we had to fiddle with the color and tint for clarity and it look great now. The sound was better than the others since it has a strip of sound the entire length of the screen so we didn't have to get the additional speak …" Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"The TV is used for bedroom-adequate size for top of bureau and bedroom, excellent resolution and clear image, good design for room -appropriate cost, volume is appropriate for size and location.
But below average audio-sound isn't define enough,too brassy but OK -audio controls aren't helpful c
Read Full Review »
Pros
Cons
Best Uses
"I bought this as a bedroom TV for my mother. It came out of the box and almost instantly scanned all the channels on my mom's cable sytem. All I needed to do is tweak the color and tint slightly and it was good to go. Sound is a little weak, but not too bad. I hooked up an antenna and HD looked very …" Read Full Review »
Pros
Cons
Best Uses
"The one thing I have as a negative is the way the connection is made into the TV set. Rather than the plug having to be placed in an upward direction, it would be so much easier if the connection was able to be put in straight in. (i.e. as a plug goes into a wall) Connection falls out easily, diffic …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.2
BizRate Rating
Good 8.5
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
