Targus Ultra Mini 4-Port USB Hub
#1
4.4
based on 9 reviews
Ratings Distribution
5 star
86
4 star
58
3 star
9
2 star
2
1 star
5
Category Average
4.1
Low Price:
$14.99 at Kmart
$17.99 at ClubMac
Find it at Amazon
$14.99 - $24.99
from 15 stores
More Images
Pros
  • Reliable (112)
  • Easy setup (87)
  • Small (65)
  • Fast (51)
  • Highly compatible (44)
  • Durable (39)
  • Strong connection points (39)
  • Easily expanded (32)
  • Improves performance (32)
  • A life saver for wires (1)
See less See more
Cons
  • Flimsy (3)
  • Not energy efficient (3)
  • Unreliable (3)
  • Incompatible (2)
  • Limited compatibility (2)
  • Cables not wireless (1)
  • Cord too long (1)
  • Dont work with wireless (1)
  • Great product (1)
Best Uses
  • Desktop (71)
  • Home (64)
  • Computer equipment (52)
  • Small networks (11)
  • Laptop (6)
  • High-end equipment (5)
  • Networking (5)
  • Larger networks (2)
  • Good for laptops (1)
  • Netbook (1)
Provided by MacMall
Ultra Mini USB Hub (4 Ports) Convenient plug and play connectivity for multiple USB devices The Targus Ultra Mini USB 4 Port Hub will allow your notebook computer to have plug and play connection to multiple input/output USB devices. The hub features a 4-port bus and self-powered stand-alone USB hub (AC Adapter optional). Packaged in a small and attractive enclosure, the hub can fit any place on a desktop, allowing for easy connection of four low speed or full speed USB devices to your USB enabled computer
Features:• 4 Port USB Hub• Convenient plug and play connectivity for multiple USB devices• Allows your notebook computer to have plug and play connection to multiple input/output USB devices• Ultra-lightweight, compact design features four USB ports• Suitable for PC or Apple laptops or USB-enabled desktop computers• Overcurrent protection on each port prevents power shutdown of the hub• Supports both full-speed and low-speed transfer rates• 3.3 ft. cable
Technical Specs
Compliance:• CE, FCC Class A and B Approved
Size:• 3.75” x 1.66” x .75”
Warranty:• One year
Weight:• 3.0 oz
Specification Description
Model 10273676, PA055U
UPC 092636109332
#per pack 1
Accessory Indicator Yes
Benefits Connect up to 4 USB devices, like memory drives and PDAs, to your desktop or notebook simultaneouslyConvenient self-powered, stand-al
Cables Included Upstream cable
Capacity UOM mAh
Compatible Platforms Windows, Mac
Compliant Standards USB 2.0, 1.1
Country Of Origin China
Description Header Portable connectivity.
Display Catalog Number 55010121
Included in the Box Upstream cable
Manufacturer Labor Warranty 12
Manufacturer Part Number PA055U
Manufacturer Parts Warranty 12
MAP Price 0.0
Model PA055U
Operating Temperature UOM ° F
Product Depth 1.5
Product Dimensions UOM inches
Product Disclaimer Warranty is limited.
Product Height 0.75
Product Length 3.75
Product Type Hubs
Product Weight 3
Product Weight UOM ounces
Product Width 3.75
Supported Languages English
Targus Ultra Mini 4-Port USB Hub Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Targus Ultra Mini 4-Port USB Hub Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[5 of 5 customers found this review helpful]
4.0
Very Handy
"My USB ports are at the back of my PC tower, so plugging equipment into them is a pain (my desk sits in a corner, access is tricky). This little gadget is extremely handy for letting me simply plug it into the back then be able to quickly plug items in and out from the front of my desk instead of having to constantly reach behind the machine...." Read Full Review »
Oct 24, 2007 by WriterLainey
See more positive Targus Ultra Mini 4-Port USB Hub reviews
1.0
Not worth it - old technology
"Received this as a requested gift. It is not marked anywhere on the package or unit or instructions that it is only USB 1.1. Only after connecting it and plugging a USB device into it, did I get the message that my device will be accessed at a reduced performance because the hub is only USB 1.1. I didn't even think USB 1.1 hubs were even being sold anymore! I had to go to the Targus website to actually fin..." Read Full Review »
Jan 06, 2008 by Electronics guy
See more negative Targus Ultra Mini 4-Port USB Hub reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Did Not Last/Short Life Span
2.0
"When purchasing a USB Hub for my notebook, I was looking for small/multiple USB port expansion. This product had the sleek look/style and function.
It worked sufficiently (not with transfer rate of 480mbps) but fairly good. This product suddenly failed me (stopped working) because my printer was sho …"  Read Full Review »
Was this Networking Hub & Switch review on the Targus Ultra Mini 4-Port USB Hub helpful to you?
Jul 22 2008
AZNATIVE
Phoenix, AZ
Reviewed at:
Price: $24.99
[1 of 1 customers found this review helpful]
USB Hub expands computer use
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
"Although my computer had many USB connects they were in the back of the computer except one in front The hub allows me to download picture from camera, use a flash drive and have my scanner all at one time. Great buy "
 Report Abuse  (1)  (0)  0 comments
May 7 2009
Illini72
Russellville, AR
Reviewed at:
Price: $19.99
Works Well
4.0
"I use this for my Xbox 360 and have had only one problem with it: it doesnt always have power running to it.
This is a minimal problem though; as long as my 360 is turned on, it works wonderfully, but when my 360s off, unfortunately, the usb hub isnt able to access the power off the 360's brick. "
Jul 24 2008
ThePurpleRabbit
Vegas
Reviewed at:
Price: $24.99
It works!
5.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Desktop
  • Home
"I found that it works without an external power supply. "
Jul 16 2009
John
Ohio
I am:
  • High bandwidth user
Reviewed at:
Price: $19.99
Just Ok
3.0
"Its great because you can get out from the back of the computer. But as soon as I plug in more then two things into it the power gets overloaded. "
May 25 2009
JonH888
Undisclosed
Reviewed at:
Price: $24.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
