TIC TFS6WG Terra-Forms Pro Outdoor Rock Speaker (Granite)
#700
2.0
based on 1 review
Ratings Distribution
5 star
0
4 star
0
3 star
0
2 star
1
1 star
0
Category Average
4.4
$149.99 at RadioShack
Find it at Amazon
Find it at Ebay
$149.99
from 1 store
Pros
  • Attractive design (1)
  • Easy to connect (1)
See less See more
Cons
  • Not durable (1)
  • Poor sound quality (1)
Best Uses
Provided by RadioShack
The TFS6WG Pro Outdoor Rock Speaker was designed to provide high-performance in an exterior rock speaker system.
Specification Description
Model TF-S6WG
Accessory Indicator Yes
Additional features 8" coaxial
Benefits Handles up to 75W continuous power (150W peak) for strong performanceTeflon-sealed internal cabinetry and drivers are part of an over
Cables Included 14/2 burial cable
Capacity UOM mAh
Connectivity technology Wired
Country Of Origin China
Crossover frequency 4500 Hz
Description Header Outdoor speaker delight.
Display Catalog Number 55017603
Features 35-20000Hz frequency response provides a broad sound range8-ohm and 70V switchable for commercial installations
Frequency response 60Hz-20kHz
Grille color White Granite
Impedance 8 ohms
Included in the Box Speaker39" 14/2 burial cable
Manufacturer Labor Warranty 12
Manufacturer Part Number TF-S6WG
Manufacturer Parts Warranty 12
MAP Price 0.0
Model TF-S6WG
Operating Temperature UOM ° F
Peak power 120 watts
Power range 150 watts
Product Depth 16
Product Dimensions UOM inches
Product Disclaimer Warranty is 1 year limited.
Product Height 11.9
Product Length 16
Product Type Home speakers
Product Weight 16
Product Weight UOM pounds
Product Width 12.1
RMS (continuous) power 60 watts
Sensitivity 91 dB
Speaker type Outdoor
Speakers included 1
Supported Languages English
Tweeter size 2 inches
Tweeter type Aluminum
Water resistant Yes
Woofer size 8 inches
Woofer type Injection-molded PP cone
TIC TFS6WG Terra-Forms Pro Outdoor Rock Speaker (Granite) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 13, 2008
TIC TFS6WG Terra-Forms Pro Outdoor Rock Speaker (Granite) Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
cheap components yield bad speaker
2.0
    Pros
  • Attractive Design
  • Easy To Connect
    Cons
  • Not Durable
  • Poor Sound Quality
    Best Uses
  • None
"The speaker cone for the dual driver eventually degrades due to cheap materials , despite being in a sealed housing . Also,. the granite coating flakes off and reveals the plain housing after about a year . Needs to be better constructed to last more than a couple of years. "
Was this Speaker & Subwoofer review on the TIC TFS6WG Terra-Forms Pro Outdoor Rock Speaker (Granite) helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 13 2008
timetoreplaceyetagain
new jersy
I am:
  • Audiophile
  • Tech Savvy
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
