Thermaltake Silent 775D Processor Heatsink and Cooling Fan
#256
4.1
based on 125 reviews
Ratings Distribution
5 star
71
4 star
26
3 star
10
2 star
8
1 star
10
Category Average
4.3
$24.00 - $42.99
from 12 stores
More Images
Provided by photoalley.com
  • Copper base contact heat source directly
  • 4 heatpipes, provide maximum cooling
  • Heatpipe penetrate fin and seamless soldering process, ensure the best contact for heat transfer
  • Push-pin design, easy to install
    Main Features
  • Manufacturer: Thermaltake Technology Co., Ltd
  • Manufacturer Part Number: CL-P0378
  • Manufacturer Website Address: www.thermaltakeusa.com
  • Product Type: Processor - Heatsink & Cooling Fan with Heat Pipes
  • Fan Diameter: 3.54"
  • Fan Speed: 2500 rpm
  • Air Flow: 41.41 CFM
  • Mounting Type: Push-pin
  • Cooler Type: Thermo-Electric
  • Connectors: 4-pin LP4
  • Dimensions: 3.35" Height x 3.66" Width x 4.13" Length - Silent 775D, 3.54" x 3.54" x 0.98" - Fan
  • Weight: 13.47 oz
  • Additional Information:
  • Noise Level: 21dBA
  • Number of Fins: 58
  • Life Time: 30,000 Hours
  • Heatpipe: 6mm Copper Tube x 4pcs
  • Compatibility:
    Intel Socket LGA775 Processors:
  • Core 2 Duo
  • Core 2 Exterme
  • Celeron D
  • Pentium D
  • Pentium 4
  • Pentium Extreme Edition
  • Specification Description
    Model 57553, CL-P0378
    UPC 841163019771
    Application Processor
    Type Heatsink & Cooling Fan with Heat Pipes
    Thermaltake Silent 775D Processor Heatsink and Cooling Fan Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 26, 2009
    Thermaltake Silent 775D Processor Heatsink and Cooling Fan Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    Have this installed on a ...
    "Have this installed on a Core2 Quad q6600. It idles around 34-38 celsius and the hottest I've seen it is 47 while playing Crysis. The fan is silent. Install is easy - here's what I did. To install use a flat blade screwdriver rather than your fingers. Line up the pins, then use the screwdriver to push straight down on the pins till you hear the 'click'. I installed diagonally - one corner then the diagon..." Read Full Review »
    Feb 09, 2008 by rcy
    See more positive Thermaltake Silent 775D Processor Heatsink and Cooling Fan reviews
    2.0
    Unhappy with fan. Bought ...
    "Unhappy with fan. Bought it with a TigerDirect barebones bundle and it didn't fit the case/motherboard/combo in the bundle. Used it elsewhere on a Pentium D 925 3.0ghz in a Thermaltake case and it can't keep the CPU from entering thermal shutdown. This fan is also very problematic to install. Those pesky clips just keep popping out. Ease of use gets a zero star out of five rating. The case it's in is a th..." Read Full Review »
    May 10, 2008 by wirez
    See more negative Thermaltake Silent 775D Processor Heatsink and Cooling Fan reviews
    Displaying 1 - 5 of 125 Reviews
    Show
    Sort by
    2.0
    "Unhappy with fan. Bought it with a TigerDirect barebones bundle and it didn't fit the case/motherboard/combo in the bundle. Used it elsewhere on a Pentium D 925 3.0ghz in a Thermaltake case and it can't keep the CPU from entering thermal shutdown. This fan is also very problematic to install. Th …"  Read Full Review »
    Was this Computer Fan & Cooling System review on the Thermaltake Silent 775D Processor Heatsink and Cooling Fan helpful to you?
    May 10 2008
    wirez
    Undisclosed
    This fan is simply not ...
    3.0
    "This fan is simply not worth it. Great fan and works well, but as MANY have said before, it has a TERRIBLE fastener system. Even if it works, you can never be sure if those cheesy little plastic clips will stay put, or randomly pop out on you. I fussed and fussed with those clips and while I was ins …"  Read Full Review »
    Apr 25 2008
    BuildAGood
    Undisclosed
    5.0
    Install is easy - here's what I did. To install use a flat blade screwdriver rather than your fingers. Line up the pins, then use the screwdrive …"  Read Full Review »
    Feb 9 2008
    rcy
    Undisclosed
    Avoid this one: LOUD above idle and mediocre performance
    1.0
    "If you have this processor, you'll want to make sure your CPU fan is dynamically controlled, meaning your computer adjusts the fan speed based on how hot the processor is.
    At idle (when the processor is doing very little work) this fan is actually very quiet. However, as soon as you start to do an …"  Read Full Review »
    Sep 28 2007
    webgrunt
    Reviewed at:
    Price: $42.99
    I bought this cooler ...
    5.0
    "I bought this cooler because my Coolmaster was not keeping my p4 3.2 cool playing Urban Terror. It was running at 60c idle and over 75c under load. The installation was a snap, though I had to remove my mother board to take off the plastic backing that held the screws for the Coolmaster. It fit my A …"  Read Full Review »
    Jul 6 2009
    chewtoy
    Undisclosed
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
