Targus Ultra Mini Optical Mouse with Retractable Cord
4.3
based on 14 reviews
Ratings Distribution
5 star
105
4 star
55
3 star
19
2 star
5
1 star
7
Category Average
4.3
Low Price:
$14.95 at B&H Photo Video
 Trusted:
$14.99 at Adorama
Find it at Amazon
$14.95 - $21.99
from 15 stores
More Images
Pros
  • Glides smoothly (148)
  • Accurate tracking (141)
  • Comfortable design (138)
  • Fast response (129)
  • Works on any surface (115)
  • Great features (77)
  • Compact (2)
  • Travel (2)
  • A bit small but great (1)
  • Cheap (1)
See less See more
Cons
  • Limited surface compatibility (16)
  • Catches easily (13)
  • Uncomfortable design (12)
  • Inadequate features (3)
  • Inaccurate tracking (2)
  • Slow response (2)
  • Breaks too soon (1)
  • Buttons wear out (1)
  • Cord can get stuck (1)
  • Cord gets in way (1)
Best Uses
  • Travel (111)
  • Web browsing (89)
  • Everyday (75)
  • Professional (51)
  • Gaming (37)
  • Graphic design (7)
  • Any uses (1)
  • Compact yet powerful (1)
  • Molecular modeling (1)
  • School (1)
Provided by photoalley.com
The Targus Ultra Mini Retractable Optical Mouse (Silver and Black with red LED) is the perfect solution for the mobile warrior who needs to save space when using an external mouse. The "Screen Scroller Button" will allow you to scroll up or down, left or right, and you can also alternate between open applications. The mouse allows you to browse web sites and Windows easily. The Ultra Mini Retractable Optical Mouse comes standard with a USB connection (USB 1.1) that will allow true plug and play connection with the notebook USB port.
Main Features
  • Manufacturer: Targus Group International.
  • Manufacturer Part Number: PAUM01U
  • Manufacturer Website Address: www.targus.com
  • Pointing Device Type: Mouse
  • Pointing Device Connectivity Technology: Cable
  • Pointing Device Wireless Technology: Not Applicable
  • Movement Detection: Optical
  • Scroller: 1 x Scroll Wheel
  • Interfaces/Ports: 1 x 4-pin Type A Male USB
  • Dimensions: 0.9" Height x 1.4" Width x 3" Depth
  • Weight: 1.5 oz
  • Standard Warranty: 1 Year(s) Limited
  • Specification Description
    Model 10273676, 262682, PAUM01U
    UPC 092636201104
    Accessory Indicator Yes
    Benefits Small, compact design is perfect when space is limitedOptical sensor technology ensures perfect response to mouse movementsA
    Capacity UOM mAh
    Country Of Origin China
    Description Header Small in size, huge in compatibility.
    Display Catalog Number 55010159
    Enclosure Color Silver
    Included in the Box Targus® PAUM01U Ultra Mini Optical MouseCarrying pouch
    Manufacturer Labor Warranty 12
    Manufacturer Part Number PAUM01U
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model PAUM01U
    Operating Temperature UOM ° F
    Product Dimensions UOM inches
    Product Disclaimer Warranty is 1 year limited.
    Product Height 0.9
    Product Length 3
    Product Type Scroll mouse
    Product Weight 1.5
    Product Weight UOM ounces
    Product Width 1.4
    Required to function Windows® 98, Me, 2000, XP or Mac OS®USB port
    Supported Languages English
    Targus Ultra Mini Optical Mouse with Retractable Cord Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 17, 2009
    Targus Ultra Mini Optical Mouse with Retractable Cord Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    "Don't judge a mouse by it's size"
    "A really great little pocket mouse...." Read Full Review »
    Nov 17, 2009 by Tekman
    See more positive Targus Ultra Mini Optical Mouse with Retractable Cord reviews
    3.0
    Very compact but buttons wear out
    "I have bought at least three of these. The first one's right button pretty much quit after a year of travel use on my laptop. The second unit's buttons are getting a bit balky, but a firm push still works. I bought a third for my new netbook; so far, so good. The list price is silly, given the early failures; only buy them on sale. But you cannot beat the size and weight for travel...." Read Full Review »
    Aug 02, 2009 by Grumpy
    See more negative Targus Ultra Mini Optical Mouse with Retractable Cord reviews
    Displaying 1 - 5 of 14 Reviews
    Show
    Sort by
    [2 of 2 customers found this review helpful]
    It's Really Mini...but Beware
    3.0
    "Pros
    The good thing about this mouse is the retractable cord that saves space in your working area, it comes with its own travel bag, and its size. They weren't lying...it really is "ultra mini" and its also ultra light.
    Cons
    My only problem with this mouse is that after a few montnhs the USB por …"  Read Full Review »
    Was this Computer Mice review on the Targus Ultra Mini Optical Mouse with Retractable Cord helpful to you?
     Report Abuse  (2)  (0)  0 comments
    Apr 9 2007
    krislaw
    Grand Rapids, Michigan
    Reviewed at:
    Price: $21.99
    Great Mouse
    5.0
      Pros
    • Accurate Tracking
    • Comfortable Design
    • Fast Response
    • Glides Smoothly
    • Right size for netbook
    • More »
      Cons
    • None
      Best Uses
    • Everyday Use
    • Traveling
    "Great to use with the netbook and when traveling. Just the right size for the airline tray. So far I have not found any negatives. "
    Oct 7 2009
    Jacki
    Mazatlan, Mexico
    I am:
    • Casual User
    Reviewed at:
    Price: $14.99
    retractable optical mouse
    5.0
    "Pros
    I purchased this mouse for my husband to use on his notebook. It's great. I use my desk top and am used to using a mouse so we had to have one especially for me. It works easy and the retractable makes it easy to use wherever you want to put it. I highly recommend it. "
    Feb 18 2008
    carol8449
    Gloversville, NY
    Reviewed at:
    Price: $21.99
    the product is very gooooooood!!
    5.0
      Pros
    • Accurate Tracking
    • Fast Response
    • Great Features
      Cons
    • None
      Best Uses
    • Everyday Use
    "i use it every day.
    it's easy to take cause it's small and light.
    maybe the wire is not good, it sometimes can twist. "
    Oct 6 2009
    Ruby
    Ames, IA
    I am:
    • Casual User
    Reviewed at:
    Price: $14.99
    The Compatability Issue
    1.0
      Pros
    • None
      Cons
    • Catches Easily
      Best Uses
    • None
    "Not only does the retracting system not work, but I found it to be incompatible with my MacBook. Just to see, I plugged it into a friend's PC, and it seemed to be just fine. "
    Aug 11 2008
    t
    Oregon
    I am:
    • Power user
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
