Terk Low-Profile Indoor TV Antenna
#10
3.9
based on 59 reviews
Ratings Distribution
5 star
23
4 star
23
3 star
3
2 star
7
1 star
3
Category Average
3.6
$18.99 - $49.00
from 6 stores
More Images
Pros
  • Easy setup (54)
  • Durable (34)
  • Strong signal (32)
  • Attractive design (13)
  • Fine-tuning (6)
  • Decent-not great-signal (1)
  • Design (1)
  • Easy assembly (1)
  • Easy connection (1)
  • Easy to adust (1)
See less See more
Cons
  • Poor reception (10)
  • Bulky (5)
  • Flimsy (4)
  • Unattractive design (4)
  • Appearance needs some wor (1)
  • Channel 5 not viewable (1)
  • Digital not until june (1)
  • Fine tuning so-so (1)
  • Large (1)
  • Limited reception (1)
Best Uses
  • Living room (31)
  • Bedroom (28)
  • Small rooms (17)
  • Office (8)
  • Portable devices (4)
  • Kitchen (2)
  • Closer to window best (1)
  • Door stop (1)
  • Family room (1)
  • Garage (1)
Provided by OneCall
The TV4 low-profile antenna is a perfect set-top antenna for use in urban or suburban areas. TV4 combines a high-performance antenna with a low-profile design that fits on top of any television, and even fits inside most TV cabinets. TV4 features TERK`s unique Complementary Symmetry technology, incorporating a pair of tuned receiving elements for excellent reception range and clarity.
TV4`s revolutionary design allows the antenna to stand less than 4-3/4 inches high while delivering outstanding reception. Unlike the frustrating trial and error method of adjusting conventional antennas, a simple rotation obtains optimum reception. TERK`s indoor television antennas are engineered with premium materials resulting in a durable, high-performance antenna that will look great on any TV for years to come.
Features:
Perfect set-top antenna in urban or suburban areas
Low-profile design stands just 4-3/4" high and fits inside most television cabinets
Ultra-small footprint allows antenna to rotate freely atop most televisions
Includes both VHF and UHF capability for reception of channels 2 through 69
Includes VHF/UHF band separator and 75-300 ohm matching transformer for easy hook-up to any television set
6 ft. long 75 ohm cable allows the antenna to be installed on even the largest rear projection televisions
Non-skid silicon base ensures maximum stability on any set-top
Specification Description
Model TV-4, TV4
UPC 034405000426
Accessory Indicator Yes
Benefits Streamlined design fits inside most television cabinets alongside your other componentsEasy to install and adjust, so you can fine-tu
Capacity UOM mAh
Country Of Origin China
Description Header Rabbit ears: evolved.
Display Catalog Number 55017644
Manufacturer Labor Warranty 12
Manufacturer Part Number TV-4
Manufacturer Parts Warranty 12
MAP Price 0.0
Model TV-4
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type UHF/VHF
Product Weight UOM pounds
Supported Languages English
Terk Low-Profile Indoor TV Antenna Questions
Questions and Answers
Where to Buy
$19.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$19.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$18.99
Code FALLSAVINGS33 : $5 Off Orders Over $50
Show all 6 stores
Product Reviews
Last update: Nov 16, 2009
Terk Low-Profile Indoor TV Antenna Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
Excellent Antenna & Value
"I live in a basement (garden) apartment on the northside of Chicago. Reception with past amplified antennas I purchased from the big box stores has been terrible and unreliable. This TERK antenna hits the mark on all counts. Consistent reliable signal, easy to set up, modern with small footprint, and a great value. I would recommend this antenna to all others who are in the market for a reliable indoor VHF/UHF a..." Read Full Review »
Apr 19, 2009 by Finn the Irishman
See more positive Terk Low-Profile Indoor TV Antenna reviews
2.0
not what I expected
"This antenna receives a slightly stronger signal than my old $5 one. However, it only gets roughly 3 channels downstairs so I had to use it upstairs. It is much larger than I expected, but still short enough if you have a small space where "rabbit ears" would not fit. It was inexpensive compared to some, but the even cheaper ones would probably work just as well...." Read Full Review »
May 04, 2009 by pocketfullofsunshine
See more negative Terk Low-Profile Indoor TV Antenna reviews
Displaying 1 - 5 of 59 Reviews
Show
Sort by
not what I expected
2.0
    Pros
  • Durable
  • Easy To Set Up
    Cons
  • Bulky
  • Poor Reception
    Best Uses
  • Bedroom
"This antenna receives a slightly stronger signal than my old $5 one. However, it only gets roughly 3 channels downstairs so I had to use it upstairs. It is much larger than I expected, but still short enough if you have a small space where "rabbit ears" would not fit. It was inexpensive compared t …"  Read Full Review »
Was this Antenna review on the Terk Low-Profile Indoor TV Antenna helpful to you?
 Report Abuse  (4)  (0)  0 comments
May 4 2009
DeBary, FL
I am:
  • Casual User
Reviewed at:
Price: $19.99
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Living Room
"I live in a basement (garden) apartment on the northside of Chicago. Reception with past amplified antennas I purchased from the big box stores has been terrible and unreliable. This TERK antenna hits the mark on all counts. Consistent reliable signal, easy to set up, modern with small footprint, an …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Apr 19 2009
Finn the Irishman
Chicago, Illinois
I am:
  • Enthusiast
Reviewed at:
Price: $19.99
[6 of 7 customers found this review helpful]
Great performance for the buck...
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Living Room
"This is my primary source for HD. I haven't taken the step to upgrade to HD satellite service. This antenna is all I need for great reception. Rarely does it need to be adjusted to pick up a signal and i get everything up and down the spectrum. "
 Report Abuse  (6)  (1)  0 comments
Feb 25 2008
Brian
Torrance, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $19.99
No Thanks
1.0
    Pros
  • None
    Cons
  • Bulky
  • Poor Reception
  • Unattractive Design
    Best Uses
  • None
"This antenna is "unsightly" and much bulkier than you would think. Bought this antenna for our boat as the marina doesn't allow dish's or provide cable. The Terk TV 4 did not provide reception as well as the [$]RCA basic antenna we were using. We had hoped that this antenna would work well with th …"  Read Full Review »
Nov 16 2009
First Mate
Seattle Wa
Reviewed at:
Price: $19.99
Rabbit Ears Worked Better
2.0
    Pros
  • Easy To Set Up
    Cons
  • Flimsy
  • Poor Reception
    Best Uses
  • Return To Store
"Set it up on first floor of a one story house near front door and limited tree coverage nearby. Hooked up to TV and quickly discovered that standard rabbit ear antenna worked better than this product. In fact, this product did not work at all - no reception whatsoever. It is much smaller than the …"  Read Full Review »
Oct 29 2009
MyAmishHead
Port Clinton, OH
I am:
  • Casual User
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$19.95
$19.99
$18.99
$19.93
$27.99
Code KMART5OFF50 : Save $5 off $50 with coupon
$49.00
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
