TomTom ONE140S 3.5" Screen GPS Navigation System
#54
4.1
based on 47 reviews
from $119.00 - $179.99
Ratings Distribution
5 star
26
4 star
13
3 star
2
2 star
1
1 star
5
Category Average
4.1
More Images
Pros
  • Easy setup (12)
  • Easy menus (11)
  • Easy to read (11)
  • Acquires satellites quickly (10)
  • Compact (10)
  • Reliable (10)
  • Simple controls (10)
  • Large clear lcd (3)
  • Clear voice (1)
See less See more
Cons
  • Flimsy mounting (2)
  • Acquires satellites slowly (1)
  • Inaccurate (1)
  • Short battery life (1)
Best Uses
  • Finding specific address (9)
  • Planning trips (8)
  • Rural navigation (7)
  • Faster routes (6)
  • Urban navigation (6)
  • "where am i" feature (1)
  • Geocaching (1)
Provided by Meijer.com
The TomTom ONE 140S 3.5" GPS Navigator with Text-to-Speech capability puts complete navigation into a compact, portable GPS device. Switch it on and go right out of the box. Spoken turn-by-turn instructions and 3D graphics will guide you to any address in the US, Canada, or Mexico - including more than 7 million preloaded points of interest.
IQ routes technology gives you the fastest route every time by using actual average speeds of travel on your route to calculate your trip rather than only posted speed limits, so you'll always travel the smartest route. Advanced lane guidance uses photorealistic images to bring even more clarity to complex multilane exits, so you can be more confident on the road, even when you're in a strange city.
TomTom has the most accurate maps and with TomTom map share technology you can instantly modify street names, street direction, POIs, road speeds and turn restrictions on your own device. With the Help Me! menu, there are added safety features so you can easily access local emergency providers. The award winning fold and go easy-port mount folds flat against the device, making it easy to take it with you from car to car. The ONE 140S is complete, portable navigation.
Specification Description
Model 1EK0.052.02, 1EK005202, 1EKO.052.02, 636926026659
UPC 636926026659
Antenna Internal
Auto routing/rerouting Yes
Battery Average Run Time 3
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits 3.5-inch touchscreen makes navigating the intuitive menu a cinchText-to-speech function announces street names so you can focus on th
Cables Included USB cable
Capacity UOM mAh
Chemistry Lithium Ion
Color support Yes
Connections USB (1)
Country Of Origin China
Description Header For easy navigation.
Display Catalog Number 55032818
Display size (diagonal) 3.5 inches
End Product Indicator Yes
Expandable Memory SD
Features Large speaker gives you the best audio quality and eliminates distortionsMaps include speed limit data to warn you when you're exceed
GPS type Car
Hands-free calling capability Yes
Included in the Box ONE 140S GPS receiverEasyport mountUSB chargerUSB cableAdhesive diskDocumentation
Manufacturer Labor Warranty 12
Manufacturer Part Number 1EK0.052.02
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps U.S., Mexico, Canada
Menu navigation Touchscreen
Model ONE 140S
Operating Temperature UOM ° F
Points of interest 7 million
Power Device Battery, charger
Product Depth 0.8
Product Dimensions UOM inches
Product Height 3
Product Type Car
Product Weight 6.8
Product Weight UOM ounces
Product Width 3.6
Rechargeable Yes
Spoken street names Yes
Supported Languages English
Touchscreen Yes
Traffic/Weather Yes
Type QVGA
Updatable Maps Yes
Uploadable Maps SD slot
Voice Guidance Yes
TomTom ONE140S 3.5" Screen GPS Navigation System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 12, 2009
TomTom ONE140S 3.5" Screen GPS Navigation System Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Great Product!
"Great unit and it works as advertised. I'm always looking to explore new places and have this help me get there...." Read Full Review »
Jun 17, 2009 by Marc
See more positive TomTom ONE140S 3.5" Screen GPS Navigation System reviews
3.0
I read good reviews about ...
"I read good reviews about this TomTom and was very interested in the IQ routes as well as giving directions and street names out loud. It is very easy to use and did a good job providing the best route based on time of day and announcing turns well in advance. The demo feature and text turn by turn instructions are cool too. Unfortunately, the advanced lane guidance is overdone in my opinion. There is an option ..." Read Full Review »
Aug 14, 2009 by BrianAC
See more negative TomTom ONE140S 3.5" Screen GPS Navigation System reviews
Displaying 1 - 5 of 47 Reviews
Show
Sort by
Simple to use but has plenty of options
5.0
    Pros
  • Acquires Satellites Quickly
  • Clear voice
  • Compact
  • Easy Menus
  • Easy To Read
  • More »
    Cons
  • None
    Best Uses
  • Faster Routes
  • Finding Specific Address
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"For many months I have been looking for a GPS that would replace my stolen Mio320. Going from a 4.3 screen to a 3.2 at first would seem like a negative.Just the opposite, I can now mount the 140S next to my review mirror and keep it up out of unwanted eyes. I'm able to take it with me because of it' …"  Read Full Review »
Was this Car GPS review on the TomTom ONE140S 3.5" Screen GPS Navigation System helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 7 2009
Scannerfreq
Central Florida
I am:
  • Enthusiast
Easy to set up and use
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • "Where Am I" feature
  • Geocaching
  • Planning Trips
"Use "Where Am I" in the "Help" section to get your exact location if you're lost...then plot your trip from there.
Also, go to the Tom Tom site and download "Home", and get updated maps installed on your device. "
Nov 12 2009
darkcrash17
New Jersey
I am:
  • Casual User
Reviewed at:
Price: $149.95
Good little GPS
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • Simple Controls
    Cons
  • Acquires Satellites Slowly
    Best Uses
  • Planning Trips
"This is my first GPS. I got it because I'm traveling more for work. I wanted something simple and didn't want all the extra frills of MP3 player and video stuff. I just wanted something that would tell me how to get to where I was going.
The Tomtom ONE 140s is pretty good. Playing around, I tri …"  Read Full Review »
Jul 21 2009
Pickle
East Windsor, NJ
I am:
  • Casual User
Reviewed at:
Price: $149.95
Great Product!
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None that I can tell
    Best Uses
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"Great unit and it works as advertised. I'm always looking to explore new places and have this help me get there. "
 Report Abuse  (5)  (0)  0 comments
Jun 17 2009
Marc
Niles, IL
I am:
  • Enthusiast
Reviewed at:
Price: $149.95
[1 of 2 customers found this review helpful]
Great Product!
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Flimsy Mounting
    Best Uses
  • Faster Routes
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"Got this for my sister. She is horrible with directions and she loves it. The product is so great. She had a garmin before and this GPS is such an upgrade from that. I highly recommend it. The only problem is the mounting sometimes falls off but other than that...I think its the best GPS! "
 Report Abuse  (1)  (1)  0 comments
Aug 15 2009
NYC Driver 2009
New York
I am:
  • Power User
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
