Terk AF-1 AM/FM Q Amplified Indoor AM/FM Antenna
#164
2.3
based on 21 reviews
Ratings Distribution
5 star
3
4 star
2
3 star
1
2 star
7
1 star
8
Category Average
3.6
Low Price:
$42.99 at J&R Electronics
 Trusted:
$49.95 at B&H Photo Video
Find it at Amazon
$42.99 - $79.99
from 5 stores
More Images
Pros
  • Easy setup (13)
  • Attractive design (6)
  • Strong signal (5)
  • Fine-tuning (4)
  • Good fm reception (4)
  • Durable (2)
  • Fm reception is good (1)
See less See more
Cons
  • Poor reception (9)
  • Poor am reception (4)
  • Unattractive design (3)
  • Pricey (2)
  • Am reception bad (1)
  • Flimsy (1)
  • Gain misrepresented (1)
  • Simply does not work (1)
  • Weak signal (1)
Best Uses
  • Living room (12)
  • Attic/roof mount (1)
  • Bedroom (1)
  • Media center (1)
  • Office (1)
  • Portable devices (1)
  • Small rooms (1)
Provided by OneCall
High-Performance Styling
The AM/FM Q is TERK`s finest indoor, amplified AM/FM antenna, combining high-performance and superior technologies in a stylish and compact design. This antenna offers superior radio reception by adjusting to a wide range of conditions.
Unique Pin-DotTM Pre Tuning
At the heart of the AM/FM Q antenna is TERK`s unique Pin-Dot Pre-Tuning which allows the user to adjust the antenna to a specific frequency by simply adjusting the dial to match the desired radio station. The result is clearer AM and FM stations and much less static than ever before.
Versatile and Easy To Install
The AM/FM Q must be plugged into a radio or stereo receiver and a wall outlet to power the amplifier. Since some tuners and receivers have either 75 or 300 Ohm antenna inputs, the AM/FM Q comes with everything you need to hook up the antenna right out of the box.
More Stations
By combining Pin-Dot pre Tuning with controlled amplification, the AM/FM Q can make it possible to enjoy stations that were previously unlistenable. Sometimes a station is too weak to hear above the static—often because it is too far away. To counteract this, the AM/FM Q contains a built-in amplifier that strengthens signals. In addition, the AM/FM Q features Pin-Dot pre Tuning —TERK`s unique tuning system that zeroes in on hard-to-receive stations. As the air waves become increasingly crowded, fine-tuning has become an increasingly useful tool in the quest for better reception.
Clearer Reception
The AM/FM Q tunes out noise and interference using TERK`s Pin-Dot pre Tuning system to receive AM and FM stations with greater clarity than ever before. Pin-Dot pre Tuning adjusts the antenna to match a specific frequency and that means less static to the listener. Although amplifiers do strengthen signals, stronger is not always better. If a station has too much static, amplifying it will also amplify the noise and may actually make it harder to hear. The best antennas allow you to control the level of amplification while continually optimizing the desired signal for better reception. TERK`s AM/FM Q gives you this kind of full control needed for today`s crowded airwaves.
Designed for Top Performance & Control
The AM/FM Q is actually two discreet antennas: an AM and an FM. The antenna experts at TERK know that placing the AM and FM antennas so close to each other can negatively impact reception. That`s why the AM/FM Q`s AM antenna flips back—away from the FM antenna—and features patented Non-Coinduction(TM) circuitry to isolate the antennas from each other and preserve radio reception. On the face of the AM/FM Q is a line of LEDs that facilitate tuning and amplifying. Depending on which is being adjusted at the time, LEDs (in red) indicate level of amplification or station being tuned in (key on back of AM/FM Q). TERK has even thought of the little details; the AM/FM Q stands on a non-skid pedestal so it won`t slide around during adjustments.
A Few, Simple Connections
The AM/FM Q does require a few connections: AM and FM wires must be plugged into a radio/receiver and the power cord must be plugged into a wall outlet. Since tuners and receivers may have either 75 Ohm or 300 Ohm antenna inputs, the AM/FM Q comes complete with adapters.
Specification Description
Model AF-1, AF1, AF1/Q, AF1Q
UPC 034405231004
Accessory Indicator Yes
Benefits Non-conduction circuitry isolates AM/FM antennas for better receptionLED display shows optimal signal strength for clearer tuning
Capacity UOM mAh
Country Of Origin China
Description Header Enjoy better radio.
