Tiffen 58mm Linear Polarizing Glass Filter
3.9
based on 59 reviews
from $14.82 - $37.95
Ratings Distribution
5 star
16
4 star
29
3 star
9
2 star
2
1 star
3
Category Average
4.4
More Images
Pros
  • Clear optics (42)
  • Firm mount (30)
  • Well built / quality construction (26)
  • Consistent effect (18)
  • Easy to use (18)
  • Cheap (2)
  • Great picture quality (2)
  • Lightweight (1)
  • Mount a little shaky (1)
  • Nice case (1)
See less See more
Cons
  • Loose mount (2)
  • A bit hard to remove (1)
  • Didn't eliminate all (1)
  • Inconsistent effect (1)
  • Lacks more saturation (1)
  • Lens cap doesn't fit (1)
  • Moving filter (1)
  • Not coated (1)
  • Not linear (1)
Best Uses
  • Color correction (19)
  • Lens protection (19)
  • Image manipulation (13)
  • Uv protection (13)
  • Artwork (4)
  • Filter protection (3)
  • Color saturation (2)
  • Shooting outdoors (2)
  • Color intesifying (1)
  • Cut down reflections (1)
Provided by OneCall
Light rays which are reflected by any surface become polarized and Polarizing filters are used to select which light rays enter your camera lens. They allow you to remove unwanted reflections from non-metallic surfaces such as water, glass etc. They also enable colors to become more saturated and appear clearer, with better contrast. This effect is often used to increase the contrast and saturation in blue skies and white clouds. Polarizers do not affect the overall color balance of a shot. It is important that you choose the correct version of polarizer for your camera. Many of today's cameras use semi-silvered mirrors or prisms to split the light entering the viewfinder in order to calculate exposure and focusing distance. Polarizing filters can sometimes interact with these items to give unpredictable exposure or focusing. So we recommend that you choose a circular polarizer unless you have a manual focus camera which has no beam splitter. If you will be using your Polarizing filter on a lens which has a focal length of 28mm or wider (on a 35mm camera), we recommend that you use a Wide Circular Polarizer to avoid a possible vignette effect.
Specification Description
Model 2580A002, 58CP, 58POL
UPC 024066016652
Filter Diameter 58mm
Thread Size (Round) 58mm
Type Circular Polarizers
Type Linear Polarizers
Tiffen 58mm Linear Polarizing Glass Filter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 20, 2009
Tiffen 58mm Linear Polarizing Glass Filter Reviews
Most helpful positive review
Most helpful negative review
4.0
Tiffen 58 mm circular polarizer
"I use this for landscape shots in the mountains and especially if there is a lake or stream in the shot. It definitely results in a more dramatic blue sky in many situations. In other words it works as advertised and at a very reasonable price...." Read Full Review »
Sep 02, 2009 by Vegard
See more positive Tiffen 58mm Linear Polarizing Glass Filter reviews
2.0
nothing out of the ordinary
"for moderate enhancement, this is a good product. for maximum enhancement, go with another filter...." Read Full Review »
Nov 20, 2009 by Rachel
See more negative Tiffen 58mm Linear Polarizing Glass Filter reviews
Displaying 1 - 5 of 59 Reviews
Show
Sort by
4.0
    Pros
  • Clear Optics
  • Easy To Use
  • Firm Mount
    Cons
  • None
    Best Uses
  • Color Correction
"I use this for landscape shots in the mountains and especially if there is a lake or stream in the shot. It definitely results in a more dramatic blue sky in many situations. In other words it works as advertised and at a very reasonable price. "
  • Made with Product
Was this Camera Filter review on the Tiffen 58mm Linear Polarizing Glass Filter helpful to you?
Sep 2 2009
Vegard
Seattle
I am:
  • Photo Enthusiast
Reviewed at:
Price: $14.95
[3 of 3 customers found this review helpful]
Enhancing you images
4.0
    Pros
  • Clear Optics
  • Consistent Effect
  • Firm Mount
  • Strong Construction
    Cons
    Best Uses
  • Glare control
  • Image Enhancer
  • Saturation
  • UV Protection
"Although the Hoya circular polarizer (HMC) multi-coated glass filter by Hoya does achieve its objective, it falls somewhat short of a higher degree of saturation effect; however, this is no cause for dissappointment - please, read that I am reasonably satisfied with the product. I shoot outdoors vid …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jun 26 2008
Larry
San Juan, Puerto Rico
I am:
  • Professional
Reviewed at:
Price: $14.82
perfect fit for canon
4.0
    Pros
  • Clear Optics
  • Consistent Effect
  • Firm Mount
    Cons
    Best Uses
  • Artwork
  • Lens Protection
  • UV Protection
"I needed this filter to shoot original art prints that had been already mounted and framed under glass. The filter was great at removing high glare from my tripod and other components set up in front of the art. It didn't eliminate all the reflection though, so I had to also add matte black boards s …"  Read Full Review »
May 6 2008
ric
Lansing, MI
I am:
  • Professional
Reviewed at:
Price: $14.82
[2 of 2 customers found this review helpful]
Great Filter
5.0
    Pros
  • Clear Optics
  • Firm Mount
    Cons
  • None
    Best Uses
  • Color Correction
  • Lens Protection
"Outstanding filter. Produces great landscape pictures. I have been using this filter to take pictures along our local river parkway, and the reflections in the water are outstanding. The water and skies come out beautifully blue with very clear reflections in the water. Eliminates all the glare and …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 3 2008
Randy
West Haven, UT
I am:
  • Photo Enthusiast
Reviewed at:
Price: $14.82
This product is great!
5.0
    Pros
  • Clear Optics
  • Firm Mount
    Cons
  • None
    Best Uses
  • Artwork
  • Color Correction
  • Image Manipulation
"The polarizer is great for those bright, sunny days! It really brings out the blues of the sky and ocean, and the green of the trees and grass. I recommend a circular polarizer to anyone pursuing landscape/wildlife photography. "
Apr 29 2008
Capturing the Sublime
Bradenton, FL
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $14.82
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
