Tiffen 77UVP 77mm UV Protector Filter
4.4
based on 102 reviews
Ratings Distribution
5 star
59
4 star
31
3 star
6
2 star
2
1 star
4
Category Average
4.4
Low Price:
$31.95 at B&H Photo Video
 Trusted:
$31.95 at Adorama
Find it at Amazon
$31.95
from 3 stores
More Images
Pros
  • Clear optics (70)
  • Firm mount (64)
  • Well built / quality construction (55)
  • Easy to use (52)
  • Consistent effect (17)
  • Compact design (5)
  • Great picture quality (3)
  • Cheap (2)
  • Bargain (1)
  • Interfaces well with camcorder (1)
See less See more
Cons
  • Loose mount (2)
  • Causes lens flare (1)
  • Causes reflections (1)
  • Decreased performance (1)
  • Filter touches lens front (1)
  • Halo arount light sources (1)
  • Inconsistent clarity (1)
  • Inconsistent effect (1)
  • May need bigger lens cap (1)
  • No increase in performance (1)
Best Uses
  • Lens protection (76)
  • Uv protection (48)
  • Color correction (4)
  • Filter protection (4)
  • Shooting outdoors (4)
  • Close up filming (2)
  • Panoramic filming (2)
  • Shooting indoors (2)
  • Image manipulation (1)
  • Not usable (1)
Provided by B&H Photo Video
Tiffen 77mm UV Protector Glass Filters are wise initial investments. They help protect your valuable investment from dust, moisture and scratches, which can lead to costly repairs.
Specification Description
Model 77UVP
UPC 049383099454
Thread Size (Round) 77mm
Type Ultra Violet
Tiffen 77UVP 77mm UV Protector Filter Questions
Questions and Answers
Where to Buy
$31.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$31.95
$31.95
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Nov 16, 2009
Tiffen 77UVP 77mm UV Protector Filter Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Buy this!
"This is the very first accessory you should buy (actually for ANY lens)! You've just spent good money on a finely engineered chunk of glass---protect it! No matter how careful a photographer you are,no matter how often you use a lens cap, this filter is STILL about the wisest investment you can make. Tiffen makes a consistently great product, in a variety of sizes, which attaches smoothly & evenly----no distorti..." Read Full Review »
May 21, 2008 by AFRHPro
See more positive Tiffen 77UVP 77mm UV Protector Filter reviews
1.0
Keep away from the Tiffen 77mm UV filter
"I've bought this for my new EF 24-105mm f/4L IS lens. This was the first time I's buying a filter. I also bought other two Tiffen UV filters: a 52mm for EF 50mm f/1.8, and a 58mm for EF-S 18-55mm f/3.5-5.6 and Sigma 70-300 APO DG Macro f/4-5.6. While the other two are quite acceptable, the 77mm is bad. Most probably, I'll not use it at all. When the filter is fully fitted, it touches the front element of the le..." Read Full Review »
Jan 05, 2009 by Black the Jack
See more negative Tiffen 77UVP 77mm UV Protector Filter reviews
Displaying 1 - 5 of 102 Reviews
Show
Sort by
simply a MUST HAVE!
5.0
    Pros
  • Easy To Use
  • Firm Mount
    Cons
  • None
    Best Uses
  • Lens Protection
  • UV Protection
"it´s simply a must have... with 77mm you obviously own an imprtant piece of equipment...... PROTECT IT!!!! "
Was this Camera Filter review on the Tiffen 77UVP 77mm UV Protector Filter helpful to you?
Nov 16 2009
Lucho from Argentina
Buenos Aires, Argentina
I am:
  • Pro Photographer
Reviewed at:
Price: $31.95
1.0
    Pros
  • Firm Mount
    Cons
  • Optically bad
    Best Uses
  • Not usable
While the other two are quite acceptable, the 77mm is …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 5 2009
Black the Jack
San Jose, CA
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $31.95
[2 of 2 customers found this review helpful]
More trouble than good...
1.0
    Pros
  • None
    Cons
  • Decreased Performance
    Best Uses
  • None
"I found that this filter actually slowed my lens down. Camera metering selected faster shutter speeds across all apertures when the filter wasn't used and I never had this problem with other lens using UV protectors from different brands. The filter also induced flaring when my lens was wide open …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 11 2009
Larry
Plantation, FL
Reviewed at:
Price: $31.95
Buy this!
5.0
    Pros
  • Clear Optics
  • Consistent Effect
  • Firm Mount
  • Strong Construction
    Cons
    Best Uses
  • Color Correction
  • Lens Protection
  • UV Protection
(actually for ANY lens)! You've just spent good money on a finely engineered chunk of glass---protect it! No matter how careful a photographer you are,no matter how often you use a lens cap, this filter is STILL about the wisest investment you can mak …"  Read Full Review »
May 21 2008
AFRHPro
Washington DC
I am:
  • Professional
Reviewed at:
Price: $31.95
Nothing new to report.
5.0
    Pros
  • Clear Optics
  • Easy To Use
  • Firm Mount
    Cons
  • None
    Best Uses
  • Lens Protection
"Set it and forget it. The filter is a sturdy UV I use to protect the lens. Thats it. I'm not one of those obsessive compulsive photo tech nerds who analyze the UV coming through into my pictures. My photos still look great, the lens is protected, the filter is easy to clean. End of story. If y …"  Read Full Review »
Apr 8 2009
Chris
East Coast, U.S.A.
I am:
  • Photo Enthusiast
Reviewed at:
Price: $31.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