Display Catalog Number 55016336
Manufacturer Labor Warranty 12
Manufacturer Part Number AF-1
Manufacturer Parts Warranty 12
MAP Price 0.0
Model AF-1
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 4.7
Product Length 4.3
Product Type AM/FM
Product Weight UOM pounds
Product Width 5.9
Supported Languages English
Terk AF-1 AM/FM Q Amplified Indoor AM/FM Antenna Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Terk AF-1 AM/FM Q Amplified Indoor AM/FM Antenna Reviews
Most helpful positive review
Most helpful negative review
[20 of 21 customers found this review helpful]
5.0
It Works and Looks Good
"I live in a suburb of a large metropolitan area. I installed this in an enclosed media cabinet located in a media room that has no windows. Further, the roof has radiant barrier decking (foil lined plywood). Certainly not a radio frequency friendly environment. This unit had no problem pulling in all the local radio stations, both FM and AM. I have not used the "Pin-Dot Pre-Tuning" feature, as it was not necess..." Read Full Review »
Aug 30, 2009 by Zymurgy
See more positive Terk AF-1 AM/FM Q Amplified Indoor AM/FM Antenna reviews
1.0
This Terk is a Turkey
"Little wire antenna that came with my receiver works much better! Slightly weak FM signal got slightly worse and weak AM reception disappeared altogether when the Terk AF-1 was hooked up. More money doesn't mean more performance for this product...." Read Full Review »
Dec 31, 2007 by Weak Reception
See more negative Terk AF-1 AM/FM Q Amplified Indoor AM/FM Antenna reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
1.0
    Pros
  • Easy To Set Up
    Cons
  • Poor Reception
    Best Uses
  • None
"Little wire antenna that came with my receiver works much better! Slightly weak FM signal got slightly worse and weak AM reception disappeared altogether when the Terk AF-1 was hooked up. More money doesn't mean more performance for this product. "
Was this Antenna review on the Terk AF-1 AM/FM Q Amplified Indoor AM/FM Antenna helpful to you?
 Report Abuse  (20)  (1)  0 comments
Dec 31 2007
Weak Reception
Incline Village, NV
I am:
  • Tech Savvy
Reviewed at:
Price: $69.99
[7 of 7 customers found this review helpful]
Alot of money to buy the Terk name.
1.0
    Pros
  • None
    Cons
  • Expensive
  • Poor Reception
  • Unattractive Design
    Best Uses
  • None
"Like most Terk products, one pays a high premium for the Terk brandname but gets little in return. There are better FM antennas on the market that cost less money than this one. "
 Report Abuse  (7)  (0)  0 comments
Apr 11 2009
Dave
I am:
  • Power User
Reviewed at:
Price: $69.99
Very poor reception on both AM and FM
1.0
    Pros
  • Durable
    Cons
    Best Uses
  • NONE
"I live 25 miles from Tucson, AZ. Without the antenna I receive no stations. With antenna I receive only three stations on FM. On AM the static does come in more clearly but without any stations. I would rate this antenna as not worth the money. A complete failure. "
Nov 9 2009
Dick
Green Valley, AZ 85614
I am:
  • Enthusiast
Reviewed at:
Price: $53.88
Save your money and buy the 19.99 one
1.0
    Pros
  • None
    Cons
  • Flimsy
  • Poor Reception
    Best Uses
  • Living Room
"I get more channels with the cheaper one. It's cheaply made and not worth the money. "
Mar 23 2009
crystal blue
chicago, IL
I am:
  • Power User
Reviewed at:
Price: $69.99
[2 of 2 customers found this review helpful]
AM/FM Q Powered Indoor Antenna
3.0
    Pros
  • None
    Cons
  • Poor Reception
    Best Uses
  • Living Room
"It would be nice to find answers to whether "other users" actually exist. When I first purchased the Q it worked well but after a year (warranty expired) it's kind of like GM (in need of a bailout or new mgmt or at least a new customer, not me. Unfortunately the FAQ's were nowhere to be found thro …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 7 2009
Disappointed in Terk
Denver, CO
I am:
  • Power User
Reviewed at:
Price: $53.88
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
