Sylvania LC225SL9 LCD HDTV - 22 Inch
#452
4.1
based on 11 reviews
Ratings Distribution
5 star
6
4 star
2
3 star
2
2 star
0
1 star
1
Category Average
4.4
Low Price:
$341.88 at Meijer.com
 Trusted:
$369.99 at MacMall
$365.99 at ClubMac
see all stores
$341.88 - $399.99
from 6 stores
More Images
Pros
  • Good connection options (6)
  • Attractive design (5)
  • Fast setup (5)
  • Great picture quality (4)
  • High resolution (4)
  • Simple controls (4)
  • Wide viewing angle (3)
  • Easy setup (1)
  • Great sound quality (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Bad interface (1)
  • Low resolution (1)
  • No cons - for a test unit (1)
  • Poor image quality (1)
  • Slow on changing channels (1)
Best Uses
  • Bedroom (3)
  • Dorm room (1)
  • Movies (1)
  • Office (1)
  • Small rooms (1)
  • Testing (1)
Provided by Meijer.com
The new Sylvania LC225SL9 22" HD LCD TV delivers high-definition viewing in a compact design that makes it convenient to use anywhere in the home or office. This stylish television offers WSXGA 1680x1050 resolution, Pix technology, and a 3D digital comb filter for superior image quality. The Sylvania LC225SL9 features a built-in ATSC/NTSC tuner with HD quality output, closed caption decoder, Dolby digital sound and a variety of connection options, including PC-in, S-video and HDMI. Enjoy high-definition entertainment anywhere in your home or office with this compact, HD LCD television. If you thought you couldn't afford HD TV, think again. The Sylvania LC225SL9 is priced to fit your budget.
Specification Description
Model 053818640548, LC-225SL9, LC225SL9
UPC 053818640548
16:9 Mode Yes
Audio Controls Treble, base, reset
Benefits XGA display delivers HD, 1368x768 pixel resolution for incredibly realistic imagesFeatures a coaxial digital audio output for routing
Capacity UOM mAh
Closed Caption Capability Yes
Compliant Standards UL Listed, FCC/DHHS Certificated
Controls / Adjustments Contrast, brightness, color, tint, sharpness
Country Of Origin China
Description Header Get crystal-clear quality.
Display Catalog Number 55028021
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 22 inches
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box Sylvania LC225SL9 22" LCD HDTVRemote ControlUser's Guide
Inputs 1 x RCA(Video), 1 x S-Video(S-Video), 1 x Component(Component), 1 x HDMI(HDMI), 1 x VGA(PC-in), 1 x "F" Plug(RF in), 3 x RCA(Audio in), 1 x Phone 1/8"
Manufacturer Labor Warranty 90
Manufacturer Part Number LC225SL9
Manufacturer Parts Warranty 12
MAP Price 0.0
Model LC225SL9
Operating Temperature UOM ° F
Output Power / Total 2 watts
Outputs 1 x Digital(Digital audio out)
Parental controls Yes
Product Depth 7.4
Product Dimensions UOM inches
Product Disclaimer Dolby is a registered trademark of Dolby Laboratories Licensing Corporation. DTS is a registered trademark of Digital Theater Systems, Inc.
Product Height 17.8
Product Type Flat-panel TVs
Product Weight 11.1
Product Weight UOM pounds
Product Width 21.4
Reception System ATSC/NTSC/QAM
Screen Size Range 21-30"
Sound Output Mode Stereo
Speaker(s) Built-in, 2W Speakers (2)
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 22 inches
TV Resolution 1680x1050
TV Technology LCD
Voltage Required 120VAC +/- 10%, 60Hz +/- 0.5%
Widescreen Modes 480i, 480p, 720p, 1080i
Sylvania LC225SL9 LCD HDTV - 22 Inch Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 7, 2009
Sylvania LC225SL9 LCD HDTV - 22 Inch Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
5.0
HD in the bedroom
"Great bedroom cinema; easy to set up there's everything you need in the cute remote. If you are going to use a dvd player, please choose a similar model. The stand looks flimsy but does the job...." Read Full Review »
Aug 04, 2008 by Rick
See more positive Sylvania LC225SL9 LCD HDTV - 22 Inch reviews
1.0
Not worth the money!
"I bought this television for my daughter this past Christmas. The picture was great for a couple of weeks, but has gotten fuzzier every day. Yesterday the screen quit working. It went to a bunch of colored lines and made a loud static noise whenever you turned it on. Today we turned it on and the screen stays black. After troubleshooting over the phone with Sylvania, they determined that it needs sent back...." Read Full Review »
Feb 09, 2009 by T
See more negative Sylvania LC225SL9 LCD HDTV - 22 Inch reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
HD in the bedroom
5.0
    Pros
  • Attractive Design
  • Clear Audio
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Dorm Rooms
  • Movies
  • Office
  • Small Rooms
The stand looks flimsy but does the job. "
Was this LCD TV review on the Sylvania LC225SL9 LCD HDTV - 22 Inch helpful to you?
 Report Abuse  (5)  (0)  0 comments
Aug 4 2008
Rick
Denver Colorado.
I am:
  • Practical
  • Professional
  • Tech Savvy
[3 of 3 customers found this review helpful]
I just bought another one of these
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
    Cons
  • None
    Best Uses
  • None
"I bought one for my son's room about a month ago and I am very pleased with the T.V. My son's loves it. I am buying another one for my daughter's room. This is a great product for the price. Great picture and sound. Sylvania is one of the best manufacturer name of the pass and will be one of the fut …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Nov 16 2008
Amy
Boston, MA
I am:
  • Casual User
1.0
    Pros
  • Attractive Design
  • Reduced Glare
    Cons
  • Bad Interface
  • Dull Image
  • Poor Resolution
    Best Uses
  • Bedroom
"I bought this television for my daughter this past Christmas. The picture was great for a couple of weeks, but has gotten fuzzier every day. Yesterday the screen quit working. It went to a bunch of colored lines and made a loud static noise whenever you turned it on. Today we turned it on and th …"  Read Full Review »
Feb 9 2009
T
Cincinnati, OH
I am:
  • Casual User
Reviewed at:
Price: $341.88
Good Test Unit
3.0
    Pros
  • Fast Setup
  • Simple Controls
  • Used For Testing
    Cons
  • No Cons - For a Test Unit
    Best Uses
  • Testing
"The product is being used in a test lab. It is being submitted to high level HDMI testing to see if the product interface can be forced to fail. So far, so good.
I would recommend this product for testing but I wouldn't have it in my home. "
Mar 16 2009
HDMI Tester
San Diego, CA.
I am:
  • Power User
Awesome
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
"Great HD picture when using my Xbox 360. The picture is very good, especially for the price and the size. Would definatley recommened "
Aug 7 2009
Big Daddy Ken
Garfield Heights Ohio
I am:
  • Casual User
Reviewed at:
Price: $341.88
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
