Thermaltake PurePower 500W ATX 12V 2.0 Power Supply
4.8
based on 35 reviews
from $59.99 - $87.68
Ratings Distribution
5 star
29
4 star
5
3 star
0
2 star
1
1 star
0
Category Average
4.3
More Images
Pros
  • Quiet (4)
  • Reliable (4)
  • Easy to install (3)
  • Highly compatible (3)
  • Fast (2)
  • A lot of power (1)
  • Durable (1)
  • Good value (1)
  • High quality (1)
See less See more
Cons
  • Cables are clumsy (1)
Best Uses
  • Gaming (2)
  • High-end multimedia (2)
  • Home computer (1)
  • Powering a subwoofer amp (1)
Provided by RadioShack
A perfect power solution for a wide variety of hardware combinations.
Specification Description
Model W0100RU
UPC 841163013397
Accessory Indicator Yes
Benefits Intelligent Cable Management: black cable sleeving for optimum air-flowComplies with ATX 12V 2.0 VersionSupport 6-pin PCI-Ex
Body Material Metal
Cables Included Cable with 24-pin main connector, Cable with 4-pin+12V power connector, Cable with (8) 4-pin peripheral power connectors, Cable with (2) 4-pin floppy
Capacity UOM mAh
Country Of Origin China
Description Header Get pure power from this Tt PurePower.
Display Catalog Number 55026704
Features Dual 12V railsCooling System: (1) 12cm fan, speed: 2400 RPM(+/-10%)Noise 19dB at 2000RPMP.G. Signal 100-500 ms
Included in the Box PurePower 500W ATX 12V 2.0 version power supplyOwner's manualAccessory box (misc hardware)Cable with 24-pin main co
Manufacturer Labor Warranty 3
Manufacturer Part Number W0100RU
Manufacturer Parts Warranty 3
MAP Price 0.0
Model W0100RU
Operating Temperature UOM ° F
Product Depth 5.9
Product Dimensions UOM inches
Product Height 3.4
Product Type 401-500W
Product Weight 3.7
Product Weight UOM pounds
Product Width 5.5
Supported Languages English
Thermaltake PurePower 500W ATX 12V 2.0 Power Supply Questions
Questions and Answers
Where to Buy
$59.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$64.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$59.99
$1.99 Shipping on Orders Over $75 ends 12/31/09
Show all 8 stores
_
Product Reviews
Last update: Nov 15, 2009
Thermaltake PurePower 500W ATX 12V 2.0 Power Supply Reviews
Most helpful positive review
[0 of 1 customers found this review helpful]
Most helpful negative review
4.0
Exceptionally Good PSU!
"This is a very nice PSU. It came neatly boxed, with all required hardware - even ATX screws. The only thing that bothers me is that the cables are non-detachable from the PSU, so they cannot be customized. However, I knew this before buying. It was shipped directly from Thermaltake to my house, so you are not getting something old...." Read Full Review »
Feb 12, 2009 by Compumind
See more positive Thermaltake PurePower 500W ATX 12V 2.0 Power Supply reviews
2.0
I bought this product im ...
"I bought this product im March '09 and it just died - 5 months later! Just had Mobo, vid card and proc running in the system. 500w was more than enough juice...." Read Full Review »
Aug 23, 2009 by Sliderjon
See more negative Thermaltake PurePower 500W ATX 12V 2.0 Power Supply reviews
Displaying 1 - 5 of 35 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Install
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • Cables are clumsy
    Best Uses
  • Gaming
  • High-End Multimedia
It was shipped directly from Thermaltake to my house, s …"  Read Full Review »
Was this Computer Component review on the Thermaltake PurePower 500W ATX 12V 2.0 Power Supply helpful to you?
 Report Abuse  (0)  (1)  0 comments
Feb 12 2009
Compumind
New York, NY
I am:
  • Heavy Duty User
Reviewed at:
Price: $64.99
would buy another one
5.0
    Pros
  • A lot of power
  • Quiet
  • Reliable
    Cons
  • Non
    Best Uses
"i am not using it for a computer instead i am using it to power a 750 watt car amp, you use the 12 volt wires and the ground wires and put a paper clip between the green ps-on wire and a ground wire so it will turn on without motherboard "
Sep 6 2009
subwoofer lover
dewitt, mi
I am:
  • Heavy Duty User
Reviewed at:
Price: $64.99
I've owned one of these ...
5.0
"I've owned one of these in the past and it ran for 24 hours a day 7 days a week for over 2 years. Can't beat the price for performance on this power supply. It's not a fancy light show under powered supply like you see usually at thsi price level. This one is powerful, quiet and cooling is very a …"  Read Full Review »
Oct 26 2009
CompuTech007
Undisclosed
Reviewed at:
Price: $59.99
I would buy this product again and again
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • Gaming
"This unit has plenty of room to add too. For the price you can't beat a good upgrade like this one! I'll be getting at least two more for other builds I'm working on... COOL! "
May 11 2009
Brett
Holly, MI
I am:
  • Frequent User
Reviewed at:
Price: $64.99
A Best Buy!!!!!!!!
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • none
    Best Uses
  • Home Computer
"Thermal take = HIGhest Quality. I was Awed by the great finish it fit the case perfectly.No Problems installing it and Now I have THE power!!!! I will need it for the lights I Plan to install Later!
Will Buy again for next build!!!! "
Jun 16 2008
MACKDANNY
Athens TX USA
Reviewed at:
Price: $64.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
