Thermaltake TR2-R1 CPU Cooler
#4
4.6
based on 240 reviews
Ratings Distribution
5 star
169
4 star
52
3 star
7
2 star
7
1 star
5
Category Average
4.3
$9.00 - $11.99
from 8 stores
More Images
Cons
  • Unreliable (1)
Best Uses
Provided by RitzCamera.com
  • Silent Solution
  • Tool-less clip, easy installation
  • Perfect ratio aluminum extrusion heatsink for better heat dissipation
    Main Features
  • Manufacturer: Thermaltake Technology Co., Ltd
  • Manufacturer Part Number: A4022
  • Manufacturer Website Address: www.thermaltakeusa.com
  • Product Type: Processor - Cooling Fan & Heatsink
  • Fan Diameter: 3.62"
  • Fan Speed: 1300 rpm - +/- 30 %
  • Air Flow: 35.43 CFM
  • Noise Levels: 16 dB(A)
  • Fan Life: 50000 Hour(s)
  • Mounting Type: Clip Mount
  • Connectors: 3-pin TX3
  • Dimensions: 1.5" Height x 3.62" Width x 3.62" Depth - Fan, 1.81" Height x 4.02" Width x 4.02" Depth - Heatsink, 3.31" Height x 4.02" Width x 4.8" Depth
  • Weight: 16.93 oz
  • Additional Information:
  • Power Input: 1.56 W
  • Started Voltage: 7 V
  • Rated Voltage: 12 V
  • Rated Current: 0.13 A
  • Air Pressure: 1.50 mm H2O
  • Compatibility:
  • AMD Athlon 64 X2
  • Athlon 64 FX
  • Athlon 64 (Socket AM2, 939, 754)
  • Sempron (Socket 754)
  • Standard Warranty: 6 Year(s)
  • Thermaltake TR2-R1 CPU Cooler Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 26, 2009
    Thermaltake TR2-R1 CPU Cooler Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    This is my very first AMD ...
    "This is my very first AMD build EVER, and I emphasize EVER. I ordered the PC Chips and the AMD 3800+ combo, 1GB of ram, this heatsink, and a small chassis (will go in to details a little later). This heatsink keeps the the cpu at a nice 28-30C standard load. It fit on the socket nicely, nothing went wrong except for when i tried to put it in my chassis, it didn't fit how i planned (i got the Ultra MicroFly). It'..." Read Full Review »
    Feb 07, 2008 by Anonymous
    See more positive Thermaltake TR2-R1 CPU Cooler reviews
    3.0
    I bought this product and ...
    "I bought this product and had to return it because I couldn't mount it. I originally bought a Coolmaster Hyper 48 (which went belly up after only 2.5 years). The TR2 does NOT come with any PC board mounting hardware. Unfortunately it had no documentation either so I am assuming that it is intended to mount on existing pc mount hardware. In this case, the hold down springs lined up with the Coolmaster base ..." Read Full Review »
    Sep 09, 2009 by Chuck
    See more negative Thermaltake TR2-R1 CPU Cooler reviews
    Displaying 1 - 5 of 240 Reviews
    Show
    Sort by
    3.0
    "I bought this product and had to return it because I couldn't mount it. I originally bought a Coolmaster Hyper 48 (which went belly up after only 2.5 years). The TR2 does NOT come with any PC board mounting hardware. Unfortunately it had no documentation either so I am assuming that it is intende …"  Read Full Review »
    Was this Computer Fan & Cooling System review on the Thermaltake TR2-R1 CPU Cooler helpful to you?
    Sep 9 2009
    Chuck
    Undisclosed
    5.0
    "This is my very first AMD build EVER, and I emphasize EVER. I ordered the PC Chips and the AMD 3800+ combo, 1GB of ram, this heatsink, and a small chassis (will go in to details a little later). This heatsink keeps the the cpu at a nice 28-30C standard load. It fit on the socket nicely, nothing went …"  Read Full Review »
    Feb 7 2008
    Undisclosed
    Fan was a Dud
    1.0
      Pros
    • None
      Cons
    • Unreliable
      Best Uses
    • None
    "The price[...] were good, but the fan was a dud and would not run even after trying it in several connections. For a few bucks, can replace it so did not bother with all of the hassle to return it. Would not buy this product. "
    Aug 18 2009
    Paul
    Maumelle, Arkansas
    I am:
    • Frequent User
    Reviewed at:
    Price: $11.99
    Well when i bought this ...
    3.0
    "Well when i bought this cooling fan i bought my MOBO and cpu too...and well my Asus M2N32-SLI Deluxe Wireless Edition NVIDIA Socket AM2 ATX Motherboard comes with a cooling device around the cpu and when i went to install this cooling fan i found out that because of the size of this fan/heatsink th …"  Read Full Review »
    Aug 7 2007
    Pattycakes
    Undisclosed
    OK, i needed a fan other ...
    4.0
    "OK, i needed a fan other than the one they ship with the CPU. But, since this was a PC i was building and going to have to ship, needed one not as HUGE as the ones I use.
    This was perfect. It is basically a nice oversized CPU cooler. Not fancy, but, it is on a Quad core AMD, keeps it around 35-37c, …"  Read Full Review »
    Jul 15 2009
    dptazzz
    Undisclosed
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
