Thermaltake TR2 430W AC Power Supply
#6
4.6
based on 166 reviews
Ratings Distribution
5 star
128
4 star
24
3 star
2
2 star
6
1 star
6
Category Average
4.3
Low Price:
$29.99 at CompUSA
 Trusted:
$39.99 at TigerDirect
$34.98 at Mwave.com
see all stores
$29.99 - $50.78
from 13 stores
More Images
Pros
  • Easy to install (3)
  • Fast (1)
  • Good cord length (1)
  • Good mix of molex sata (1)
  • Good power fit (1)
  • Highly compatible (1)
  • Quiet (1)
  • Reliable (1)
See less See more
Cons
  • Low amperage per 12v rail (1)
  • Overpriced (1)
  • Unreliable (1)
Best Uses
  • Computers (2)
  • Editing spread sheets g (1)
  • High-end multimedia (1)
  • Low power need (1)
Provided by RitzCamera.com
Main Features
  • Manufacturer: Thermaltake Technology Co., Ltd
  • Manufacturer Part Number: W0070RUC
  • Manufacturer Website Address: www.thermaltakeusa.com
  • Product Type: ATX Power Supply
  • Fans: 80mm Dual Low Noise Fan
  • Compatibility:
  • Intel
  • AMD
  • Input Voltage: 115V AC to 230V AC
  • Current: 9A @ 115V AC - Input Current, 5A @ 230V AC - Input Current
  • Output Power: 430 W Maximum
  • Weight: 5.73 lb
  • Specification Description
    Model W0070RUC
    UPC 841163006443
    Accessory Indicator Yes
    Benefits Support 6-pin PCI-Express connectorPFC function, improved energy efficiency and reduced-current load on AC delivery systemsD
    Cables Included Power cord, Main connector cable with 24-pin main connector, 4-pin +12V (1), 4-pin peripheral connectors (9), 4-pin FD connectors (2), 5-pin SATA (2),
    Capacity UOM mAh
    Country Of Origin China
    Description Header Power up!
    Display Catalog Number 55026058
    Features Input voltage 115 VAC/230 VAC; input-frequency range 47 ~ 63HzInput current 9.0A/5.0AHold-up time 16ms; efficiency > 65%
    Included in the Box Thermaltake TR2 430W power supplyPower cordMain connector cable with 24-pin main connector, 4-pin +12V (1), 4-pin peripheral
    Manufacturer Labor Warranty 3
    Manufacturer Part Number W0070RUC
    Manufacturer Parts Warranty 3
    MAP Price 0.0
    Model W0070RUC
    Operating Temperature UOM ° F
    Product Dimensions UOM inches
    Product Height 3.4
    Product Length 6.3
    Product Type 401-500W
    Product Weight 5.73
    Product Weight UOM pounds
    Product Width 6
    Supported Languages English
    Thermaltake TR2 430W AC Power Supply Questions
    Questions and Answers
    Where to Buy
    $39.99
    $1.99 Shipping On Orders Over $100 at TigerDirect
    BizRate Rating Outstanding 9.1
    $39.99
    $10 Off Orders Of Orders Over $85 + Free Shipping
    $29.99
    $1.99 Shipping on Orders Over $75 ends 12/31/09
    Show all 13 stores
    Product Reviews
    Last update: Oct 26, 2009
    Thermaltake TR2 430W AC Power Supply Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    My TR450 watt is a Great power supply
    "I don't know what Bart's problem is, "But" I've had the 450 watt power supply in my back up computer for 2 years and have had no problems! I'm now replacing the power supply in my main computer from a 250 watt to the TR2 430 watt power supply and can't wait for it to get here! I want to thank Thermaltake for a good, reliable product and hope my new unit is just as worry free as my other one!..." Read Full Review »
    Oct 02, 2008 by ChrisW
    See more positive Thermaltake TR2 430W AC Power Supply reviews
    2.0
    Nope
    "I bought this in a pinch when I needed a supply right now & the one I ordered wouldn't be here for a couple days. It has a many connectors including SATA. Unfortunately, the amperage is low & should only be used for a base system that doesn't have multipel HDDs, big graphics cards & multiple drives. You can get better ones for less...." Read Full Review »
    May 14, 2009 by CrackerJacker
    See more negative Thermaltake TR2 430W AC Power Supply reviews
    Displaying 1 - 5 of 166 Reviews
    Show
    Sort by
    5.0
      Pros
    • Easy To Install
    • Fast
    • Highly Compatible
    • Quiet
    • Reliable
      Cons
    • None
      Best Uses
    • High-End Multimedia
    I want to thank Th …"  Read Full Review »
    Was this Surge Protector review on the Thermaltake TR2 430W AC Power Supply helpful to you?
    Oct 2 2008
    ChrisW
    Redding, CA
    I am:
    • Heavy Duty User
    Reviewed at:
    Price: $39.99
    Nope
    2.0
      Pros
    • Easy installation
    • Good Cord Length
    • Good mix of molex SATA
      Cons
    • Low amperage per 12V rail
    • Overpriced
      Best Uses
    • Computers
    • Low power need
    "I bought this in a pinch when I needed a supply right now & the one I ordered wouldn't be here for a couple days. It has a many connectors including SATA. Unfortunately, the amperage is low & should only be used for a base system that doesn't have multipel HDDs, big graphics cards & multiple drives. …"  Read Full Review »
    May 14 2009
    CrackerJacker
    Harrisburg, PA
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $39.99
    LOL this review below me ...
    5.0
    "LOL this review below me is HILARIOUS! I've used these power supplies many times and have never had a problem with them! Thermaltake makes a very sharp power supply - everything they make is ''truepower'' the standard for high end computing! Not to say the BEST but on the road without the price ta …"  Read Full Review »
    Mar 7 2009
    cotamotor
    Undisclosed
    Reviewed at:
    Price: $39.99
    This power supply is ...
    2.0
    "This power supply is atrocious... I spent 6 hours just trying to rout the cables cause they were as stiff as a log... After i finished killing myself with the routing i went on to plug everything in. The ATX 30 pin power for the motherboard was missing some wires. I went on and plugged it in anyways …"  Read Full Review »
    Feb 24 2009
    Undisclosed
    Reviewed at:
    Price: $39.99
    I purchased this unit ...
    1.0
    "I purchased this unit 5/28/07. Last night, 3 months and a week later, I opened my PC to install additional RAM. I noticed this power supply was throwing off a lot of heat internally. Upon closer examination I saw that neither the front nor rear fan in the supply were spinning.
    The supply was still …"  Read Full Review »
    Sep 7 2007
    kevin
    Undisclosed
    Reviewed at:
    Price: $39.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
