Terk AM-1000 AM ADVANTAGE Indoor AM Antenna
#14
4.1
based on 23 reviews
Ratings Distribution
5 star
9
4 star
10
3 star
3
2 star
0
1 star
1
Category Average
3.6
$34.95 - $69.00
from 5 stores
Pros
  • Easy setup (14)
  • Attractive design (11)
  • Strong signal (11)
  • Durable (10)
  • Fine-tuning (6)
  • Fast setup (4)
  • Improved audio/video (4)
  • Simple controls (4)
  • Best price found (1)
  • Easy to use (1)
See less See more
Cons
  • Poor reception (3)
  • Bulky (1)
  • Tethered to the tuner (1)
Best Uses
  • Bedroom (9)
  • Living room (6)
  • Office (6)
  • Portable devices (6)
  • Small rooms (6)
  • Home (4)
  • Hardwired (1)
  • Professional (1)
  • Used with boom box (1)
Provided by OneCall
The AM Advantage
Dramatically improves the AM reception on ANY stereo system tuner, receiver or portable radio! Now you can experience AM radio like you've never heard before. The TERK AM Advantage antenna combines technology with tuning convenience and flexibility to give you the clearest AM reception and maximum value from ANY radio. It requires NO connections, batteries, or power cords!
The TERK AM Advantage antenna is a non-powered, fully adjustable indoor AM antenna designed for extended range capability. The antenna receives AM frequencies 535KHz to 1700KHz for local and distant AM reception.
TERK's Pin-Dot (TM) Pre-Tuning matches the specific AM frequency on your radio to give you superior reception...
TERK's AM Advantage antenna with Pin-Dot (TM) Pre-Tuning lets you tune out noise and static reception so you can listen to your favorite AM stations with the clearest reception ever. TERK's Pin-Dot (TM) Pre-Tuning adjusts its own antenna to match the specific frequency of the AM station you're trying to receive. By simply rotating the dial located at the center of the antenna, you will be able to tune in the best AM reception possible.
Specification Description
Model ADVANTAGE, Advantage, TERADVANTAGE
UPC 034405000907
Accessory Indicator Yes
Benefits Ideal for receiving your favorite sports and news stationsPin-dot pretuning lets you select the frequency of your choiceNo w
Capacity UOM mAh
Country Of Origin China
Description Header Awesome antenna.
Display Catalog Number 55016335
Manufacturer Labor Warranty 12
Manufacturer Part Number ADVANTAGE
Manufacturer Parts Warranty 12
MAP Price 0.0
Model ADVANTAGE
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type AM only
Product Weight UOM pounds
Supported Languages English
Terk AM-1000 AM ADVANTAGE Indoor AM Antenna Questions
Questions and Answers
Where to Buy
$34.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$49.00
BizRate Rating Outstanding 9.1
$39.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Show all 5 stores
Product Reviews
Last update: Nov 5, 2009
Terk AM-1000 AM ADVANTAGE Indoor AM Antenna Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Great AM Antenna for AM DXers
"I have have this antenna still I would recommend it most people who listen to distant AM broadcast stations and low power stations. Covers the entire AM band. You can connect it to your own stereo system to the 2 terminals or couple it to the internal ferrite bar antenna in the radio...." Read Full Review »
Aug 28, 2007 by gccradioscience
See more positive Terk AM-1000 AM ADVANTAGE Indoor AM Antenna reviews
1.0
I didn't work for me
"My home is an electronic Bermuda Triangle. I was hoping to listen to AM as I was going to sleep. And while it did improve things, the reception is not good enough to listen to. It did improve my reception in the daytime. I do wish they had explained that most clock radios can not be hard wired...." Read Full Review »
Jul 14, 2009 by PJC
See more negative Terk AM-1000 AM ADVANTAGE Indoor AM Antenna reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Portable Devices
  • Small Rooms
"I have have this antenna still I would recommend it most people who listen to distant AM broadcast stations and low power stations. Covers the entire AM band. You can connect it to your own stereo system to the 2 terminals or couple it to the internal ferrite bar antenna in the radio. "
This is the Terk coupled to a small AM/FM radio
  • Picture of Product
  • Using Product
This is with my other radio antennas
  • Using Product
Was this Antenna review on the Terk AM-1000 AM ADVANTAGE Indoor AM Antenna helpful to you?
 Report Abuse  (2)  (0)  0 comments
Aug 28 2007
gccradioscience
Virginia Beach, VA
I am:
  • Gearhead
Reviewed at:
Price: $39.99
Beach Audio Bested Others on Terk
4.0
    Pros
  • Attractive Design
  • Best Price Found
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Bedroom
  • Hardwired
  • Living Room
  • Small Rooms
"I bought the Terk because a twin-coil ferrite antenna I purchased, even after returning it, was not satisfactory. I am pleased with the [...] price from Beach Audio. The unit for me works hardwired to my classic 1979 Marantz ST400 AM/FM digital tuner and its companion 50-watt integrated amp. Without …"  Read Full Review »
Nov 5 2009
Will the Listener
Moncks Corner, S.C.
I am:
  • Enthusiast
Reviewed at:
AM radio w/o static and signal loss
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Strong Signal
    Cons
  • Bulky
    Best Uses
  • Bedroom
  • Living Room
  • Portable Devices
  • Small Rooms
"This is a great AM antenna, works to take the fringe station and make it clear - without static and annoying signal gain and loss. I listen to a talk station in San Francisco (85 miles away), the signal is clear day and night. Downside - The loop antenna is about 8" in diameter, so be prepared for …"  Read Full Review »
Oct 27 2009
Talk radio is good
Sacramento
I am:
  • Casual User
Reviewed at:
Price: $39.99
A must for AM listerers of weak stations
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Improved Audio/Video
  • Simple Controls
    Cons
    Best Uses
  • Home
"I've three of these Terk antennae in my house. It is pretty simple: If I'm listening to AM radio in a room then the tuner there will be wired to a AM Advantage.
Pros:
- pretty stylish for an antenna
- works well at pulling in weak signals and allows fine tuning around the frequency, not p …"  Read Full Review »
Dec 10 2008
Charles
Cupertino, CA
I am:
  • Enthusiast
Reviewed at:
Price: $34.95
Amazing Technology
5.0
    Pros
  • Easy To Set Up
  • Fine-Tuning
  • No connections required
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
  • Portable Devices
  • Small Rooms
"Being an eclectic radio collector, I researched Terk Loops, thus my purchase. Well ... Amazing, simply amazing results. It works incredibly well on my Tivoli Model One (fully transistorized) radio. WJIB never sounded better! I've also used it successfully on my 1950~1960s radios and a 1938 Philc …"  Read Full Review »
Mar 18 2009
franklyradio
Quincy,MA
I am:
  • Enthusiast
Reviewed at:
Price: $39.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
