Tiffen 52TPK1 52mm 3-Piece Filter Kit - Polarizer, UVP, 812 Color Warming
4.2
based on 21 reviews
Ratings Distribution
5 star
8
4 star
9
3 star
4
2 star
0
1 star
0
Category Average
4.4
Low Price:
$32.50 at B&H Photo Video
 Trusted:
$32.50 at Adorama
Find it at Amazon
$32.50 - $48.49
from 4 stores
More Images
Pros
  • Clear optics (15)
  • Firm mount (13)
  • Well built / quality construction (12)
  • Easy to use (10)
  • Consistent effect (7)
  • Affordable (1)
See less See more
Cons
  • Inconsistent effect (1)
  • Loose mount (1)
  • Poor threads (1)
Best Uses
  • Lens protection (16)
  • Uv protection (14)
  • Color correction (5)
  • Image manipulation (5)
  • Filter protection (4)
  • Artwork (1)
  • Filter effects (1)
  • Polarization (1)
Provided by Dell
More economical than individual filter purchases. These multiple filter kits take the guesswork out of having a variety of creative filter effects at your fingertips. Pre-package assortments, with combinations of Tiffen's most popular filters, provide a range of artistic possibilities for almost every photographic application and budget.
Specification Description
Model 52TPK1, 52tpk1
UPC 049383156737
Thread Size (Round) 52mm
Tiffen 52TPK1 52mm 3-Piece Filter Kit - Polarizer, UVP, 812 Color Warming Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 1, 2009
Tiffen 52TPK1 52mm 3-Piece Filter Kit - Polarizer, UVP, 812 Color Warming Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
4.0
Slight difference
"I am new to using filter lenses that I don't really see that much difference. I bought this filter lens kit of three, to lessen the glare and protect my lens and so far, it's doing it's job that's why I am giving it a 4star. I still have to learn how to effectively use these filters in artistic way. I guess it will give me benefits in the future. It wasn't so expensive a[$] so I did not hesitate buying it...." Read Full Review »
May 04, 2009 by OliveTheNewbie
See more positive Tiffen 52TPK1 52mm 3-Piece Filter Kit - Polarizer, UVP, 812 Color Warming reviews
3.0
Good Basic Kit
"These filters do what they're supposed to do. I would like to point out that they are subject to flare though. These aren't multi-coated, so when you have lights in the shot you can get blobs showing up in the picture. This is why they come pretty cheap though. Also be a bit careful around the pouch. I started tearing some of the inner fabric on mine because of it. It isn't going to be falling apart any tim..." Read Full Review »
Jun 11, 2007 by soundman1024
See more negative Tiffen 52TPK1 52mm 3-Piece Filter Kit - Polarizer, UVP, 812 Color Warming reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
Slight difference
4.0
    Pros
  • Clear Optics
  • Easy To Use
    Cons
  • Inconsistent Effect
    Best Uses
  • Filter Protection
"I am new to using filter lenses that I don't really see that much difference. I bought this filter lens kit of three, to lessen the glare and protect my lens and so far, it's doing it's job that's why I am giving it a 4star. I still have to learn how to effectively use these filters in artistic way. …"  Read Full Review »
With polarizer
With polarizer
  • Made with Product
Was this Camera Filter review on the Tiffen 52TPK1 52mm 3-Piece Filter Kit - Polarizer, UVP, 812 Color Warming helpful to you?
 Report Abuse  (1)  (0)  0 comments
May 4 2009
OliveTheNewbie
NYC, NY
I am:
  • Photo Enthusiast
Reviewed at:
Price: $32.50
Good Basic Kit
3.0
    Pros
  • Consistent Effect
  • Firm Mount
  • Strong Construction
    Cons
  • None
    Best Uses
  • Color Correction
  • Lens Protection
  • UV Protection
Also be a bit careful around the p …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 11 2007
soundman1024
Saint Joseph, MO
I am:
  • Getting started
  • Hobbyist/Enthusiast
Reviewed at:
Price: $32.50
[3 of 3 customers found this review helpful]
Mediocre Lens Kit
3.0
    Pros
    Cons
  • Loose Mount
  • Poor Threads
    Best Uses
  • Lens Protection
  • UV Protection
"I originally bought this kit as I was looking to protect my lens- I thought this was a great buy for a polarizer, UV Filter, and a warming filter. The items arrived and had a LOT of dust/film on them, and I spent a good 30 minutes trying to remove smudges from the UV filter. I eventually gave up on …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Feb 6 2009
EA
Easton, PA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $32.50
seems to do what it is supposed to
3.0
    Pros
  • Clear Optics
  • Easy To Use
  • Firm Mount
    Cons
  • None
    Best Uses
  • Filter Protection
"I bought this set primarily to protect the lens, and for the polarizer. The UV coated filter does nothing noticeable to the picture, but it does mount firmly and doesn't impede clarity. The polarizer works reasonably well, depending on the angle of the sun. I haven't found it to dramatically heig …"  Read Full Review »
May 4 2009
velogirl
NYC
I am:
  • Casual Photographer
Reviewed at:
Price: $32.50
Ask questions before buying.
3.0
    Pros
  • Affordable
    Cons
  • None
    Best Uses
  • None
"I wish I had realized there was so much difference in filters. This kit was fairly cheap and included a variety of filters so I couldn't resist. After getting them I didn't feel they were as good of quality as the Tiffen 67mm I had gotten before. I should have asked more questions but didn't know …"  Read Full Review »
Jan 21 2008
Rudy
Wichita, KS
I am:
Reviewed at:
Price: $32.50
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
