TomTom Go 720 GPS System
#187
4.1
based on 316 reviews
Ratings Distribution
5 star
171
4 star
102
3 star
23
2 star
20
1 star
25
Category Average
4.1
Low Price:
$119.99 at TigerDirect
 Trusted:
$187.45 at pcRUSH
$119.99 at CompUSA
see all stores
$119.99 - $442.10
from 10 stores
Pros
  • Easy to read (115)
  • Easy setup (106)
  • Compact (101)
  • Simple controls (99)
  • Reliable (92)
  • Acquires satellites quickly (88)
  • Easy menus (76)
  • Large screen (46)
  • Good battery life (20)
  • Quality construction (20)
See less See more
Cons
  • Poor battery life (20)
  • Inaccurate (12)
  • Flimsy mounting (11)
  • Difficult menus (8)
  • Acquires satellites slowly (5)
  • Complicated controls (5)
  • Pricey (5)
  • Bulky (2)
  • Poor value (2)
Best Uses
  • Finding specific address (68)
  • Faster routes (58)
  • Planning trips (57)
  • Urban navigation (43)
  • Rural navigation (31)
  • Auto (29)
  • Travel (20)
  • Adventure (13)
  • Geocaching (10)
  • Boating (2)
Provided by photoalley.com
The GO 720 is an incredibly slim TomTom. With a 4.3" touchscreen and award-winning software, it puts the power of GPS in a portable, lightweight device. Switch on and go right out of the box. Spoken turn-by-turn instructions including street names guide you along. Enjoy preloaded maps of the US and Canada and millions of points of interest like gas stations, ATMs, hotels and more. The GO 720 makes driving safer with handsfree calling, school zone and speed limit warnings, and access to emergency resources. Customize your TomTom! With MapShare technology, make instant changes to street names, street directions and POIs. Record your own voice for personalized navigation instructions; even add recognizable branded POIs to help you to find your favorites quicker. Access smart extras like real-time traffic, 5-day weather forecasts and celebrity voice downloads.
Specification Description
Model 1M00.780, 1M00.783, 1M00780, 1M00780 refurbished
UPC 063692017114
Address search Yes
Alarms Speed alert
Anti-glare Yes
Anti-theft device Yes
Auto routing/rerouting Yes
Available memory 64MB
Backlight Yes
Battery Average Run Time 5
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits Compact: fits perfectly in your car, hand or pocketFaster & easier address input helps you set up your route more quickly than ever
Capacity UOM mAh
Chemistry Lithium Polymer
Color support Yes
Connectivity Bluetooth®
Country Of Origin China
Day/Night mode Yes
Description Header GO where you want to go.
Digital music capability FM transmitter; MP3 player; iPod® compatible
Display Catalog Number 55027666
Display size (diagonal) 4.0 inches
End Product Indicator Yes
Expandable Memory SD, MMC
Features 4.3" extra-wide touchscreen provides optimal navigation view with extensive info, including trafficStart navigating in seconds with t
FM radio capability Yes
GPS type Car
Hands-free calling capability Yes
Included in the Box GO 720 deviceWindshield mountCar chargerTomTom HOME and Owner's Manual on CD ROMDesk dockDocument
Inputs x (Power)
Manufacturer Labor Warranty 6
Manufacturer Part Number 1M00.783
Manufacturer Parts Warranty 6
MAP Price 0.0
Maps United States and Canada
Max Operating Temperature 131 Fahrenheit
Menu navigation Touchscreen
Min Operating Temperature 14 Fahrenheit
Model Go 720 Refurb
Operating Temperature UOM ° F
Other features Plug & Go; TomTom Map Share; automatic call pickup; record your own navigation instructions; content sharing between devices; TomTom HOME; weather ser
Outputs 1 x Phone 1/8"(Headset)
Photo viewer Yes
Points of interest Millions preloaded
Processor 400MHz
Product Depth 0.9
Product Dimensions UOM inches
Product Disclaimer Drivers in California and Minnesota should not use the suction mount on their windshield or side or rear windows.
