TomTom ONE GPS Navigation System
#213
4.1
based on 619 reviews
Ratings Distribution
5 star
326
4 star
263
3 star
44
2 star
37
1 star
48
Category Average
4.1
$217.99 - $229.24
from 3 stores
Pros
  • Easy setup (380)
  • Compact (373)
  • Easy to read (368)
  • Easy menus (345)
  • Acquires satellites quickly (321)
  • Simple controls (318)
  • Reliable (304)
  • Large screen (67)
  • Secure mounting (51)
  • Good value (19)
See less See more
Cons
  • Poor battery life (122)
  • Inaccurate (56)
  • Acquires satellites slowly (50)
  • Flimsy mounting (49)
  • Difficult menus (21)
  • Complicated controls (13)
  • Bulky (2)
  • No sd card slot (2)
  • Tough to control (2)
Best Uses
  • Finding specific address (304)
  • Planning trips (225)
  • Faster routes (214)
  • Urban navigation (131)
  • Rural navigation (111)
  • Geocaching (35)
  • Auto (9)
  • Travel (6)
  • Adventure (3)
  • Highway driving (2)
Provided by MacMall
One 3rd Edition Portable GPS Navigator - Refurbished Includes an improved user interface with new options for customizing the navigation screen & more information with easier access to other functions. The latest version of the popular TomTom One GPS navigation unit includes an improved user interface with new options for customizing the navigation screen and more information with easier access to other functions. The MapShare feature allows you to edit maps instantly on your device and report map errors easily using your device with TomTom HOME. The Help Me Main menu option allows the user to navigate to and find information on assistance hospitals, gas stations, etc. Highlights:&nbsp&nbsp&nbsp&nbsp• Easy start-up&nbsp&nbsp&nbsp&nbsp• Optional traffic information&nbsp&nbsp&nbsp&nbsp• TomTom Map ShareFeatures:Easy to use&nbsp&nbsp&nbsp&nbsp• Plug & go: Works straight out of the box.&nbsp&nbsp&nbsp&nbsp• Quick and easy start-up: Just enter address and start driving.&nbsp&nbsp&nbsp&nbsp• User-friendly 3.5” touchscreen: Crystal clear 3D graphics.&nbsp&nbsp&nbsp&nbsp• Portable: Wallet-sized device with compact windshield holder.&nbsp&nbsp&nbsp&nbsp• Loud & clear spoken instructions: 36 languages to choose from.Best Maps
  • Preloaded maps: Laest maps of the US & Canada with details on addresses & house numbers, plus Points of Interest like gas stations, restaurants and hotels.
  • TomTom Map Share: This unique technology enables you to add to, update and personalize your maps instantly. It also lets you share and benefit from fellow users’ changes - daily, automatically and easily via TomTom HOME. TomTom Map share technology means TomTom drivers can always have the most up-to-date maps at their fingertips.
Safe, relaxed and cost-effective driving
  • Complete guidance to your destination: Tells you when you’ll arrive, how long it will take and provides a variety of routing options.
  • ‘Help me!’ menu: Direct access to emergency numbers and directions to nearest assistance (road assistance / police station / hospital).
  • Fast & accurate positioning: Start navigating in seconds with a high sensitivity GPS receiver and TomTom’s free QuickGPSfix Service.
  • Easy access to traffic info: The optional RDS-TMC Traffic Receiver accessory keeps you up-to-date on road congestion to minimize your delays.
  • Fast route (re-)calculation: Automatically re-calculates your route if you detour from the planned one.
Smart and fun extras
  • TomTom HOME: Desktop software to keep your device Future Proof with new maps and free software upgrades, plus access to other downloadable extras.
  • Smart extras: Points of Interest, maps, voices, designer cases, mount kits and more.
Technical Specifications: &nbsp&nbsp&nbsp&nbsp• Highly sensitive GPS chipset&nbsp&nbsp&nbsp&nbsp• 3.5" full color TFT LCD touchscreen (320x240 pixels, 64,000 colors)&nbsp&nbsp&nbsp&nbsp• 1GB internal memory&nbsp&nbsp&nbsp&nbsp• RDS-TMC connector&nbsp&nbsp&nbsp&nbsp• Internal Lithium-Ion battery (2 hours operation)&nbsp&nbsp&nbsp&nbsp• Dimensions: 3.8"x 3.2" x 1.0"&nbsp&nbsp&nbsp&nbsp• Weight: 6.1 ounces&nbsp&nbsp&nbsp&nbsp• Operating temperature: 14 °F to + 131 °F
Specification Description
Model 03A30E16, 1N00.083, 1N00.183, 1N00181
UPC 636926014113
Address search Yes
Antenna Integrated
Auto routing/rerouting Yes
Available memory 1GB
Battery Type Product
Benefits Easy to use, just plug it in and goEnter an address or touch a destination icon on the screen and get directionsUser-friendl
Cables Included USB
Capacity UOM mAh
Chemistry Lithium Ion
Color support Yes
Country Of Origin Taiwan
Description Header ONE of a kind GPS navigation.
Display Catalog Number 20-165
Display Catalog Number 55027873
Display size (diagonal) 3.5 inches
End Product Indicator Yes
External antenna connection Yes
Features Update and personalize your maps instantly with TomTom Map ShareTrip guidance tells you trip length, when you will arrive and provide
GPS type Car
Included in the Box ONE 3rd Edition GPSWindshield mountAdhesive disk for mountUSB car chargerUSB cableTomTom HOME sof
Included in the Box ONE 3rd EditionWindshield mountUSB car charger and cableDocumentation
Inputs 1 x (Power/USB)
Inputs 1 x (Power/USB), 1 x (External antenna)
Manufacturer Labor Warranty 2
Manufacturer Labor Warranty 6
Manufacturer Part Number 1N01.083
Manufacturer Parts Warranty 2
Manufacturer Parts Warranty 6
MAP Price 0.0
Maps Canada and the U.S. (including Alaska)
Menu navigation Touchscreen
Model ONE 3rd Edition (Refurb)
Model ONE 3rd ed.
