Terk Audiovox HDTVo Amplified Outdoor HDTV Antenna
#8
4.2
based on 45 reviews
Ratings Distribution
5 star
25
4 star
14
3 star
0
2 star
0
1 star
6
Category Average
3.6
$71.99 - $119.99
from 10 stores
More Images
Pros
  • Easy setup (27)
  • Strong signal (19)
  • Durable (9)
  • Attractive design (8)
  • Fine-tuning (7)
  • Great picture quality (2)
  • Compact low profile (1)
  • Easy to handle (1)
  • Fast setup (1)
  • Free hdtv is a miralce (1)
See less See more
Cons
  • Poor reception / weak antenna (4)
  • All the plastic (1)
  • Can't handle obstructions (1)
  • Flimsy (1)
  • May need perfect terrain (1)
  • Needs open window indoors (1)
Best Uses
  • Attic/roof mount (9)
  • Living room (5)
  • Home (3)
  • Roof mount (2)
  • Tv (2)
  • 3 bedrooms family room (1)
  • Attic (1)
  • Attic antenna (1)
  • Hdtv (1)
  • Large screen tv in den (1)
Provided by Beach Audio
A compact, amplified, highly directional VHF/UHF antenna utilizing
the a long periodic UHF element with VHF rear reflector element.
Includes HDTVo antenna, Power injector, Mini-mast mounting bracket,
All associated mounting screws.
* Receives all available UHF/VHF local HDTV broadcasts
* CEA Antenna Locator Code: Blue
* Highly directional UHF elements reduces signal interference
* High average return loss for better reception and performance
* Amplification improves picture quality
* High gain picks up further stations
* FM compatible
* Includes all hardware needed to mount on a wall, roof or an attic.
-- SPECIFICATIONs ----------------------------------
FREQUENCY RANGE- VHF 40 MHz ~ 230 Mhz (channels 2-13)
UHF 470 MHz ~ 862 Mhz (channels 14-69)
GAIN - UHF 11 dB typical
VHF 12 dB typical
INSERTION LOSS - -1 +/1 1dB max.
DIMENSIONS - width 39"
length (front to back housing bracket) 22"
depth (top to bottom of f-connector) 3.25"
Length of mast with bracket: 12"
WEIGHT - 7 lbs
www.audiovox.com
Specification Description
Model HD-TVO, HDTVO, HDTVo
UPC 034405002161
Brand Name TERK
color null
Manufacturer TERK Technologies
Manufacturer Website Address www.terk.com
Product Type HDTV Antenna
RF (1) Rear Output
size null
sku 152136
skuprice 119.9900
style HDTVO
taxable Y
Terk Audiovox HDTVo Amplified Outdoor HDTV Antenna Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 24, 2009
Terk Audiovox HDTVo Amplified Outdoor HDTV Antenna Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
Works great for HDTV, issue splitting signal
"This antenna was actually purchased about a year ago and I mounted it in my attic instead of outside. I did not want to bother with grounding it or the homeowners association rules. The cable run through the attic is about 35 feet. I went to antennaweb to get the direction to point the antenna based on my location. It worked great, pulling in the signals from where I live in West Palm Beach to Miami (over 70 mil..." Read Full Review »
Feb 06, 2008 by Anonymous
See more positive Terk Audiovox HDTVo Amplified Outdoor HDTV Antenna reviews
1.0
I should have known better
"I bought this antenna hoping it would have sufficient gain to receive the new HDTV transmissions. Since most of the carriers are now broadcasting in the UHF band and have reduced their signal strengths, I should have know better. I was about 40 miles from NYC and could only pick up stations north of Peekskill, NY. I cannot really rate the product since it was unrealistic, given my location, that I would get NYC ..." Read Full Review »
Aug 03, 2009 by TechMohr
See more negative Terk Audiovox HDTVo Amplified Outdoor HDTV Antenna reviews
Displaying 1 - 5 of 45 Reviews
Show
Sort by
4.0
I went to antennaweb to get the direction to point the antenna based …"  Read Full Review »
Was this Antenna review on the Terk Audiovox HDTVo Amplified Outdoor HDTV Antenna helpful to you?
 Report Abuse  (2)  (0)  0 comments
Feb 6 2008
West Palm Beach, FL
Reviewed at:
Price: $84.95
[1 of 1 customers found this review helpful]
WORKS GREAT IN THE ATTIC
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic antenna
"I chose this antenna because it was small enough not to be an eyesore mounted on my house. I had recently hooked a PC with a dual analog/ota hdtv tuner card to our big screen and was needing an antenna so I could record free digital broadcast and cable programs at the same time on the computer. When …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 23 2009
Logger Dave
Wadesboro,NC
I am:
  • Enthusiast
Reviewed at:
Price: $74.99
[0 of 1 customers found this review helpful]
Good reception, easy install, good price
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • All the plastic
    Best Uses
  • Living Room
"I live 40+ miles from transmitters with a slight elevation rise in between. The old 4'x5' radio shack antenna was giving a 68 signal rating mounted 15' above the roof. The HDTVo gave 76 mounted on the same pole 2' below the eaves, then 81 when mounted 5' above roof on same pole. When spring comes, I …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jan 4 2009
littlefires
Roundup, MT
I am:
  • Enthusiast
Reviewed at:
Price: $74.99
amazing little guy, may need a mountain
4.0
    Pros
  • Easy to handle
  • Easy To Set Up
  • Nicely compact
    Cons
    Best Uses
  • Single tv
"one week user, needs a lot of tweeking, i am in a deep valley about 30 miles north of the empire state building. terk found channels that i didn't know existed, but is not able to pull in some channels that i regularly have through my 16 foot long (old and damanged, deep fringe) roof antenna that i …"  Read Full Review »
Nov 15 2008
devoted diyer
westchester county, ny
I am:
  • Enthusiast
Reviewed at:
Price: $74.99
Crystal clear and worth the $$!
4.0
"After a frustrating year with a new HDTV and and constantly adjusting small indoor rabbit ears antenna for each channel, it was time to purchase an indoor/outdoor antenna. I purchased this online after speaking with a Best Buy employee. He mentioned this had great reviews and was a reasonable purcha …"  Read Full Review »
Oct 3 2008
rabbitearsgone
Saint Paul, MN
Reviewed at:
Price: $107.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