Product Height 3.3
Product Type Car
Product Weight 7.75
Product Weight UOM ounces
Product Width 4.65
Rechargeable Yes
Required to function Hands-free calling is compatible with the following: AT&T: Motorola RAZR V3, Motorola RAZR V3i, Motorola ROKR E1, Motorola L6, Motorola L2, Mo
Resolution 480x272 pixels
Routing options Quickest, shortest, by required arrival time, avoiding toll roads and motorways and more
Size Specialty
Supported Languages English, French, German, Portuguese, Russian, Spanish, Swedish, Dutch
Touchscreen Yes
Traffic/Weather Yes
Type TFT LCD
Updatable Maps Yes
Uploadable Maps SD card (optional)
Voice Guidance Yes
TomTom Go 720 GPS System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 2, 2009
TomTom Go 720 GPS System Reviews
Most helpful positive review
[62 of 63 customers found this review helpful]
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
Great Product
"First off I've got to say I was a little hesitant to order a refurbished product. But since it comes with the full 1 year warranty I figured there wasn't much too lose. I ordered the tomtom 720 on a Thursday and received it the following Monday. I opened it up and it looked great. First time using it I found it to be very simple and easy to operate. The software works great with a ton of free options to download..." Read Full Review »
Jul 19, 2008 by Lost no more
See more positive TomTom Go 720 GPS System reviews
1.0
Could be so much better!
"I ordered the 720 as a refurbished product after some research. It arrived in great shape cosmetically, I charged it overnight, and rudimentary setup was easy. But it was a matter of minutes before the battery indicator showed a half charge. Within about 35 minutes, it was flashing a low battery warning. I tried another overnight charge from a different charger, and got more of the same the next day. TomTom..." Read Full Review »
Apr 09, 2009 by JoMo
See more negative TomTom Go 720 GPS System reviews
Displaying 1 - 5 of 316 Reviews
Show
Sort by
[7 of 7 customers found this review helpful]
I Love My Go 720
5.0
    Pros
  • Compact
  • Easy To Read
  • Easy To Set Up
  • Reliable Performance
  • Simple Controls
    Cons
  • Short Battery Life
    Best Uses
  • Trucking
"I own my own trucking business and use this thing on a daily basis. I have had it for about 3 months and can't imagine starting a trip without it now.
About the only thing I have noticed is that the battery life doesn’t seem to last that long. Although I haven't timed it, the battery seems to on …"  Read Full Review »
Was this Car GPS review on the TomTom Go 720 GPS System helpful to you?
 Report Abuse  (7)  (0)  0 comments
Jun 5 2008
Rayzer
North Carolina
I am:
  • Gearhead
  • Technically Savvy
1.0
    Pros
  • Acquires Satellites Quickly
  • Easy Menus
  • Easy To Set Up
  • Simple Controls
    Cons
  • Inaccurate
  • Phone compatibility
    Best Uses
  • Planning Trips
  • Urban Navigation
"I ordered the 720 as a refurbished product after some research. It arrived in great shape cosmetically, I charged it overnight, and rudimentary setup was easy. But it was a matter of minutes before the battery indicator showed a half charge. Within about 35 minutes, it was flashing a low battery …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Apr 9 2009
JoMo
Des Moines, IA
I am:
  • Casual User
Reviewed at:
Price: $249.99
[11 of 11 customers found this review helpful]
Great Gps with lot of options!
5.0
    Pros
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None so far
    Best Uses
  • Finding Specific Address
"I bought this Gps refurbished for [$]and have been very happy with it so far. It has so many options that I didn't realize when I bought it. For example it connects to my cell phone and I am able receive my text messages through it while I am driving. I also have uploaded my phone book to it so mak …"  Read Full Review »
 Report Abuse  (11)  (0)  0 comments
Sep 13 2008
Melissaki5
Chicago, IL
I am:
  • Gearhead
Reviewed at:
Price: $249.99
[6 of 6 customers found this review helpful]
Best decision after a lot of research.
5.0
"I had never owned a GPS before this purchase. I had spent a large amount of time researching them and was leaning toward a Garmin 660/670 and Dreamed of owning a 680. Until I saw the TomTom 720.
I have been extremely happy with my purchase! Especially since I had a lot of hesitation buying a TomTom, …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Aug 26 2007
Clicksand
Farmington, MN
Excellent Choice
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Faster Routes
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"I got this unit as a refurbhish, and after setting it up to the computer, it upgraded the HOME sotfware and the internal GPS software! If your unit states that the Map Guarantee is expired, contact TomTom, and they will upgrade your map for free!!! So far, I have to say, this is a stupid bargain f …"  Read Full Review »
Nov 24 2008
RichieV
NYC 10033
I am:
  • Power User
Reviewed at:
Price: $249.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
