Terk FDTV2A Omni Directional Amplified Flat Digital HDTV Antenna
#155
1.8
based on 3 reviews
Ratings Distribution
5 star
0
4 star
1
3 star
1
2 star
0
1 star
4
Category Average
3.6
$44.98 - $69.99
from 5 stores
More Images
Pros
  • Easy setup (4)
  • Attractive design (3)
  • Great picture quality (1)
See less See more
Cons
  • Low quality picture (1)
  • No signal (1)
  • Not durable (1)
  • Short range (1)
Best Uses
  • Clipboard (1)
  • Paper weight (1)
Provided by OneCall
  • Removable ELN amplifier for maximum flexibility and outstanding digital TV reception without signal saturation
  • 360 degree reception pattern and patented reception technology eliminate need for constant adjustments while outperforming traditional antennas
  • Optimized
  • or HDTV reception and high gain picks up further stations
  • Includes 3 way mounting bracket for maximum flexibility in placement including hanging or lying flat or standing
  • Designed to blend in with high end HDTV systems
  • Terk FDTV2A Omni Directional Amplified Flat Digital HDTV Antenna Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 19, 2009
    Terk FDTV2A Omni Directional Amplified Flat Digital HDTV Antenna Reviews
    Displaying 1 - 3 of 3 Reviews
    Show
    Sort by
    over priced - over rated
    1.0
      Pros
    • Attractive Design
    • Easy To Set Up
      Cons
    • No signal
    • Short range
      Best Uses
    • Paper weight
    "I was told by the salesman that this is the best antenna for me, it received no channels. Go to antennaweb.org to find the best antenna for your situation. Turns out I need an outdoor antenna and the salesman was wasting my time. May work fine if you are located near the signal towers. "
    Was this Antenna review on the Terk FDTV2A Omni Directional Amplified Flat Digital HDTV Antenna helpful to you?
    Oct 19 2009
    Country boy
    Virginia
    I am:
    • Power User
    Reviewed at:
    Price: $44.99
    [2 of 2 customers found this review helpful]
    STAY AWAY FROM THIS ANTENNA
    1.0
      Pros
    • Easy To Set Up
      Cons
    • Low Quality Picture
    • Not Durable
      Best Uses
    • CLIPBOARD
    "I HAVE TO MOVE THIS ANTENNA CONSTANTLY TO MAINTAIN THE DIGITAL SIGNAL. THE MOUNTING HARDWARE IS JUST A PIECE OF PLASTIC THAT EASILY FALLS OFF. ITS BEST TO GET AN OUTDOOR ANTENNA. "
     Report Abuse  (2)  (0)  0 comments
    Jun 12 2009
    THE GUY FROM NY
    NEW YORK
    I am:
    • Casual User
    [2 of 3 customers found this review helpful]
    Works as advertized.
    4.0
      Pros
    • Attractive Design
    • Easy To Set Up
    • Great Picture
      Cons
    • None
      Best Uses
    • None
    "Provided good reception for an indoor antenna. More than adequately met its functional requirements. "
     Report Abuse  (2)  (1)  0 comments
    Jul 21 2009
    Groucho
    Washington, DC
    I am:
    • Power User
    Reviewed at:
    Price: $44.99
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
