Toshiba ® 19LV611U 19" LCD HDTV/DVD Combo (White)
#15
4.1
based on 7 reviews
from $259.00 - $308.08
Ratings Distribution
5 star
4
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.0
More Images
Pros
  • Attractive design (4)
  • Great picture quality (4)
  • Fast setup (3)
  • Simple controls (3)
  • Durable (1)
  • Easy setup (1)
  • Great sound quality (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Poor image quality (1)
  • Poor sound quality (1)
Best Uses
  • Home (3)
  • Movies (3)
  • Office (2)
  • Dorm room (1)
  • Large rooms (1)
  • Professional (1)
  • Small rooms (1)
  • Video (1)
Provided by nulime.com
Product Model: 19LV611U
Space saver and all-in-one entertainment solution, the 19LV611U LCD HDTV with built-in DVD player is a compact powerhouse with sleek design and high-gloss white finish. This TV is perfect for viewing standard and high definition digital television signals and DVD movies.
Technical Information
Actual Screen Size: 18.5"
Screen Technology: LCD Active Matrix
Compatible Technology: HDTV
Aspect Ratio: 16:9
Features:
  • Auto Program
  • Closed Caption
  • Channel Labeling
Media Support:
  • DVD-R - Play
  • DVD-R/RW - Play
  • CD-R - Play
  • CD-RW - Play
Formats Support:
  • DivX
  • MP3
  • WMA
Video
Video System:
  • ATSC
  • NTSC
Maximum Resolution: 1366 x 768
Scan Format: 720p
Audio
Speaker Included: Yes
Audio Decoding: Stereo
Sound System:
  • Dolby Digital
  • Surround
Interfaces/Ports
Ports:
  • 1 x Headphone Rear
  • 1 x Component Video In
  • 2 x Stereo Audio Line In Rear
  • 1 x RCA Composite Video In Rear
  • 1 x S-Video In
  • 1 x 15-pin HD-15 VGA In
  • 1 x Audio Line In
  • 1 x HDMI Digital Audio/Video In
  • 1 x Digital/Coaxial Audio Line Out
  • 1 x RF Antenna In Rear
Controls/Indicators
Language Support:
  • English
  • French
  • Spanish
Built-in Devices
Built-in Devices: DVD
Physical Characteristics
Color: White
Dimensions: 13.12" Height x 18.74" Width x 2.63" Depth
Weight: 11.2 lb
Miscellaneous
Green Compliance: Yes
Green Compliance Certificate/Authority: Energy Star
Specification Description
Model 19LV611U, TOS19LV611
UPC 022265002261
16:9 Mode Yes
Battery Type Remote
Benefits 18.5" (diagonal) LCD display delivers great high-definition-quality images (1366x768)Built-in slot loading DVD player for all-in-one
Brightness 300 cd/m2
Capacity UOM mAh
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.7 million
Compliant Standards UL Listed, FCC/DHHS certified
Connections HDMI in (1)Component video in (1)S-video in (1)Composite video in (1)RCA analog audio (1)Antenna
Controls / Adjustments Mode, Contrast, Brightness, Color, Tint, Sharpness
Country Of Origin Thailand
Description Header An all-in-one entertainment solution.
Display Catalog Number 55035085
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 18.5 inches
Enclosure Color White
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box Toshiba 19LV611U 19" LCD HDTV/DVD Combo with detacheable standRemote control"AAA" batteries (2)User's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number 19LV611U
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 19LV611U
Operating Temperature UOM ° F
Parental controls Yes
Pixel Response Time 5 ms
Product Depth 2.63
Product Dimensions UOM inches
Product Disclaimer *Dolby is a registered trademark of Dolby Laboratories Licensing Corporation. DTS is a registered trademark of Digital Theater Systems, Inc.
Product Height 13.12
Product Type TV/DVD/VCR combos
Product Weight 11.2
Product Weight UOM pounds
Product Width 18.74
Reception System NTSC/ATSC/QAM
Screen Size Range 10-20"
Secondary Audio Program (SAP) Yes
Size AAA
Sound Output Mode Stereo
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Surround Sound Effects Dolby® Digital/DTS® Compatible
Technology IR
TV Diagonal Size 18.5 inches
TV Image Contrast Ratio 1000:1
TV Resolution 1366x768
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 170 Degrees
Viewing Angle (Vertical) 170 Degrees
Voltage 1.5
Voltage Required 120V AC ± 10%, 60Hz ± 0.5%
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Toshiba ® 19LV611U 19" LCD HDTV/DVD Combo (White) Questions
Questions and Answers
Where to Buy
$259.99
$1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09
BizRate Rating Outstanding 9.1
$281.00
5% off orders at Abt.com
BizRate Rating Outstanding 9.4
$259.00
Show all 12 stores
_
Product Reviews
Last update: Sep 25, 2009
Toshiba ® 19LV611U 19" LCD HDTV/DVD Combo (White) Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great little set
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Professional
  • Video
"I bought this set for my bedroom and one of the reasons I like it is the flat screen enabled me to position it in a corner where it doesn't take up too much space, yet the picture is a decent size for that great "lying in bed" viewing. The setup was simple, directions are clear. For watching tv or …"  Read Full Review »
Was this TV / DVD / VCR Combo review on the Toshiba ® 19LV611U 19" LCD HDTV/DVD Combo (White) helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 21 2009
Cat lady
Chicago, IL
I am:
  • Casual User
Reviewed at:
Price: $281.00
[4 of 4 customers found this review helpful]
love the look of this tv, + energy star
4.0
    Pros
  • Attractive Design
  • Clear Audio
  • Clear Picture
  • Durable
  • Easy Controls
  • More »
    Cons
  • Poor Audio
    Best Uses
  • Dorm Rooms
  • Large Rooms
  • Movies
  • Office
  • Small Rooms
"I hate the ways most newer tv's look - this is one of the few with a really nice look, in white. The picture is better than many LCD sets, with a good viewing angle. Unless I am on the floor playing with the dog, the picture looks very good. The speakers sound too tinny, so I bought some Cozo comput …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Sep 6 2009
appledude
San Diego, California
I am:
  • Enthusiast
Reviewed at:
Price: $299.99
Excellent picture. Very versatile.
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"Versatile TV with excellent picture. Internal DVD player accomodates convenient viewing in any room. Does not take up a lot of space. We use it in our kitchen and guest rooms, where its design, size, and functionality are perfect. "
Sep 25 2009
Jer the Bear
Coastal Carolina
I am:
  • Casual User
Reviewed at:
Price: $281.00
[3 of 3 customers found this review helpful]
If you're looking for a ...
5.0
"If you're looking for a "white" cabinet TV for the kitchen area, this is it. Its big screen in a compact size is just right for our kitchen. There's no glare on the screen from our skylight either. Although it's not a 1080P TV, the HD channels still look great. The built-in DVD is a bonus we probabl …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jul 13 2009
the4pals@o
Undisclosed
Not Worth the Money
1.0
    Pros
  • None
    Cons
  • Poor Picture Quality
    Best Uses
  • None
"Nice looking but not bright enough, even when the lights in the room out. Save your money and get a newer model. Sorry. "
Sep 12 2009
Brian
Somewhere In South Carolina
I am:
  • Casual User
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
