Thermaltake Armor VA8000 System Cabinet
#153
4.7
based on 3 reviews
from $149.99
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.3
$149.99 at RadioShack
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Durable (3)
  • Attractive design (2)
  • Big (1)
  • Easy to install (1)
  • Good value (1)
  • High quality (1)
  • Quiet (1)
  • Spacious (1)
See less See more
Cons
  • Heavy with 5 hhd 2cddvd (1)
Best Uses
  • Gaming (2)
  • Multimedia (2)
  • Office (2)
  • Upgrade (2)
  • Home (1)
  • Replacement (1)
Provided by Shoppers Choice
MODEL- ARMORBLACK VENDOR- THERMALTAKE FEATURES- Armor Full-Tower Case- Black finish Full-tower aluminum case with side panel window. Air Cooling System with dual rear exhaust, top exhaust and front intake. Totally Fanless thermal system validated (Fanless CPU/VGA cooler, fanless PSU, fanless chassis are supported and tested by Thermaltake. ) Optional BTX upgrade kit. Removable HDD case and tool-free installation for 5. 25 inch drives. Dual USB 2. 0, IEEE-1394a/FireWire, Audio & Speakers ports. Relocatable front conrol panel (Power, Reset switch, HDD & PWR LEDs). Screwless slots for easy assembly. 3. 5 inch HDD modules with 12cm fan holds three hard drives. Retractable foot stand and side panel lock. Extra large thumb screws for easy open side panel. Accessory box bundled in 5. 25 inch drive bay. HDD & FDD rack is relocatable. -- SPECIFICATIONs ---------------------------------SIDE PANEL - Transparent side panelCOOLING SYSTEM- Front (intake): 120 x 120 x 25 mm, 1300 RPM, 17 dBA includes blue LED fan Rear (exhaust): 120 x 120 x 25 mm, 1300 RPM, 17 dBA includes blue LED fan 90 x 90 x 25 mm, 1800 RPM, 19 dBA Top (exhause): 90 x 90 x 25 mm, 1800 RPM, 19 dBADRIVE BAYS - External: (10) 5. 25 inch bays ( 2) 3. 50 inch bays Internal: ( 6) 3. 50 inch baysEXPANSION - 7 slotsI/O PORTS - (2) USB 2. 0 ports (1) IEEE-1394a/FireWire port (2) Audio ports MATERIAL - Chassis: 1. 0 mm SECC Front Door: aluminumMOTHERBOARDS - Accepts Micro ATX, ATX, Extend ATX, BTX (with option). POWER- No power supply includedSIZE - 220mm w x 530mm h x 560mm d WT. - 7. 5 Kg. Www. Thermaltake. Com
Specification Description
Model ARMORBLACK, VA8000BWS
UPC 839200051280
Accessory Indicator Yes
Benefits 11 5.25" drive bays and 6 3.5" drive bays for maximum flexibilityDesigned for a fanless installation if that is your desireE
Capacity UOM mAh
Country Of Origin China
Description Header Protect your components with this Armor.
Display Catalog Number 55025691
Enclosure Color Black
Features Compatible with ATX and BTX*Tool-free installation for 5.25" devices, removeable HDD cage(3) 3.5" HDD module with 12cm blue
Included in the Box Thermaltake Armor SECC Super Tower (Black)Owner's manualHardware pkg
Manufacturer Labor Warranty 3
Manufacturer Part Number VA8000BWS
Manufacturer Parts Warranty 3
MAP Price 0.0
Model VA8000BWS
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer *BTX requires an optional upgrade kit, not included.
Product Height 20.86
Product Length 22.04
Product Type Tower
Product Weight 35.71
Product Weight UOM pounds
Product Width 8.66
Supported Languages English
Thermaltake Armor VA8000 System Cabinet Questions
Questions and Answers
Where to Buy
$149.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Mar 25, 2009
Thermaltake Armor VA8000 System Cabinet Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Awesome case, but a little dusty
4.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"I've had this case since it cost almost 3 times what it's being sold for here, and I've loved it. Tons of space for just about anything you would want to put in it. All the fans are super quiet and the front fan even has a dust screen, the benefits of which are negated however by the big open ventil …"  Read Full Review »
Was this Computer Casing review on the Thermaltake Armor VA8000 System Cabinet helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 28 2007
LABurns
Pasedena, CA
Reviewed at:
Price: $149.99
Big and Tough
5.0
    Pros
  • Attractive Design
  • Big
  • Durable
  • Easy To Install
  • Quiet
    Cons
  • None
    Best Uses
  • Gaming
  • Multimedia
  • Office
  • Upgrade
"i liked it mostly for all the case space its great for if its your'e first build or you just wanna move parts from an old case its very flexable and has all your'e needs! "
Mar 25 2009
Jonathan P.
Kenner, LA
I am:
  • Heavy Duty User
Reviewed at:
Price: $149.99
Excellent & Solid Case
5.0
    Pros
  • Attractive Design
  • Durable
  • Spacious
    Cons
  • Heavy with 5 HHD 2CDDVD
    Best Uses
  • Gaming
  • Home
  • Multimedia
  • Office
  • Replacement
  • More »
"I use this case for my powerhouse pc....Intel QUAD 9650 , RAID 10...plenty of room for cooling and expansion..ultra-quiet fans. "
Dec 27 2007
tenchobuff_hp
Dartmouth, MA
I am:
  • Heavy Duty User
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