Mounting options Windshield mount
New Date Sun Dec 09 00:00:00 CST 2007
Operating Temperature UOM ° F
Other features Choice of routes, favorites, traffic service capable, spoken directions, choice of voices
Outputs 1 x (Power/USB)
Points of interest Millions
Processor 266MHz
Product Depth 1
Product Dimensions UOM inches
Product Disclaimer Some features require a subscription. Drivers in California and Minnesota should not use the suction mount on their windshield or side or rea
Product Disclaimer Some features require a subscription. Drivers in California and Minnesota should not use the suction mount on their windshield or side or rear
Product Height 1
Product Height 3.8
Product Length 3.8
Product Type Car
Product Weight 6.1
Product Weight UOM ounces
Product Width 3.2
Recharge Time 2
Recharge Time UOM HOURS
Rechargeable Yes
Resolution 320x240
Size Specialty
Supported Languages Dutch, English, French, German, Italian, Japanese, Portuguese, Russian, Spanish, Swedish
Supported Languages English, French, German, Italian, Japanese, Portuguese, Russian, Spanish, Swedish
Touchscreen Yes
Traffic/Weather Yes
Type LCD
Updatable Maps Yes
Uploadable Maps Internal memory
Voice Guidance Yes
Web Availability ONLINE ONLY
TomTom ONE GPS Navigation System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 15, 2009
TomTom ONE GPS Navigation System Reviews
Most helpful positive review
[15 of 15 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
Great basic navigation
"Pros: In my work I am often required to travel to places I’ve never so much as heard of on very short notice. I have owned my Tomtom One for several months now and it has yet to let me down. Both the visual and audio turn-by-turn directions are clear and easy to follow. If you make a wrong turn, within seconds the unit recalculates the route to get you to your destination. When it first arrived, as a test, I ..." Read Full Review »
Oct 25, 2007 by Photog
See more positive TomTom ONE GPS Navigation System reviews
1.0
Compare Mio 320, 220 and Tomtom 1 3rd ed
"I bought Mio C320 and Tomtom one 3rd edition from RadioShack, and C220 from Circuit City.Overall of Mio C320 and C220:Great units! Highly recommended! Maps like FINE ARTS with just adequate roads and texts. Easy to use. I can easily set my new routes while I am driving. Two great and very easy to-use features while driving: tap on the screen to overview the big area around you and tap back to normal, and put..." Read Full Review »
Dec 02, 2007 by blueship789
See more negative TomTom ONE GPS Navigation System reviews
Displaying 1 - 5 of 619 Reviews
Show
Sort by
why so complicated?
4.0
    Pros
  • Acquires Satellites Quickly
  • Compact
  • Easy To Set Up
  • Reliable Performance
    Cons
  • Complicated Controls
  • Difficult Menus
  • Flimsy Mounting
    Best Uses
  • Faster Routes
  • Finding Specific Address
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"it seems to be a good product and so fare it works great. it was a gift for my mom (65 yrs young), she's the not the most technologically savey comsumer. the on screen menu's take some practice to operate correctly and navigate. i have another unit from a different manufacturer and it's much simpler …"  Read Full Review »
on the road again
on the road again
  • Using Product
Was this Car GPS review on the TomTom ONE GPS Navigation System helpful to you?
Apr 2 2009
vrodg
southern maryland
I am:
  • Casual User
[9 of 9 customers found this review helpful]
This Is Reliable; I'm Very Happy
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy to customize
  • Easy To Read
  • More »
    Cons
  • No battery use indicator
  • Sometimes hit-or-miss map
    Best Uses
  • Urban Navigation
"I picked Tom Tom because it had the LEAST number of bad reviews, and I wanted to pay a little more to get above the cheapest models which gave users the poorest performance.
My standard had been Magellan, after first using it in a rental car back in the 1990s, but poor reviews have changed my min …"  Read Full Review »
 Report Abuse  (9)  (0)  0 comments
Jul 15 2008
quaker
Daytona Beach, FL
I am:
  • Bad With Directions
  • Frequent Traveler
  • Gearhead
[6 of 6 customers found this review helpful]
Excellent Starter GPS
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Short Battery Life
    Best Uses
  • Faster Routes
  • Geocaching
  • Planning Trips
  • Rural Navigation
  • More »
"What a bargain! I usually have found refurbished items to be without any risk. Generally the company takes extra care and time to insure each unit is performing up to standards before releasing it for sale. This doesn't happen on assembly line manufacturing. I have had numerous GPS units (Call i …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Nov 30 2008
Kansas City
I am:
  • Power User
[0 of 1 customers found this review helpful]
The best GPS
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Faster Routes
  • Planning Trips
  • Urban Navigation
"the product is great in giving me demo before I start driving to my trip "
 Report Abuse  (0)  (1)  0 comments
Apr 22 2009
Abu Sumaya
Clarkston
I am:
  • Power User
[4 of 4 customers found this review helpful]
great GPS, great deal
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Flimsy Mounting
    Best Uses
  • Faster Routes
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"This is the 4th TomTom that I've owned. I still own 3, but one of them was stolen. [$] is a fantastic deal for the TomTom One, especially since it comes with the "latest map guarantee". 3 of them have been refurbished with no porblems. I've been using this refurbished one from Radio Shack for a w …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jun 18 2008
danrezzy
Wash DC suburbs
I am:
  • Frequent Traveler
  • Gearhead
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
