Tiffen Pro-RL Bracket
3.8
based on 20 reviews
from $111.59 - $138.50
Ratings Distribution
5 star
6
4 star
7
3 star
4
2 star
2
1 star
1
Category Average
4.2
Pros
  • Reliable (13)
  • Well built / quality construction (9)
  • Easy setup (7)
  • Lightweight (6)
  • Softens light (5)
  • Consistent (4)
  • Convenient interface (2)
  • Easy to use (2)
  • Easy to adjust height (1)
  • Moves flash off-camera (1)
See less See more
Cons
  • Heavy / bulky (3)
  • Weak construction (2)
  • Awkward ergonomics (1)
  • Awkward front handle (1)
  • Confusing / bad remote control (1)
  • Heavy after a few hours (1)
  • Moderate construction (1)
  • More anti-slip assortment (1)
  • Not lightweight (1)
  • Plastic nuts loosen (1)
Best Uses
  • Photography (11)
  • Fill flash (9)
  • Lighting (9)
  • Weddings (8)
  • Portraits (5)
  • Photojournalism (4)
  • Artificial lighting (3)
  • Macro (2)
  • Sports photography (2)
  • Strobe lighting (2)
Provided by B&H Photo Video
Pro-RL Bracket
Specification Description
Model 310-700, 310700
UPC 750062011895
Select Medium Format Brackets
Tiffen Pro-RL Bracket Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Tiffen Pro-RL Bracket Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
PRO-RL AT WORK
"USE THIS RIG FOR WEDDINGS CHRISTENINGS ETC. FOR GREAT FLASH DISTRIBUTION IT IS BRILLIANT, THROWING THE FLASH DOWNWARDS CREATING A SHADOW BEHIND AND LOW ON THE SUBJECT, WHICH IS NOT AT ALL DISTRACTING IN THE PHOTOGRAPHS. MUCH BETTER THAN A SIDE FLASH BRACKET REGARDING SHADOWS, ESPECIALLY WHEN SIDE FLASH BRACKET HAS TO BE TURNED TO PORTRAIT MODE.I LOVE THE FACT THAT WHETHER YOU WANT A LANDSCAPE MODE SHOT AND WANT ..." Read Full Review »
Feb 05, 2007 by REPTILIAN
See more positive Tiffen Pro-RL Bracket reviews
3.0
Camera mounting screw is weakest link.
"Bracket utilized for Wedding Photography. Offers exceptional strobe height adjustment. The one thing that failed straightaway was the screw knob that you turn to lock down the camera to the bracket. It never tightened properly (screw kept spinning-nylon bushing allowed screw to keep turning never locking in place) so my camera had to be constantly adjusted and tightened down. The anti-twist bracket for the N..." Read Full Review »
Jun 06, 2008 by MacDaddy
See more negative Tiffen Pro-RL Bracket reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
Very Nice Bracket
5.0
    Pros
  • Consistent
  • Easy Setup
  • Reliable
    Cons
  • None
    Best Uses
  • Photography
  • Portraits
  • Weddings
"Just got this bracket, and have used it for a couple senior photo shoots. It worked very well. It rotates from horizontal to portrait very easily. It is heavy with my Pentax K20D and Flash mounted, but is well worth putting forth some extra muscle. I like the fact that the flash will lift so high ab …"  Read Full Review »
Was this Studio Lighting review on the Tiffen Pro-RL Bracket helpful to you?
Nov 9 2009
Photo Lady
Butler, PA
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $111.59
PRO-RL AT WORK
4.0
    Pros
  • Strong Construction
    Cons
  • Bulky
    Best Uses
  • Fill Flash
  • Lighting
  • Photography
"USE THIS RIG FOR WEDDINGS CHRISTENINGS ETC. FOR GREAT FLASH DISTRIBUTION IT IS BRILLIANT, THROWING THE FLASH DOWNWARDS CREATING A SHADOW BEHIND AND LOW ON THE SUBJECT, WHICH IS NOT AT ALL DISTRACTING IN THE PHOTOGRAPHS. MUCH BETTER THAN A SIDE FLASH BRACKET REGARDING SHADOWS, ESPECIALLY WHEN SIDE FL …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 5 2007
REPTILIAN
UNITED KINGDOM
Reviewed at:
Price: $111.59
3.0
    Pros
  • Lightweight
    Cons
  • Poor Interface
  • Weak camera screw mount
    Best Uses
  • Fill Flash
  • Lighting
  • Photography
  • Wedding
"Bracket utilized for Wedding Photography. Offers exceptional strobe height adjustment. The one thing that failed straightaway was the screw knob that you turn to lock down the camera to the bracket. It never tightened properly (screw kept spinning-nylon bushing allowed screw to keep turning never …"  Read Full Review »
Jun 6 2008
MacDaddy
North Carolina
I am:
  • Professional
Reviewed at:
Price: $111.59
Did not like for my uses
2.0
    Pros
  • Easy Setup
  • Lightweight
    Cons
  • None
    Best Uses
  • Artificial Lighting
  • Photography
  • Weddings
"Returned it - no way to lock it in portrait and the thing kept falling over hitting my lens. Did not have the reach I was looking for and could have used a few more inch extension, overall did not like it for the uses I would put it through but could see it being good for others as it's good in lan …"  Read Full Review »
Nov 5 2009
MJ
Buffalo, NY
I am:
  • Pro Photographer
Reviewed at:
Price: $111.59
[1 of 1 customers found this review helpful]
Pretty decent for the money...
4.0
    Pros
  • Reliable
    Cons
  • None
    Best Uses
  • Fill Flash
  • Lighting
  • Macro
  • Photojournalism
  • Sports Photography
"I saw another photographer using this bracket and I liked it, then bought it. The bracket is nice and useful. I love that the flash can be lifted up a lot and it can tilt horizontally. Also, the camera tilting mechanism is easy to use once you get the grip of it. The bracket is very well balanced, i …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 9 2008
Rekin
Miami, FL
I am:
  • Professional
Reviewed at:
Price: $111.59
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
