Tamrac 5770 Velocity 10x Pro, Sling Pack with Tuck-A-Way Waist Belt, Black
#155
4.3
based on 19 reviews
Ratings Distribution
5 star
13
4 star
3
3 star
0
2 star
2
1 star
1
Category Average
4.2
Low Price:
$99.95 at B&H Photo Video
 Trusted:
$99.95 at Adorama
Find it at Amazon
$99.95
from 3 stores
More Images
Pros
  • Easy to use (9)
  • High quality (9)
  • Comfortable strap (5)
  • Good protection (4)
  • Highly compatible (4)
  • Durable (3)
  • Comfortable (2)
  • Compact design (2)
  • Improves performance (2)
  • Bag design (1)
See less See more
Cons
  • Heavy / bulky (3)
  • Lacks functionality (2)
  • Poor design (2)
  • Poor performance (2)
  • Camera sits a little high (1)
  • Its pretty large (1)
  • Limited compatibility (1)
  • Not enough pocket room (1)
  • Poor color option (1)
Best Uses
  • Daily transport (4)
  • Travel (4)
  • Protecting gear (2)
  • Storage (2)
  • Carry all the gear i need (1)
  • Complex projects (1)
  • Daily usage (1)
  • In the field (1)
  • On the go (1)
Provided by OneCall
The Velocity 10x - Pro Sling Pack is the largest version of our popular sling packs. It holds one or two pro-sized DSLRs with lenses attached, additional lenses and a flash. Inside the main compartment, the cameras with lenses attached are suspended on two vertical, foam-padded dividers that are internally reinforced with rigid plastic. The Velocity 10x can be carried comfortably like a backpack, but when swung around to the front, the secure zippered Quick Flip Top opens away from the body for fast and convenient access to camera gear. A well-padded sling strap comfortably distributes the weight, but need not be removed to quickly access photo equipment. A Tuck-A-Way™ waist belt allows the Velocity 10x to be used comfortably during vigorous activities such as hiking or biking. The front pocket has organizer pockets inside to keep a mobile phone, PDA or photo accessories within easy reach. It also features Tamrac's US-patented Memory & Battery Management System™ that uses red flags to identify available memory cards and batteries from ones that are used up. A pocket inside the lid stores filters and lens caps. Customize this sling pack with Tamrac's Modular Accessory System™ components.
Specification Description
Model 577001
UPC 023554027613
Depth (Inches) 10.5
Depth Internal (Inches) 6.5
Height (Inches) 15.5
Height Internal (inches) 13
Select Capacity Two or More Cameras Plus
Width (Inches) 14
Width Internal (Inches) 12
Tamrac 5770 Velocity 10x Pro, Sling Pack with Tuck-A-Way Waist Belt, Black Questions
Questions and Answers
Where to Buy
$99.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$99.95
BizRate Rating Outstanding 9.1
$99.95
Product Reviews
Last update: Sep 20, 2009
Tamrac 5770 Velocity 10x Pro, Sling Pack with Tuck-A-Way Waist Belt, Black Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Great Design!!!
"Pro's: Unique Design - tried many slings but this one stands out because the top opens away from your body and the wide-mouth gives you full access to all your gear while protecting it from spilling out or being stolen. Fits Comfortably - Can be slung across one shoulder to carry it, or carried as intended across your back. Handle on top is very useful. Large Compartments - Holds my "kit" consisting of Nikon..." Read Full Review »
Jan 29, 2009 by John C.
See more positive Tamrac 5770 Velocity 10x Pro, Sling Pack with Tuck-A-Way Waist Belt, Black reviews
2.0
doesn't hold 2 pro dslrs as shown
"I bought this bag for an upcoming trip. based on the images from Tamrac I was counting on being able to top load both my Canon 1DsII and Nikon D3. when I went to try to do this, it could only be done if you force the cameras into position. there isn't an inch of room between the grips and they bang and scratch at each other. I finally took out one of the included dividers so that one camera can be at the bottom ..." Read Full Review »
Mar 27, 2009 by disappointed with this
See more negative Tamrac 5770 Velocity 10x Pro, Sling Pack with Tuck-A-Way Waist Belt, Black reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
Great Design!!!
4.0
    Pros
  • Comfortable
  • Easily Accessible Equipment
  • Great Design
    Cons
  • None
    Best Uses
  • Daily Usage
  • Protecting Gear
  • Transporting Gear
"Pro's:
Fits Comfortably - Can be slung across one shoulder to carry it, or carrie …"  Read Full Review »
Was this Professional Video Accessory review on the Tamrac 5770 Velocity 10x Pro, Sling Pack with Tuck-A-Way Waist Belt, Black helpful to you?
 Report Abuse  (5)  (0)  0 comments
Jan 29 2009
John C.
Huntington, NY
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $99.95
[6 of 7 customers found this review helpful]
Finally somebody made the bag I need.
5.0
    Pros
  • Comfortable
    Cons
  • None
    Best Uses
  • Protecting Gear
"All I need when I travel overseas is two bodies, one with a 24-70 zoom and one with a 70-200 zoom. A flash or two fired by pocket wizards. Maybe one extra lens like a 50 f1.4 or a 16 to 35 zoom, The trick is to have the cameras mounted to lenses with the lens shade on them. I need 14 inches to d …"  Read Full Review »
 Report Abuse  (6)  (1)  0 comments
Jan 14 2009
Jonny Chuck
Lancaster, Pa. 17601
I am:
  • Pro Photographer
Reviewed at:
Price: $99.95
Great for 2 DSLRs w-lenses and hoods
5.0
    Pros
  • Comfortable Strap
  • Compact
  • Durable
  • Good Protection
  • Lightweight
    Cons
  • Not Enough Pocket Room
    Best Uses
  • Daily Transport
  • Storage
  • Travel
"Perfect dimensions for 2 DSLR's side by side with long lenses and hoods attached- Pack is wide enough and deep enough and there is room in the center (with adjustable dividers) for two flashes. Makes for quick shooting. It is a big pack, but it's manageable, I am a woman, and it's about my torso wid …"  Read Full Review »
Mar 6 2009
Kari
Idaho
I am:
  • Pro Photographer
Reviewed at:
Price: $99.95
The Thinking Photographers Camera Bag
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
  • Improves Performance
  • Professional Quality
    Cons
  • None
    Best Uses
  • Complex Projects
"Toting around two DSLR's, six lens (of various lengths), charging stations, remote controls, notebooks, and business cards tends to cause one to yearn for the good ole point and shoot days. But the 5770 Velocity has changed my viewpoint considerably. With ample primary space to carry my Olympus bodi …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 30 2009
ridgecounter
Oldsmar, Florida
I am:
  • Business Owner
  • Professional Artist
Reviewed at:
Price: $99.95
Tamrac Velocity 10X Sling Pack
4.0
    Pros
  • Easy To Use
    Cons
  • Its pretty large
    Best Uses
  • In the field
"I had been seeking a bag that would accommodate my DSLR with a 100-400 mm lens attached along with a couple of other lenses and large flash, transferred some of the bag weight from my shoulders to my hips, and would allow me to access the contents without removing the bag. This is the first bag that …"  Read Full Review »
Jul 2 2009
gwh
Austin, Texas
I am:
  • Hobbyist
Reviewed at:
Price: $99.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
