Toshiba 1TB Desktop External Hard Drive
#220
2.9
based on 28 reviews
Ratings Distribution
5 star
4
4 star
7
3 star
4
2 star
0
1 star
9
Category Average
4.3
Low Price:
$109.97 at CompUSA
 Trusted:
$109.97 at TigerDirect
Find it at Amazon
$109.97 - $159.99
from 9 stores
More Images
Pros
  • Fast (3)
  • Easy to install (2)
  • Highly compatible (2)
  • Quiet (2)
  • Reliable (1)
See less See more
Cons
  • Hard to install (2)
  • Does not work well w mac (1)
  • Flimsy (1)
  • Runs a bit warm (1)
  • Unreliable (1)
Best Uses
  • High-end multimedia (2)
Provided by Meijer.com
This 1TB Toshiba PH3100U-1EXB Portable USB Hard Drive makes backing up your computer simple. It offers you both extra space and a comprehensive backup solution for your digital files. The slim design and small footprint also save your desk space both at work and at home. Just a few clicks and you are on your way to creating a digital safety net to help protect your files.
With the Toshiba PH3100U-1EXB Portable USB Hard Drive, you will enjoy storage space for even the largest digital libraries. The 1TB drive is capable of storing up to 200,000 digital photos, 250,000 digital music files, or 380 hours of downloaded digital movies.
With dual connectivity design, you can choose between the USB interface or the faster eSATA interface for your data transfer needs. The drive also includes a built in on/off switch allowing you to conveniently power down your drive when not in use. The comprehensive, yet easy to use, software backups, recovers, and syncs your files. The software runs directly from the drive without requiring installation on your computer. Bi-directional synchronization helps keep your files on multiple computers up to date. You can even schedule your backup and sync tasks to automatically run at your desired day and time.
Specification Description
Model PH3100U-1EXB, PH3100U1EXB
UPC 883974254644
color null
Computer Compatibility PC and Macintosh
Connection External
Drive Capacity 1000GB 1TB
Port Compatibility USB / ESATA
Rotational Speed 5400 rpm
size null
sku 162411
skuprice 159.9900
Storage Capacity 1TB
style PH3100U-1EXB
taxable Y
Type of Drive Hard Drive
Toshiba 1TB Desktop External Hard Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 21, 2009
Toshiba 1TB Desktop External Hard Drive Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
I purchased this drive to ...
"I purchased this drive to back up my large storage in my desktop. The eSATA connection has backed up at a consistent 500+MB per minute for the entire backup. I have two RAIDs (SATA) one is striped and the other mirrored. I was a bit fearful of the striped RAID however running WIN 7 RC I haven't had a failure. Just to be safe I purchased this drive and backed up the entire 800gb drives in about a day, I know back..." Read Full Review »
Aug 22, 2009 by Jones
See more positive Toshiba 1TB Desktop External Hard Drive reviews
3.0
Disappointed that I failed to ask the question
"I've been contemplating getting a new external drive for some time. I'd been using an enclosure with an 80GB drive until I burned the drive out. So, I did research and found that the Seagate FreeAgent suited my needs best. Good transfer speeds and backup software included. When I went to the store they had both the Seagate as well as the Toshiba drive. The tag on the shelf for the Seagate showed $139.99 and the ..." Read Full Review »
Sep 17, 2009 by Anonymous
See more negative Toshiba 1TB Desktop External Hard Drive reviews
Displaying 1 - 5 of 28 Reviews
Show
Sort by
5.0
"I purchased this drive to back up my large storage in my desktop. The eSATA connection has backed up at a consistent 500+MB per minute for the entire backup. I have two RAIDs (SATA) one is striped and the other mirrored. I was a bit fearful of the striped RAID however running WIN 7 RC I haven't had …"  Read Full Review »
Was this Internal Hard Drive review on the Toshiba 1TB Desktop External Hard Drive helpful to you?
 Report Abuse  (4)  (0)  0 comments
Aug 22 2009
Jones
Portland, OR USA
Reviewed at:
Price: $159.99
Nice Drive, Mediocre Software
4.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
    Cons
  • Runs a bit Warm
    Best Uses
  • High-End Multimedia
"I wanted this drive to back up the main C/ drives on my two desktops and one laptop. It has the capacity for this. But the backup software is only Windows and on a pseudo-CD on the hard drive and if that gets corrupted the backups would be useless. So I am using Acronis backup. Also have ordered an …"  Read Full Review »
Oct 10 2009
TonyWim
State College PA
I am:
  • Frequent User
Reviewed at:
Price: $109.99
3.0
"I've been contemplating getting a new external drive for some time. I'd been using an enclosure with an 80GB drive until I burned the drive out. So, I did research and found that the Seagate FreeAgent suited my needs best. Good transfer speeds and backup software included. When I went to the store t …"  Read Full Review »
Sep 17 2009
Goffstown, NH
Reviewed at:
Price: $114.99
[0 of 1 customers found this review helpful]
Not Mac Friendly
1.0
    Pros
  • None
    Cons
  • Difficult To Install
  • Does not work well w Mac
  • Flimsy
  • Unreliable
    Best Uses
  • None
"This product would work great if the file types would be recognized. AI, PDF, or anything stored inside a file...It trashes the data. Big thumbs down if you are relying your graphic, web design or even music to be reliably stored. Your best bet is to store each item individually and check that each …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Sep 25 2009
toshibasucks
toledohio
I am:
  • Infrequent User
Reviewed at:
Price: $109.99
Happy I bought it
4.0
"Based on the other reviews people have been having trouble with the formatting. The one gripe that I have is that the preloaded backup software is easy to erase if you don't pay attention! I first copied the backup software to my desktop then formatted the drive to NTFS. Why it isn't already formatt …"  Read Full Review »
Oct 1 2009
maniben
Anchorage, AK
Reviewed at:
Price: $114.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
