Startech USB to Parallel Interface Converter
#1048
3.7
based on 3 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.1
$11.00 - $59.99
from 11 stores
More Images
Pros
  • Highly compatible (1)
  • Improves performance (1)
See less See more
Cons
  • Flimsy (1)
Best Uses
  • Computer equipment (1)
Provided by Shoppers Choice
MODEL- ICUSB1284 VENDOR- STARTECH. COM LTD FEATURES- USB to Parallel Interface Converter The USB-to-Parallel Interface Converter Cable allows PCs that support the USB specification to print to any standard parallel printer. The USB interface provides a much faster data transfer rate than a standard parallel port, thereby reducing the time waiting for a print job to be sent to your printer. This portable device is self- powered and provides Plug and Play installation to any USB-compliant computer running Windows 98/ME/2000/XP. Low power consumption as it draws power from the USB connection. High speed bi-directional parallel port compliant to IEEE-1284 industry standard. Fully Plug & Play for easy installation. Supports Windows 98, Windows ME, Windows 2000/XP. No IRQ required for installation. Connectors: (1) USB Type A Male port (1) Centronics 36 Male Parallel port Cable Length: 180cm (72 in. ) Power Consumption: 90mA (max) Power Mode: Bus powered SIZE - 1. 72 inch x 2. 12 inch x 0. 78 inch WT. - 3. 85 oz. Www. Startech. Com
Specification Description
Model ICUSB1284
UPC 065030781015
Accessory Indicator Yes
Benefits Plug-and-play installation to any USB-compliant computer running Windows® 98/ME/2000/XPCompact size and low weight make it a natu
Cable Compliant Standards USB
Cable Type USB
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Benefit from USB speed.
Display Catalog Number 55007670
Humidity Range Operating 0-80%
Interface Supported Windows
Left Connector(s) USB
Manufacturer Labor Warranty 12
Manufacturer Part Number ICUSB1284
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 41 Fahrenheit
Model ICUSB1284
Operating Temperature UOM ° F
Product Dimensions UOM feet
Product Length 6
Product Type USB
Right Connector(s) IEEE1284 Centronics
Supported Languages English
Startech USB to Parallel Interface Converter Questions
Questions and Answers
Where to Buy
$59.99
$29.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$11.00
Show all 11 stores
Product Reviews
Last update: Nov 16, 2009
Startech USB to Parallel Interface Converter Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
I would buy more
5.0
    Pros
  • Highly Compatible
  • Improves Performance
    Cons
  • Flimsy Construction
    Best Uses
  • Computer Equipment
"Good quality product. "
Was this Computer Cable & Connection review on the Startech USB to Parallel Interface Converter helpful to you?
Nov 16 2009
speeddy
South Plainfield, NJ
I am:
  • Quality Oriented
Reviewed at:
Price: $29.99
[1 of 2 customers found this review helpful]
Doesn't work on Xerox Workcenter 385
1.0
"I tried two brands of USB to Parallel cables so I could use my old Xerox Workcenter 385 with my new Dell laptop (that only has USB connectors). Neither worked. I contaced Xerox and they don't have any recommendations for compatible cables.
I still run my old computer and networked it and the print …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Jan 10 2007
Not-a-real-Techie
Vancouver, Canada
Reviewed at:
Price: $59.99
It worked for me...
5.0
"I tried this cable and it worked for me...it allows us to keep using the old printer we had. I am happy. "
May 21 2009
B. Lewison
California
Reviewed at:
Price: $59.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
