Terk Amplified Indoor Antenna
#25
3.8
based on 40 reviews
from $24.97 - $59.00
Ratings Distribution
5 star
21
4 star
5
3 star
5
2 star
3
1 star
6
Category Average
3.6
Low Price:
$24.97 at J&R Electronics
 Trusted:
$30.95 at B&H Photo Video
Find it at Amazon
Pros
  • Easy setup (13)
  • Durable (9)
  • Strong signal (9)
  • Fine-tuning (7)
  • Attractive design (4)
  • Fast setup (2)
  • Improved audio/video (2)
  • Contemporary appearance (1)
  • Exactly what i ordered (1)
  • Good value (1)
See less See more
Cons
  • Poor reception / weak antenna (3)
  • Awkward design (1)
  • Low quality picture (1)
  • Poor design (1)
  • Requires wide space (1)
  • Unattractive design (1)
Best Uses
  • Living room (8)
  • Bedroom (5)
  • Office (5)
  • Small rooms (4)
  • Home (2)
  • Portable devices (2)
  • Local stations (1)
  • Must adjust with each cha (1)
  • Tv (1)
Provided by Shoppers Choice
INCLUDES VHF & UHF CAPABILITY FOR RECEPTION OF CHANNELS 2 69; LOW-NOISE BROADBAND AMPLIFIER FEATURES 1-TOUCH ADJUST ;& PATENTED SELECTABLE BYPASS; 44 inch, 75? CABLE ALLOWS THE ANTENNA TO BE INSTALLED ON EVEN THE LARGEST REAR PROJECTION TVS; TV/MEDIA SWITCH ALLOWS SWITCHING BETWEEN BROADCAST TV ;& A VIDEO SOURCE, SUCH AS DVD, VCR OR A VIDEO GAME; LOW-PROFILE DESIGN STANDS 5. 5 inch TALL; NON-SKID SILICON BASE ;ENSURES MAXIMUM ;STABILITY ON ANY SET-TOP; INCLUDES VHF/UHF BAND SEPARATOR & 75? /300? MATCHING TRANSFORMER FOR EASY HOOK-UP; 1-YEAR LIMITED WARRANTY SUBCATEGORY2: INDOOR ANTENNAS.
Terk Amplified Indoor Antenna Questions
Questions and Answers
Where to Buy
$30.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$24.97
$31.99
Code FALLSAVINGS33 : $5 Off Orders Over $50
Show all 8 stores
_
Product Reviews
Last update: Oct 16, 2009
Terk Amplified Indoor Antenna Reviews
Most helpful positive review
[14 of 15 customers found this review helpful]
Most helpful negative review
5.0
Excelent Antenna
"After going through about 3 different HDTV antenna's I finally found this one, and it works great! When I lived in a area that had bad reception I could still get some channels with this antenna, sometime I would have to turn it for different channels but when I moved I now get all the HD channels perfectly...." Read Full Review »
Feb 08, 2009 by Jacob Blumberg "jakeb16"
See more positive Terk Amplified Indoor Antenna reviews
3.0
Eh....it's ok. Have some advice though
"I got this for my wife to pick up reception for some of her Mexican channels across the border (we are in El Paso), and to get some extra local stations not carried by Direct Tv. Some channels work very well, but about 25% cannot be picked up. I have tried many, many angles with little extra success. My dog walks across the room, someone opens my back door, etc and the signal "pauses". It's fine if you are close..." Read Full Review »
Jul 29, 2008 by YakAttack
See more negative Terk Amplified Indoor Antenna reviews
Displaying 1 - 5 of 40 Reviews
Show
Sort by
Excelent Antenna
5.0
"After going through about 3 different HDTV antenna's I finally found this one, and it works great! When I lived in a area that had bad reception I could still get some channels with this antenna, sometime I would have to turn it for different channels but when I moved I now get all the HD channels p …"  Read Full Review »
Was this Antenna review on the Terk Amplified Indoor Antenna helpful to you?
 Report Abuse  (14)  (1)  0 comments
Feb 8 2009
Chandler,AZ
Reviewed at:
Price: $39.99
[6 of 7 customers found this review helpful]
Digital Antenna
4.0
"The Antenna is a good product. Depending on the TV Station a turning or adjustment of the Antenna is occational required. Other then that the TV receives good reception with this Low Profile Antenna. I like it better then the standard long ear Antenna. It takes less space, no breaking, bending, or g …"  Read Full Review »
 Report Abuse  (6)  (1)  0 comments
Apr 9 2009
Natures Gift
Fresno, CA USA
Reviewed at:
Price: $39.99
3.0
"I got this for my wife to pick up reception for some of her Mexican channels across the border (we are in El Paso), and to get some extra local stations not carried by Direct Tv. Some channels work very well, but about 25% cannot be picked up. I have tried many, many angles with little extra success …"  Read Full Review »
Jul 29 2008
YakAttack
El Paso, Texas
Reviewed at:
Unacceptable
1.0
    Pros
  • Easy To Set Up
    Cons
  • Poor Reception
    Best Uses
  • Bedroom
"I live on the NW Side of Chicago and this antenna was actually worse then my old rabbit ears on the DTV box. I tried it with the amplifier on and off which offered no difference.
Bottom line I believe with the new DTV the boxes offered and the antennas are very poor at best. Expecially when you m …"  Read Full Review »
Aug 12 2008
jjr
Edison Park, Chicago IL
I am:
  • Tech Savvy
Good Quality Powerful Indoor TV Antenna
4.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Living Room
"I tried a number of other antennas to go w/ my digital converter box. This one is by far the best - picking up more channels than all the others. I like getting better reception w/ just a slight adjustment vs. the new "high tech" rabbit ears that have so many ways to adjust but still don't give be …"  Read Full Review »
Feb 19 2009
Pamster
Shelton, CT
Reviewed at:
Price: $24.97
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
