Close Login Module
Join
SteadiCam 'DEMO' Merlin Camera Stabilizing System - with Metal Gimbal
4.3
based on 40 reviews
Ratings Distribution
5 star
19
4 star
19
3 star
0
2 star
0
1 star
2
Category Average
4.1
$799.00
from 2 stores
More Images
Pros
  • Lightweight (21)
  • Folds small (17)
  • Good stability (15)
  • High quality (15)
  • Unfolds quickly (15)
  • Improves performance (14)
  • Compact design (11)
  • Highly compatible (6)
  • Easy to use (4)
  • Versatile (2)
See less See more
Cons
  • Pricey (5)
  • Heavy (2)
  • Steep learning curve (2)
  • Cost (1)
  • Cumbersome (1)
  • Difficult to balance (1)
  • Difficult to calibrate (1)
  • Difficult to set up (1)
  • Difficult to use (1)
  • Flimsy (1)
Best Uses
  • Stabilization (19)
  • Independent films (12)
  • Complex projects (8)
  • Home movies (6)
  • Studio (5)
  • Movies (3)
  • Weddings (3)
  • Any moving shot (1)
  • Controlled pans (1)
  • Corporate productions (1)
Where to Buy
BizRate Rating Outstanding 9.6
$799.00
No Tax Outside NY
BizRate Rating Outstanding 9.1
$799.00
Product Reviews
Last update: Oct 22, 2009
SteadiCam 'DEMO' Merlin Camera Stabilizing System - with Metal Gimbal Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
4.0
With careful calibration...
"The Merlin actually works, even with the Sony HVR-V1U which is right at the top of the Merlin weight limit. Although it requires absolutely meticulous adjustment, the instructions (including DVD) are adequate. The included carrying case allows you to store and carry the Merlin, folded up, with the camera attached. An included mounting plate lets you move the camera from Merlin to pan/tilt head readily, but ..." Read Full Review »
May 21, 2008 by skip
See more positive SteadiCam 'DEMO' Merlin Camera Stabilizing System - with Metal Gimbal reviews
1.0
Hard to start up and control
"I use this for CanonEos5Dmark2. Although, it should be in the work range of weight for this product, it takes a long time to get right, is much more difficult to use than I expected. As a matter of a fact, I cannot aim precisely where I want it to. It goes unexpected way. Maybe a lot of practice is required. I cannot really recommend this...." Read Full Review »
Jul 11, 2009 by TAK
See more negative SteadiCam 'DEMO' Merlin Camera Stabilizing System - with Metal Gimbal reviews
Displaying 1 - 5 of 40 Reviews
Show
Sort by
Quality product! [...]
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
  • Improves Performance
  • Professional Quality
    Cons
  • None
    Best Uses
  • Complex Projects
  • Home Movies
  • In The Studio
  • Independent Films
"Bought the Steadycam Merlin in September 2009. I think it is perfect tool for videowork. Please check my footage for the SONY HDR SR12 & STEADICAM MERLIN [@]Would recommend! Regards. "
Oct 20 2009
Valentina
Pittsburgh,PA
I am:
  • Business Owner
  • Film Student
  • Hobbyist
  • Professional Artist
Reviewed at:
Price: $799.00
For serious indy filmmakers
5.0
    Pros
  • Compact Design
  • Highly Compatible
  • Incredible
    Cons
  • Pricey
    Best Uses
  • Complex Projects
  • Documentaries
  • Home Movies
  • In The Studio
  • Independent Films
"I just got this Merlin a few days ago and I only really got it working right today, and yes what they say about it being a steep learning curve is right. It takes some time to get your camera balanced on it but the shots you can get after that are extremely smooth and fluid. This product is what y …"  Read Full Review »
Oct 22 2009
chrychek
Nova Scotia, Canada
I am:
  • Indy Filmmaker
Reviewed at:
Price: $799.00
4.0
    Pros
  • Folds Small
  • Good documentation
  • Practical in tight space
    Cons
  • None
    Best Uses
  • Stabilization
  • Stairs
  • Walking shots
"The Merlin actually works, even with the Sony HVR-V1U which is right at the top of the Merlin weight limit. Although it requires absolutely meticulous adjustment, the instructions (including DVD) are adequate. The included carrying case allows you to store and carry the Merlin, folded up, with the …"  Read Full Review »
May 21 2008
skip
Hershey, PA
I am:
  • Video Professional
Reviewed at:
Price: $799.00
Phenomenal piece of kit!
5.0
    Pros
  • Folds Small
  • Good Stability
  • Lightweight
  • Unfolds Quickly
    Cons
  • None
    Best Uses
  • Movies
  • Real Estate Videos
  • Stabilization
  • Weddings
"Used for Real Estate Videos, Independant Film production, Weddings.
Pros
Extremely well engineered and crafted. Once you get the hang of it, it works beautifully, although be warned, there is a serious learning curve. Don't expect to 'fly' it perfectly right out of the box. Sit down and take …"  Read Full Review »
Jul 22 2008
Van Rugge
Montreal, Canada
I am:
  • Aspiring Film Maker
Reviewed at:
Price: $799.00
[1 of 1 customers found this review helpful]
Works great IF you take your time
5.0
    Pros
  • Compact Design
    Cons
  • cost
    Best Uses
  • Hand held video
  • Home Movies
  • Independent Films
  • Real Estate
"I use it for Real Estate Videos.
This is truly a precision product. As is the case with most precision instruments, it takes some time to understand the working concept but once you do, the setup is pretty straight forward. My intended use is for a Canon 5D MKII and a Canon XHA1. So far I have on …"  Read Full Review »
Sep 7 2009
urphotoguy
Denver, CO
I am:
  • Pro Photographer
  • Pro videographer
Reviewed at:
Price: $799.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$799.00
No Tax Outside NY
$799.00
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
