Terk Edge Dual Drive FM Amplifier (DDA) Circuitry
#153
2.7
based on 11 reviews
from $22.49 - $49.00
Ratings Distribution
5 star
1
4 star
4
3 star
1
2 star
1
1 star
4
Category Average
3.6
More Images
Pros
  • Easy setup (6)
  • Strong signal (4)
  • Durable (3)
  • Attractive design (2)
See less See more
Cons
  • Poor reception / weak antenna (3)
  • Complete waste of money (1)
  • No reception (1)
  • Worse than a loose wire (1)
Best Uses
  • Living room (4)
  • Bedroom (2)
  • Paper weight (1)
Provided by OneCall
Utilizing Terk's new Dual Drive Amplifier (DDA) circuitry, the Edge's signals are captured virtually noise-free. This unique DDA feature, along with a gain range from 0 to +36 dB, minimizes noise in the FM signal with a two stage filter/amplifier before boosting broadcast frequencies.
Reception sensitivity is enhanced with the newly developed Advanced Capture Circuitry (ACC), which helps lock onto signals in crowded areas, and also to improve reception for lower-powered signals.
The FM Edge shows no bias towards any one system as it hooks-up to all receivers, tuners, and mini-systems.
Features
  • Dual Drive Amplifier
    Minimizes noise in the FM signal with a two stage filter/amplifier.
  • FM Amplifier Gain
    0 to +36dB adjusts for changing reception conditions.
  • Advanced Capture Circuitry
    Improves reception sensitivity for low power signals
  • Easy Hook-up
    Connects to all receivers, tuners and shelf systems
  • Terk Edge Dual Drive FM Amplifier (DDA) Circuitry Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 20, 2009
    Terk Edge Dual Drive FM Amplifier (DDA) Circuitry Reviews
    Most helpful positive review
    Most helpful negative review
    4.0
    sexy shape
    "Bear in mind that it has a power wire and an antenna wire. I was unable to locate the device where the wires could be concealed, but the nature of the space is such that the visible wires are not an appearance problem...." Read Full Review »
    Nov 20, 2009 by DickardF
    See more positive Terk Edge Dual Drive FM Amplifier (DDA) Circuitry reviews
    1.0
    No magic bullet
    "I bought this because the local classical station, which comes in just fine on the FM radios in most of my house, only comes in with a lot of hissing and popping on the Bose in the room where I mostly work. It says something that I can't really be sure whether this antenna improves my reception or not. It certainly doesn't improve it enough to be worth the price. I've tried moving the antenna up to the ceilin..." Read Full Review »
    Sep 28, 2009 by John
    See more negative Terk Edge Dual Drive FM Amplifier (DDA) Circuitry reviews
    Displaying 1 - 5 of 11 Reviews
    Show
    Sort by
    sexy shape
    4.0
      Pros
    • Attractive Design
    • Durable
    • Easy To Set Up
    • Strong Signal
      Cons
    • None
      Best Uses
    • Bedroom
    • Living Room
    "Bear in mind that it has a power wire and an antenna wire. I was unable to locate the device where the wires could be concealed, but the nature of the space is such that the visible wires are not an appearance problem. "
    Was this Antenna review on the Terk Edge Dual Drive FM Amplifier (DDA) Circuitry helpful to you?
    Nov 20 2009
    DickardF
    Lexington MA
    I am:
    • Casual User
    Reviewed at:
    Price: $39.99
    No magic bullet
    1.0
      Pros
    • Attractive Design
    • Durable
    • Easy To Set Up
      Cons
    • Poor Reception
      Best Uses
    • None
    "I bought this because the local classical station, which comes in just fine on the FM radios in most of my house, only comes in with a lot of hissing and popping on the Bose in the room where I mostly work. It says something that I can't really be sure whether this antenna improves my reception or …"  Read Full Review »
    Sep 28 2009
    John
    Chapel Hill NC
    I am:
    • Casual User
    Reviewed at:
    Price: $22.49
    Works well, but....
    4.0
      Pros
    • Durable
    • Easy To Set Up
    • Strong Signal
      Cons
    • None
      Best Uses
    • None
    "The Terk improved reception, but the signal booster function didn't completely eliminate the static on weaker FM stations. I found I achieved similar results using about 10 feet of 18 guage speaker wire for an antenna. I kept the Terk though as it looks neater and does serve its purpose. Nice qualit …"  Read Full Review »
    Jan 11 2008
    Cam
    Dayton, OH
    I am:
    • Practical
    Reviewed at:
    inconsistant antenna
    3.0
    "I've used this antenna in two different locations. The first location was in a house surrounded by trees and was kind of elevated and the antenna was in the basement which was below ground. It picked up stations pretty well. However when I moved, the reception turned surprisingly weak. I now live in …"  Read Full Review »
    Jan 10 2008
    maximus12105
    Virginia
    Reviewed at:
    worst purchase ever
    1.0
    "Installed the unit as per the instructions, and immediately lost almost all of my stations except very strong local ones, for which you don't even need an antenna. The silly little wire antenna that came with the receiver (although it left a lot to be desired) worked 1000% better than this unit. It …"  Read Full Review »
    Oct 28 2007
    hammerhead
    New Jersey
    Reviewed at:
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
