Sunpak Compact SXL Tripod with 2-Way Panhead - Supports 3 lbs (1.36kg)
4.0
based on 4 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
1
1 star
0
Category Average
4.1
Low Price:
$21.95 at B&H Photo Video
 Trusted:
$21.95 at Adorama
Find it at Amazon
$21.95
from 2 stores
Pros
  • Easily adjusted (2)
  • Lightweight (1)
See less See more
Best Uses
  • Travel (3)
  • Home (1)
Provided by B&H Photo Video
The Sunpak Compact SXL Tripod features a two-way panhead with textured surface and easy-grip pan handle. Oversized leg locks assure fast setup. The gearless lift'n'lock center column features an oversize locking collar. Rubber leg tips provide traction outdoors and protect surfaces indoors. Lightweight and sized perfectly for fitting into a backpack the Compact SXL Tripod is an excellent vacation tripod when traveling. Ideal for backpackers wanting camera or camcorder support.
Sunpak Compact SXL Tripod with 2-Way Panhead - Supports 3 lbs (1.36kg) Questions
Questions and Answers
Where to Buy
$21.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$21.95
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Feb 21, 2009
Sunpak Compact SXL Tripod with 2-Way Panhead - Supports 3 lbs (1.36kg) Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[2 of 3 customers found this review helpful]
No need to use the case
2.0
"The review is actually about the case, not the tripod. The tripod was affordable and compact, which was what I was looking for. I plan to use it for long exposure night shots while backpacking in Tokyo. It's strong enough (barely) to hold up my DSLR and 1:2.8, 75mm lens. The camera weights a litt …"  Read Full Review »
Was this Camera Tripod review on the Sunpak Compact SXL Tripod with 2-Way Panhead - Supports 3 lbs (1.36kg) helpful to you?
 Report Abuse  (2)  (1)  0 comments
Oct 29 2007
Camera shy
San Francisco, CA
Reviewed at:
Price: $21.95
[2 of 2 customers found this review helpful]
Works well, within it's limits
5.0
    Pros
  • Easily Adjusted
  • Lightweight
    Cons
  • None
    Best Uses
  • Travel
"We use this tripod with our D70 with the smaller lenses and it works just fine, nice and compact and you can't beat the price. Just be mindful that you're also losing a little max height with the compact size. "
 Report Abuse  (2)  (0)  0 comments
Aug 5 2008
hatchm
NW Washington
I am:
  • Casual user
Reviewed at:
Price: $21.95
[1 of 1 customers found this review helpful]
Excellent Tripod. Small and Sturdy!
5.0
    Pros
  • Easily Adjusted
    Cons
  • None
    Best Uses
  • Home
  • Travel
"Took with me to a European vacation and it was of great help to get some difficult shots otherwise impossible without a tripod. "
 Report Abuse  (1)  (0)  0 comments
Oct 20 2008
The perfecionist
New York
I am:
  • Semi-Professional
Reviewed at:
Price: $21.95
Lightweight and compact
4.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • traveling
"This tripod is as advertised. It's compact and lightweight. It stretches quite a bit too for a compact tripod. "
Feb 21 2009
RJ
Passaic, NJ
Reviewed at:
Price: $21.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
