TiVo AG0100 Wireless-G USB Network Adapter
#1
4.7
based on 102 reviews
from $37.99 - $59.99
Ratings Distribution
5 star
76
4 star
23
3 star
0
2 star
2
1 star
1
Category Average
3.9
More Images
Pros
  • Easy setup (56)
  • Strong signal (35)
  • Durable (23)
  • Attractive design (9)
  • Fast setup (9)
  • Fine-tuning (5)
  • Simple controls (3)
  • Easy to use (2)
  • Looks great (2)
  • No more phone lines (2)
See less See more
Cons
  • Alluring to small kids (1)
  • Connects via 3 foot cord (1)
  • Hard to set up (1)
  • Lights bedroom at night (1)
  • Limited compatibility (1)
  • Long wpa key is difficult (1)
  • Must buy from tivo (1)
  • Needs netowrk password (1)
  • Not the best reception (1)
Best Uses
  • Living room (36)
  • Bedroom (26)
  • Office (16)
  • Small rooms (14)
  • Home (9)
  • Portable devices (6)
  • Movies (4)
  • And dofferent ranges (1)
  • Any room remote to modem (1)
  • Any where in the house (1)
Provided by ClubMac
Wireless G USB Network Adapter - 802.11b, 802.11g Easily connect your TiVo Series2 DVR to your 802.11g or 802.11b wireless home network. Enjoy TiVoToGo and Multi-Room Viewing transfers, Music and Photos and Online Scheduling. Easily connect your TiVo Series2 DVR to your 802.11g or 802.11b wireless home network. Enjoy TiVoToGo and Multi-Room Viewing transfers, Music and Photos, Online Scheduling, and more. Eliminates the need for a phone line, if used with a broadband connection. Optimized wireless performance with your TiVo Series2 DVR. Real brushed metal base; flip-up antenna with TiVo badge. For use with a TiVo Series2 DVR only.Features Include: Easily connect your TiVo DVR to your 802.11g or 802.11b wireless home network Enjoy TiVoToGo and Multi-Room Viewing transfers, Music and Photos, Online Scheduling, and more Eliminates the need for a phone line, if used with a broadband connection Optimized wireless performance with your TiVo DVR Real brushed metal base; flip-up antenna with TiVo badge For use with a TiVo Series2 or Series3 DVR only. Not for use with a TiVo Series1 DVR (with no USB ports) or DIRECTV DVR with TiVo. Not intended to be plugged into a PC or Mac.
Specification Description
Model 851342000223, AG0100, TIVAG0100
UPC 851342000223
color Metal/Gray
Country Of Origin China
Product Details Easily connects Tivoli® Series 2 DVRs to 802.11G or 802.11B Wireless networks Eliminates the need for a phone line if used with a broadband connection Brushed metal base Flip-up antenna with Tivo® badge Use with Series 2 DVR only.
size null
sku 71577 METAL/GRAY
skuprice 49.9900
style AG0100
taxable Y
TiVo AG0100 Wireless-G USB Network Adapter Questions
Questions and Answers
Where to Buy
$49.00
5% off orders at Abt.com ends 11/30/09
BizRate Rating Outstanding 9.4
$39.99
No Tax Outside NY
BizRate Rating Outstanding 9.7
$37.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
Show all 16 stores
_
Product Reviews
Last update: Nov 16, 2009
TiVo AG0100 Wireless-G USB Network Adapter Reviews
Most helpful positive review
Most helpful negative review
[0 of 2 customers found this review helpful]
5.0
It works!
"Man, I wish I had bought this little gadget sooner. Initially, I connected my Tivo to the home network directly via ethernet cable to the router. However, a new living room configuration necessitated a wireless option. I first (and erroneously) thought that all it would take is a simple USB-based wireless adapter, such as what one could by from D-Link, or Belkin, or any of the other brands. Well, none of the..." Read Full Review »
May 31, 2007 by Marty
See more positive TiVo AG0100 Wireless-G USB Network Adapter reviews
2.0
ok, need to know NETWORK PASSWORD
"The people at [...] told us that, "You don't need the password it hooks right into the Wireless Network." It dosent. I is cool looking and it got Tivo working. I pesonaly think that it is a waste of $monney$...." Read Full Review »
Oct 11, 2007 by oobond
See more negative TiVo AG0100 Wireless-G USB Network Adapter reviews
Displaying 1 - 5 of 102 Reviews
Show
Sort by
It works!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
  • Portable Devices
  • Small Rooms
"Man, I wish I had bought this little gadget sooner. Initially, I connected my Tivo to the home network directly via ethernet cable to the router. However, a new living room configuration necessitated a wireless option. I first (and erroneously) thought that all it would take is a simple USB-based …"  Read Full Review »
Was this TV Accessory review on the TiVo AG0100 Wireless-G USB Network Adapter helpful to you?
May 31 2007
Marty
San Francisco, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $49.00
Must-Have, Easy to Use
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Problem Solver
    Cons
  • Must Buy from TIVO
    Best Uses
  • Home
  • Movies
  • Office
"I wanted to be able to view movies recorded on one DVR on another DVR, so this little gem is a must-have (literally). Although TIVO says you can technically use a "TIVO-compatible" adapter, they have a lot of disclaimers and it's not worth the effort...just order the one directly from TIVO. It gets …"  Read Full Review »
Oct 27 2009
TIVO Aficionado
San Francisco, CA
I am:
  • Power User
Reviewed at:
Price: $41.72
Works great and easy to set up
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
  • WPA Security
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
  • Small Rooms
"Now that TiVo supports WPA and WPA2 wireless security (TiVo version 8.1 or higher), It finally made sense for me to connect TiVo wirelessly to my network. I have been using this for some time now and it has been working great.
The device is well designed and surprisingly well weighted (no worries …"  Read Full Review »
Dec 5 2006
RaffMan
Boston, MA
Reviewed at:
Price: $49.00
Works Just Fine
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I have a number of wireless devices an have used wireless gaming adaptors, repeaters and so on. The Tivo wireless gizmo has been the easiest to setup and has never failed. My transmitter is on the 2nd floor with the Tivo on the first floor. It easily allows me to download/xfer hourly episodes, eg …"  Read Full Review »
May 26 2008
Mike B.
Richmond, VA
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $49.00
Worked Great
5.0
    Pros
  • Attractive Design
  • Fast Setup
    Cons
  • None
    Best Uses
  • Home
"I just plugged it into the TIVO and ran the network setup and it recognized my wireless router and worked perfectly. Good transfer speed and no drops. There are no buttons or controls on this unit. "
Nov 5 2009
Blake
Sacramento, CA
I am:
  • Enthusiast
Reviewed at:
Price: $39.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
