Sunpak Ultra-Pro Tripod With 3-Way Fluid-Effect Head - Black
#210
3.4
based on 5 reviews
from $79.99 - $99.99
Ratings Distribution
5 star
0
4 star
4
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$79.99 at ClubMac
 Trusted:
$89.95 at B&H Photo Video
$79.99 at OnSale
see all stores
More Images
Pros
  • Easily adjusted (3)
  • Good footing (3)
  • Locks in tight (3)
  • Smooth movement (3)
  • Rugged (2)
  • Compact (1)
  • Good stability (1)
  • Unfolds quickly (1)
See less See more
Cons
  • Heavy / bulky (3)
Best Uses
  • Special events (3)
  • Sports (2)
  • Home (1)
  • Landscapes (1)
  • Long exposures (1)
  • Occasionally (1)
  • Office (1)
  • Photography (1)
  • Portraits (1)
  • Stabilization (1)
Provided by Kmart
. 2.4GHz interference-free connectivity. Plug-and-play, no synching needed. Uses optical technology. Rubberized side grips. For right or left hand use. Stowable USB receiver. Black
Specification Description
Model 620-777B, 620777B
UPC 090729607789
Maximum Capacity 10 To 19.9 Lbs
Maximum Height 60" to 72"
Select Aluminum
Sunpak Ultra-Pro Tripod With 3-Way Fluid-Effect Head - Black Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 4, 2008
Sunpak Ultra-Pro Tripod With 3-Way Fluid-Effect Head - Black Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Don't get this if you are a teacher
1.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • occasionally
"I am a TV Production teacher so we use tripods every day. I ordered three of these tripods. Within two weeks, one of the tripod legs had broken and is unrepairable. Another tripods handle broke off and we now have limited movement with the head. The last one broke as well rendering the use of the pa …"  Read Full Review »
Was this Tripod Leg review on the Sunpak Ultra-Pro Tripod With 3-Way Fluid-Effect Head - Black helpful to you?
 Report Abuse  (2)  (0)  0 comments
Apr 14 2008
Ms. G the Teacher
Bradenton, FL
I am:
  • Professional
Reviewed at:
Price: $89.95
Great features
4.0
    Pros
  • Easily Adjusted
  • Good Footing
  • Locks In Tight
  • Rugged
  • Smooth Movement
    Cons
  • Heavy
    Best Uses
  • Landscape
  • Special Events
  • Sports
  • Travel
"Well built and thought through. Has many features you would expect in a tripod. Legs spread wide and independently giving great flexibility in set-up. The extra quick release plate is just the ticket if you are always swapping out cameras - makes it easy so you don't miss any shots. The tripod ( …"  Read Full Review »
Oct 6 2008
David
Albany, NY
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $89.95
Great Value
4.0
    Pros
  • Good Stability
  • Unfolds Quickly
    Cons
  • Heavy
    Best Uses
  • Long Exposures
  • Photography
  • Portraits
  • Stabilization
"Can’t say enough good things about this product, it’s sturdy and easy to assemble less than 10 seconds to open the tripod and locked it in place. Its manufacture from strong material legs are solid not hollow and the plastic coded material is top of the line. Absolutely would recommend this product. …"  Read Full Review »
Aug 24 2008
Rafael
Charlotte, NC
I am:
Reviewed at:
Price: $89.95
Great tripod for the price/
4.0
    Pros
  • Easily Adjusted
  • Good Footing
  • Locks In Tight
  • Rugged
  • Smooth Movement
    Cons
  • Heavy
    Best Uses
  • Home
  • Office
  • Special Events
"I have been trying to improve the clarity of my shots. Using this very stable tripod helped greatly. It is quality and ease of use in every way. It is, however, not easy to travel with on plane trips due to its weight and the ever tightening weight restrictions of the airlines. "
Apr 16 2008
John
Kennesaw, GA
I am:
Reviewed at:
Price: $89.95
Strong and versatile
4.0
    Pros
  • Compact
  • Easily Adjusted
  • Good Footing
  • Locks In Tight
  • Smooth Movement
    Cons
  • None
    Best Uses
  • Special Events
  • Sports
  • Studio
"The tripod head is the only problem, the quick release is plastic "
Nov 4 2008
Luis Hernandez
Atlanta, Ga
I am:
  • Semi-Professional
Reviewed at:
Price: $89.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
