Terk HDTVS Outdoor HDTV Antenna
#73
3.7
based on 10 reviews
from $90.48 - $149.99
Ratings Distribution
5 star
3
4 star
4
3 star
1
2 star
1
1 star
1
Category Average
3.6
Low Price:
$90.48 at NuGadgets
 Trusted:
$91.99 at B&H Photo Video
Find it at Amazon
More Images
Pros
  • Durable (7)
  • Easy setup (6)
  • Strong signal (5)
  • Attractive design (2)
  • Fine-tuning (2)
  • Does wonders around city (1)
  • Great picture quality (1)
  • Great reception (1)
  • Needed a amp (1)
  • Small footprint (1)
See less See more
Cons
  • Poor reception / weak antenna (2)
  • Does not improve audio/video (1)
  • Heavy / bulky (1)
Best Uses
  • Home (2)
  • Attic/roof mount (1)
  • Bedroom (1)
  • Dorm room (1)
  • Hd antenna (1)
  • Living room (1)
  • Office (1)
  • Out-side (1)
  • Outdoors (1)
  • Tv (1)
Provided by MAGo Enterprise
MODEL- HDTVs VENDOR- AUDIOVOX ELECTRONICS FEATURES- Terk Outdoor UHF/VHF HDTV AntennaIf you want reliable digital TV reception and you live in a city -- or you simply do not have room for a large antenna -- the HDTVs is the perfect solution. It is compact yet powerful enough to reel in your local HDTV broadcasts as well as standard analog UHF and VHF channels. The HDTVs features an innovative design that is great at receiving reflected signals. So even if a TV station transmits from the other side of your high-rise apartment building this antenna can zero in on signals bounced off of the buildings around you. And thanks to its included hardware you can mount this antenna on a roof railing outdoor wall or in an attic. If you want it to blend in visually you can even paint the antenna's plastic housing! * Passive (non-amplified) directional antenna optimized for HDTV. * VHF and UHF capability for reception of channels 2-69 * Adjustable antenna element for optimal signal reception * Mounting mast and foot included with required mounting screws * 15-3/4W x 29-1/2H x 9D
Specification Description
Model HD-TVS, HDTV-S, HDTVS, HDTVs
UPC 034405002338
Accessory Indicator Yes
Benefits Specifically designed to capture reflected off-air HDTV and DTV signalsCEA color code: RedSlim profile antenna receives both
Capacity UOM mAh
Country Of Origin United States
Description Header Get channels you didn't even know where there.
Display Catalog Number 55026153
Included in the Box Terk antennaMounting mastFoot bracketMounting hardware
Manufacturer Labor Warranty 12
Manufacturer Part Number HD-TVS
Manufacturer Parts Warranty 12
MAP Price 0.0
Model HD-TVS
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 29.5
Product Length 15.8
Product Type HDTV
Product Weight UOM pounds
Product Width 9
Supported Languages English
Terk HDTVS Outdoor HDTV Antenna Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 19, 2009
Terk HDTVS Outdoor HDTV Antenna Reviews
Most helpful positive review
[12 of 12 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
TERK HDTV antenna delivers just like J&R
"I set this little guy up in my attic first to replace the mommoth that wasn't picking up my HD during cloudy days. Immediately I picked up all my stations plus some subs I hadn't before. I'm 45 miles from the repeater, antennaweb said I needed red, this one is perfect for long distances. J&R delivered this faster than I was expecting. I'd say this is the best HD antenna on the market, and yes it does make a diff..." Read Full Review »
Jun 18, 2008 by McPace
See more positive Terk HDTVS Outdoor HDTV Antenna reviews
2.0
review: Terk Slim Profile Outdoor HDTV A
"Full disclosure: I have not yet mounted the device on the outside of the house. I experimented with it free standing with sign line to the transmitters.This product works, but does not appreciably improve reception over what I got with my old analog in door antenna. The most irritating thing about digital TV is total dropouts of several seconds. I paid [$] to have this antenna reduce the problem – it didn’t...." Read Full Review »
Jan 22, 2009 by knightowl
See more negative Terk HDTVS Outdoor HDTV Antenna reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Great Picture
  • Great Reception
  • SMALL FOOTPRINT
    Cons
  • None
    Best Uses
  • Dorm Room
  • Home
  • Office
  • TV
"I set this little guy up in my attic first to replace the mommoth that wasn't picking up my HD during cloudy days. Immediately I picked up all my stations plus some subs I hadn't before. I'm 45 miles from the repeater, antennaweb said I needed red, this one is perfect for long distances. J&R deliver …"  Read Full Review »
Was this Antenna review on the Terk HDTVS Outdoor HDTV Antenna helpful to you?
 Report Abuse  (12)  (0)  0 comments
Jun 18 2008
McPace
Salt Lake City, UT
I am:
  • Tech Savvy
Reviewed at:
[9 of 9 customers found this review helpful]
Very good antenna!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"I recently purchased this antenna for use with my Media PC and I've got to say that I was impressed. I set it up in my attic because I didn't want it to be mounted outside. The instructions say that it can be mounted inside or out. The signals strengths were all green bars in Windows Media Center …"  Read Full Review »
 Report Abuse  (9)  (0)  0 comments
Jul 24 2008
jahjahman
Miramar, FL
I am:
  • Tech Savvy
Reviewed at:
I have tried several others but...
4.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • Out-side
"i gave CableVision back their Box,to get HD you don't need Satillite -nor-Cable,just a good antenna like this TERK HD. To view TNT;TBS;E!;WE;even USA go to the InterNet and "plug "your pc's DVi into your TV. I can see in the future the gov't. will let the Net charge you for this ,but for now Why pa …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jun 30 2009
jac-the - TVHD-jacker
the BRONX ,NYC
I am:
  • Casual User
Reviewed at:
2.0
    Pros
  • Attractive Design
    Cons
  • Does Not Improve Audio/Video
    Best Uses
  • Home
"Full disclosure: I have not yet mounted the device on the outside of the house. I experimented with it free standing with sign line to the transmitters.This product works, but does not appreciably improve reception over what I got with my old analog in door antenna. The most irritating thing about d …"  Read Full Review »
Jan 22 2009
knightowl
Kent, Washington
I am:
  • Casual User
Reviewed at:
[4 of 4 customers found this review helpful]
Good antenna, not for masts
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • A little bulky
    Best Uses
  • Outside
"Hard to mount this antenna on a mast and its a little to heavy for that application. With a preamp, it works great. Would probably work well in the city. "
 Report Abuse  (4)  (0)  0 comments
Dec 27 2007
John in Stockdale
Stockdale, TX
I am:
  • Gearhead
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
